12-11-2020, 09:09 PM | #45 |
Rep 881
alohasurftoad3076.50 |
12-12-2020, 03:10 AM | #46 | |
Rep 108
12-12-2020, 09:56 AM | #47 |
Rep 178
Sorry for hijacking the thread. Planning to buy a new set of rims this spring for my xDrive
Spec Front – 20×8.5 ET40 Rear – 20×10 ET45 Thinking tires Front - 235x35 Rear - 275x30 Thoughts? |
12-12-2020, 10:47 AM | #48 |
Rep 4,325
that should work fine, however you might want to consider a 5, 7.5 or 10mm spacer up front for appearance or an offset of ET35-ET30, if available, since ET40 is slightly more tucked.
12-12-2020, 11:14 AM | #49 | |
Rep 178
Whats the lowest ET you can go on the F36? Would ET31 front and ET38 rear be to low? Last edited by Sigge; 12-13-2020 at 02:48 PM.. |
12-23-2020, 02:40 PM | #50 |
Rep 14
Quick question for you guys. 2014 320i xDrive. Factory tire size is 225/50R17. Id like to upgrade that to a slightly bigger tire. Whats a safe option?
2014 320iX
2008 Dmax 2008 Tahoe 1967 Malibu |
12-23-2020, 04:23 PM | #51 |
Rep 7,602
You have to be more specific. Bigger in what way? Taller sidewall? Wider wire with same overall height? Same wheels or different wheel size? If different wheels, what size? Looking for more flush fitment? etc etc.
12-23-2020, 05:38 PM | #52 |
Rep 14
Same wheels. Thinking the factory 225/50 in the front but a slight bigger 255/45 in the rear. Just not sure with the xDrive is that safe.
2014 320iX
04-14-2021, 03:56 PM | #53 |
Rep 8
Hello, 335i xdrive, i bought OEM 437M, 9x19 and 10x19.
What tyre size I need for xdrive? If tyre is not suitable, would xdelete avoid problems with transfer case? Thanks |
