02-06-2020, 09:42 AM | #23 |
Rep 1,827
The difference in unsprung weight with a smaller rotor probably isn't worth the increased likelihood of fade that will come from cooking your brakes on a circuit. The whole point of bigger brakes isn't to increase stopping power, it's to resist brake fade from overheating. Greater mass takes longer to heat up and larger surface area lets them cool faster.
Tenths or hundredths of a second saved from lighter rotors is completely moot if your brakes overheat and you can't finish the race. The biggest advantage of carbon ceramics is heat dissipation, not necessarily weight savings.
FalcoFury15.00 Onizukachan1086.00 |
02-08-2020, 02:25 PM | #24 | |||
Rep 205
Drives: 14 F30 335i xDrive
But on the track, small things make big differences. I've been tracking mine with the 340 brakes, and it's hard because it's not a big enough heat sink. Yes, lower unsprung mass does help the suspension and handling and should be done whenever possible, but the 340 isn't really sufficient for the weight of an f30 with really sticky track tires. I have custom brake scopes, Hawk DTC30 pads and factory style Brembo rotors with RBF 660 fluid and it's barely enough. If I had slicks it would overwhelm them with heat. I've just been running the 200tw tires for the time being. The F80 seems to be good with the 380 on street tires and even some on R comps depending on driving style and the track. But they're still struggling with slicks. Also I wouldn't run the drilled on track. My friends and I have seen those rotors crack. Heck, I had Stop Tech Cryo-Treated and slotted Sport Rotors crack after just a handful of track days. The riveted, plain Brembo rotors are holding up better. |
02-09-2020, 06:41 PM | #25 | |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
Anyone who thinks they see better performance in the rain from holes should stop driving in the creek and get back on the street. And yes, the holes make noise, they wear the pads down faster, they reduce the performance and heat sink of the rotor and are primarily cosmetic as far as street use is concerned. |
FalcoFury15.00 |
02-09-2020, 08:36 PM | #26 | ||
Rep 5,392
Outgassing was one reason to use drilled rotors way back in the 1980's because pad materials used then produced gases under heat and friction. The cross-drilled holes gave the gases a place to go to remove the negative effect on braking. Brake pad materials have been completely different now for a long time so outgassing is an outdated issue. I know for a fact that cross-drilled rotors have the best bite on the street in the rain because I've tested three different brake configurations on my F3x. When planning my current configuration, which has cross-drilled rotors front and back, I actually consulted with an expert who sells brakes to race teams for a living. He took me through the engineering to identify the best combination of street performance brake components for my car. Later the owner of a mod house drove my car and remarked that my brakes were better than his. And he's done several brake mods and tracks his car. |
FalcoFury15.00 |
02-09-2020, 08:46 PM | #27 | ||||
Rep 5,392
Should I get ceramic brakes?
FalcoFury15.00 |
02-11-2020, 10:38 AM | #28 | |
Big dumb dumb
Rep 60
Thanks so much to everyone in this topic. |
02-11-2020, 01:31 PM | #29 | ||
Rep 5,392
I'd suggest hanging out at the track and talking with guys on the forums who do the type of racing that interests you. |
FalcoFury15.00 |
02-12-2020, 02:29 PM | #31 |
Rep 5,392
Suggest going to the regional forum for your Florida area here on Bimmerpost and asking. Also search for FaceBook BMW groups in your area and you are bound to find track guys there.
FalcoFury15.00 |
