12-19-2023, 04:55 PM | #1 |
Rep 95
(SOLVED) No media/radio, communication, time etc. Lights are on, nobody home.
After having and issue with P147e code, patching the wiring, and replacing the fuse, my radio has no stopped working. The idrive system itself is on but there is no sound and it seems that everything is half loaded. It started this morning in concert with a brake light that I was able to remove by resetting my service interval for the rear pads.
The batter connections are fine and there is plenty do juice in the battery. Any ideas for causes? SOLVED: So this is embarrassing. When replacing the fuse that was fried I replaced it with the fuse for the speakers for some reason. I just had to put the fuse back in and everything was fine. Note to self: dont only check if fuses are broken but check if all fuses are still in place.... Last edited by GENAU; 12-29-2023 at 10:38 AM.. |
