BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Need help coding out front pdc
      07-30-2021, 07:53 AM   #23
Ikoll
Drives: 2017 330i F31 m-sport
Originally Posted by atzebmw View Post
You retrofitted the front PDC?
Then you have to set all values to WERT_02.
Because the first question here was to code out the front PDC.
So here again all values for the Front PDC retrofit.
REM_01 > EcuHwConfiguration 3000 > HW_OPTION_BODY_PDC = aktiv
REM_01 > PdcParkMasterVar 3203 > A_HYSTERESE = wert_02
REM_01 > PdcParkMasterVar 3203 > D_SCHWELLE_1 = wert_02
REM_01 > PdcParkMasterVar 3203 > D_SCHWELLE_2 = wert_02
REM_01 > PdcParkMasterVar 3203 > V_SCHWELLE_1 = wert_02
REM_01 > PdcParkMasterVar 3203 > V_SCHWELLE_2 = wert_02
REM_01 > PdcVarCoding 3200 > PDC = wert_02
REM_01 > PdcVarCoding 3200 > PDC_VARIANT = wert_02
ICMQL > Daten 3000 > IcmKod_B_S508A = aktiv
HU_NBT > EXBOX 3001 > MACRO_PDC = aktiv
HU_NBT > EXBOX 3001 > PDC_SENSOR_HINTEN = 4_sensoren
HU_NBT > EXBOX 3001 > PDC_SENSOR_VORN = 4_sensoren
Big thanks!
It worked.
I must have read the thread a little to fast. Just went directly at the coding part.
The change from 4_sensoren to kein_sensoren seemed kinda strange
      03-11-2022, 02:44 PM   #24
manuelp
Drives: BMW F20 118D Sport
Hi friends, I have installed the rear sensors on my f20 from scratch, I have problems with the 507 encoding or the hu_entry gives me an error and no longer recognizes me the cafd. So I would like to activate each value manually.
I use esys and until recently I was able to start only the sound of the sensors, then after several attempts I also saw the image in the monitor but it was all wrong and with errors I had to restore via backup but above all through the user shawnsheridan that I saved the car. But now I can't figure it out, you who have already done this, could you tell me the codes to set correctly starting from scratch?
Thank you guys.
      05-13-2022, 11:34 PM   #25
darakuja
Drives: 2013 bmw x3 28i
Ah OK.
VO is the vehicle order which you can't edit with Bimmercode.
No, if you use Bimmercode then go another way.
Try to change the following values if you find them:
in REM:
PdcParkMasterVar 3203 > A_HYSTERESE = wert_02 to wert_01
PdcParkMasterVar 3203 > D_SCHWELLE_1 = wert_02 to wert_01
PdcParkMasterVar 3203 > D_SCHWELLE_2 = wert_02 to wert_01
PdcParkMasterVar 3203 > V_SCHWELLE_1 = wert_02 to wert_01
PdcParkMasterVar 3203 > V_SCHWELLE_2 = wert_02 to wert_01
PdcVarCoding 3200 > PDC_VARIANT = wert_02 to wert_01
in HU
EXBOX 3001 > PDC_SENSOR_VORN = 4_sensoren to kein_Sensor
Hi , could you provide coding on BimmerCode for front and rear pdc sensors
      05-14-2022, 07:07 AM   #26
darakuja
I’ve got a person to code my pdc , he did it on ista , and they are not working . When I change provided values to 01 the rear pdc start working but not front ones , when i change values to 02 they are not working at all
      07-03-2022, 08:42 PM   #27
Carlosskrr
Drives: Bmw f36
Originally Posted by Bruceking07 View Post
I can also confirm that this code works for the front. Now does anyone know how to code out the rear PDC with bimmercode?
REM_01 > EcuHwConfiguration 3000 > HW_OPTION_BODY_PDC = nicht_aktiv
REM_01 > PdcParkMasterVar 3203 > A_HYSTERESE = wert_01
REM_01 > PdcParkMasterVar 3203 > D_SCHWELLE_1 = wert_03
REM_01 > PdcParkMasterVar 3203 > D_SCHWELLE_2 = wert_03
REM_01 > PdcParkMasterVar 3203 > V_SCHWELLE_1 = wert_03
REM_01 > PdcParkMasterVar 3203 > V_SCHWELLE_2 = wert_01
REM_01 > PdcVarCoding 3200 > PDC = wert_01
REM_01 > PdcVarCoding 3200 > PDC_VARIANT = wert_04
HU_NBT > EXBOX 3001 > MACRO_PDC = nicht_aktiv
HU_NBT > EXBOX 3001 > PDC_SENSOR_HINTEN = kein_sensor
Hey I just coded this into my car trying to get rid of front and rear pdc but now I have no back up camera. Did I do something wrong ? How can I get my reverse camera back without having my front and rear pdc's active
      09-05-2022, 12:13 PM   #28
Tony1316
Tony1316's Avatar
Drives: BMW 340i Xdrive
Question Code in my Rear backup Camera and PDC
[QUOTE=jaypayne05;25143012]So I did it and it worked perfectly. Thank you very much.[/QUOSo I was wondering if i could pay you to code that in for my f30 as well. i dont wanna mess with the advanced coding like that.
Antoniohakim
      09-05-2022, 12:15 PM   #29
Tony1316
Tony1316's Avatar
Could u send me his link i need to do this as well.
Antoniohakim
      02-07-2023, 01:28 PM   #30
mcmxciMega
mcmxciMega's Avatar
29
Drives: 17 BMW 440ix; 19 Mini Coope
Ah OK.
in REM:
in HU
Hey thanks so much for posting this. EXTREMELY helpful. I'd been searching the internet for the last month looking for a way to do this. One of my front sensors started to go bad, and as you can imagine, having the PDC screaming at you when you're going in reverse isn't exactly pleasant.
Can confirm this coding worked on my 17 440i. Thanks so much!
      03-28-2023, 08:06 PM   #31
farhad_uddin
Drives: bmw
BMW F36 PDC Help
Hi there, I purchased a crash damaged BMW F36 2015, front PDC were missing so replaced all front and loom. Still have no luck and Idrive shows all PDC failures but the computer diagnostic only shows all front sensors as no read but no errors for the rear. Am I able to use the following you mentioned on bimercode to deactivate front sensors so Idrive won't show error and back ones will end up only working? Not fussed about the front, just want the error to go and rears to work.
Thanks in advance!
Ah OK.
in REM:
in HU
      03-29-2023, 12:34 PM   #32
TheNine90
Drives: bmw
Yes. the above code will only activate rear pdc.
also change this
ICMQL
Daten 3000 > IcmKod_B_S508A = nicht aktiv
      05-02-2023, 03:05 PM   #33
PauloP
Drives: bmw
I retrofitted my PDC Front F20.
Now it is off by default and only works if I turn it on via the button on the console or when I engage reverse gear.
I would like it to stay on all the time.
Does anyone know how to code?
      07-16-2023, 12:43 PM   #34
Amer_n55
Drives: Bmw f32
[QUOTE=atzebmw;25141180]Ah OK.
in REM:
in HU
EXBOX 3001 > PDC_SENSOR_VORN = 4_sensoren to kein_Sensor[/QUOTE
Hello, I know it's been a while on this but I recently needed to code out my front pdc sensors and I tried this on bimmer code step by step, added this as well ( ICMQL
Daten 3000 > IcmKod_B_S508A = nicht aktiv) and it doesn't seem to work for my car even tho it's pretty much identical to the one it worked on in this post. I have a 2016 435i m package.. any idea what I could be doing wrong?
I should probably also mention that my car is xdrive coupe not grand coupe, if that makes any difference..
Thank you in advance.
      07-18-2023, 10:48 AM   #35
TheNine90
Drives: bmw
you are using bimmercode or esys?
      07-19-2023, 12:01 PM   #36
Amer_n55
Drives: Bmw f32
I'm using bimmercode.
I was trying different things today and I realized that I was able to code out front pdc yet I was still getting the warning on startup or when the speed goes below 15km/h. I even coded out rear pdc and was still getting the same warning! All cameras were still working fine. Not sure what the problem is. At this point wondering if I can code out the warning only, btw the warning I'm getting is (parking assistance malfunction: please park unaided)...
      07-19-2023, 12:56 PM   #37
TheNine90
Drives: bmw
If you have 5DP Park Assistant then you will have errors because the parking aid relies on the sensors to work. You can try coding it out.
      09-18-2023, 09:31 PM   #38
Valentinjosh
Drives: Bmw 2007 e90
Hello group
Anybody know how to program the pdc or what are my options to fix this?
Error: Ultrasonic sensor, front outer left, sensor fault:
Programming
Thanks
      09-21-2023, 10:36 AM   #39
TheNine90
Drives: bmw
Confirm if you coded the modules correctly.
      09-21-2023, 06:50 PM   #40
Valentinjosh
Thanks for answering
How can i do it? Bimmercode or ista?
      09-23-2023, 03:54 AM   #41
TheNine90
Drives: bmw
Coding is done using esys
      09-23-2023, 09:55 AM   #42
Valentinjosh
Im gonna have to check...
Thank you
      09-24-2023, 05:40 AM   #43
quaz337
Drives: BMW 320i
2017 BMW  [0.00]
Ah OK.
in REM:
in HU
Thanks for posting this. I can confirm it works perfectly on my 2017 320i.
My front PDCs aren’t working, and I have had to always press the idrive control knob to ignore the pdc error message every single time I put the gear in reverse for the rear camera to come on. With this coding, I was able to delete out the front pdc and now. Once I put the car in reverse, the rear camera comes on immediately without any error message. The rear pdc still working. Perfect solution for me.
I used BimmerCode
      05-08-2024, 07:34 AM   #44
Haq
Haq's Avatar
Australia
Drives: 15' F30 330i Msport,
Ah OK.
in REM:
in HU
this worked, thank you.
06' E90 320i Executive
15' F30 330i Msport
