11-12-2020, 01:51 PM | #1 |
Rep 6
Slid into a barrier - headlight and lower bumper damage
Hey guys,
It was very icy and my car slid into a concrete barrier on the freeway. Fortunately it was a slight tap but she did suffer some damage. I was wondering if the grille on the lower bumper where the fog light is located is simply a piece that snaps on, like the kidney grille. Also, my headlight lens is cracked and the body shop guy is telling me I have to replace the whole headlight assembly. I find that questionable, because the actual headlight is working just fine! Is there a way I can just get the lens itself replaced? Much appreciate any input or comment, thanks! Last edited by mad_jack; 11-12-2020 at 01:58 PM.. |
11-12-2020, 02:07 PM | #2 |
E4 Mafia
323
Rep 412
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
sorry to hear this but it's good you and the car are mostly ok!
I haven't had the nose off the F30, but usually all those "grill" pieces are separate and snap in. a quick look at realoem confirms this. headlights are also usually one piece. the lens is glued and sealed in. it can be removed but usually requires heating the sealing adhesive, not typical. again, realoem shows it as the assembly as one piece. good luck!
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
mad_jack0.00 |
11-12-2020, 02:45 PM | #3 | |
Rep 6
My main concern about the headlight is that it's sort of out of alignment and now there's this "gap" (see picture). Will this be a problem when I wash the car? As in, will there be important components down there that can be damaged by water? |
11-12-2020, 03:41 PM | #4 |
Rep 1,597
I would replace the lense cover only its a large piece of cheap molded plastic and get the part number from realoem.com for the foglight area. When you disassemble the light area you can fix any dislocations. Looks very minor and it'll be an easy patchup.
mad_jack0.00 |
11-12-2020, 06:52 PM | #5 | |
Rep 6
Anyone think I should be concerned about water intrusion via the headlight area (see gap)? I'm worried the area beneath it would start collecting water and potentially damage some wiring or other componentry |
11-12-2020, 07:52 PM | #6 | ||
E4 Mafia
323
Rep 412
shops probably won't touch changing the lens since it's sealed and comes as an assembly. don't want to be on the hook for moisture inside the headlight. plus it's super easy to swap in a new one.
11-12-2020, 11:25 PM | #7 |
Rep 20
Drives: 14%C2%92 F30 335, 95%C2%92 E36
What about depo headlights? They're a little more pricy but you get the upgraded look with halos for around 500 dollars, this way you could take this opportunity to upgrade your headlights and get a little more visibility and better looks.
If you wanna go the repair route the halogen headlight assembly is cheap. A quick google search shows they're around 140 per side which is hands down way less hassle compared to trying to replace your lenses. |
mad_jack0.00 |
11-13-2020, 12:24 AM | #8 | |
Rep 6
I think maybe the cracked headlight might be a problem when exposed to rain and the car wash? The headlight still works, I'm just not sure if water getting through the cracked opening could cause other problems down the line. I will eventually get it replaced, but how urgent do I need to get this fixed? |
11-13-2020, 12:29 AM | #9 | |
Rep 6
However, if I don't have to replace my headlight because of the broken lenses, then I might just leave it alone for now. Sure, it looks kinda janky, but the headlights still work. Unless NOT replacing can cause other problems, I'll just let it be for the time being. |
