BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
      02-04-2020, 08:34 AM   #2795
OUGrad05
Drives: 2010 Corvette, 2015 335i
Originally Posted by thejeremyman9 View Post
Note, the peak is not on the "high end" (of the RPM range). So what you experienced is not contrary to that observation. The stock turbo generally just falls off up top (designed for low RPM spool and torque/responsiveness), and the tunes help a lot with trying to maintain that, to the extent possible with hardware limitations.
How just wait until you get a DP and go stage 2
Yes the peak gain is def in the midrange, but peak horsepower (as in the actual high HP at 6000rpm) feels like a bigger gain than 20hp. Loving this tune so far.
2015 335i M-Sport
2015 Lexus RX
2010 Corvette Grand Sport
      02-08-2020, 04:33 PM   #2796
codestar
Drives: 2014 435i xdrive
Dyno day with v7.0 (a test version from PTF to address throttle closure issues)
It was done in 3rd gear because the baseline in 4th gear took almost 20seconds
Run 1: stock map, 3rd gear, sport+
Run 2: v7.0 test map, 3rd gear, sport+
Run 3: v7.0 test map, 3rd gear, DSC off
A little bummed on HP but the torque looks and feels great
      02-09-2020, 11:54 AM   #2797
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
That's normal, you're xdrive so you'll be making 20-25whp less than RWD would.
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, GFB DV+, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3, xDelete
      02-09-2020, 12:08 PM   #2798
Gertsee
Gertsee's Avatar
Drives: BMW 435i
Really? I thought Xdrive had a small advantage in HP & Torque over RWD
      02-09-2020, 12:26 PM   #2799
designatedposter
Drives: m235i
@codestar do you have the datalog for these runs? Are you still actively working with ptf to revise the v7?
      02-09-2020, 12:32 PM   #2800
codestar
http://www.bootmod3.net/log?id=5e3f15ecc090c66606559325
From the second run
http://www.bootmod3.net/log?id=5e3f0364c090c66606559303
One I took on the way to the shop
I'm waiting to hear back from them still so I'm not sure what PTF has in mind
      02-09-2020, 01:25 PM   #2801
gbux
gbux's Avatar
Drives: 2014 435i
are you guyes having trouble connecting recently?
I took my tune off for my yearly inspection here in NYS a month and a half ago. i finally got my inspection and went to put my tune on but i cant get my laptop to connect to the car. Everytime i hook up i get
****** STARTING BOOTMOD3 OBD Agent on MAC
14:20:28.061 [main] INFO com.bootmod3.agent.Agent - Starting bootmod3 OBD Agent , please wait...
14:20:28.067 [pool-1-thread-1] INFO com.bootmod3.agent.e.J - Searching for ENET cable connection..
2020-02-09 14:20:29,051 INFO : *** OBD Agent Version: 0.10.092 started in 997ms.
2020-02-09 14:20:35,067 INFO : ENET cable connection to the vehicle detected.
2020-02-09 14:20:38,291 INFO : Vehicle not detected, takes 30-60secs after connecting cable. Is ENET cable securely plugged in? Is ignition on? If taking longer than usual remove the negative (ground, brown) wire from the battery in the trunk for 3 minutes and reconnect.
im in accessory mode/ ignition on. seatbelt is on. lights off heater off. doors closed. tried disconnecting the batterys negative terminal for 5 minutes. tried another laptop, both windows and mac. tried another cable. tried using compressed air in the obd2 port. I cant think what im doing wrong. was a bad update pushed maybe? am i forgetting something dumb? I miss my tune....! haha
      02-09-2020, 01:35 PM   #2802
Gertsee
Gertsee's Avatar
Drives: BMW 435i
Did you try deleting and redownloading the BM3 Agent?
      02-09-2020, 01:38 PM   #2803
gbux
gbux's Avatar
Drives: 2014 435i
i did delete and redownload on the windows machine. the mac that this error message was from was a fresh download. I did see this tho on their website.
Troubleshooting
*** I can't seem to connect with OBD agent on my laptop, says to check cable and reset battery but still no VIN detected. What do I do? ***
Ensure that you have no piggybacks activate such as a JB4, Dinan etc or exhaust valve controllers. Ensure your Firewall and Windows Defender are off and any anti-virus or network security software are off as they may block communication with the car. Last but not least, check your Ethernet IPV4 settings to ensure your IP address is set to Automatic (DHCP) instead of Manual.
i have a dinantronics sport chip thing under my hood. it never gave me an issue with tuning before, maybe thats new. https://www.dinancars.com/product/d4...6-n55-engines/
i cant imagine this is it since its a simple piggyback chip
      02-09-2020, 10:19 PM   #2804
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
No, you have drivetrain lost from the split power ratio between 4 wheels instead of 2.
2013 335i xDrive
      02-10-2020, 10:52 PM   #2805
F30328
Drives: Bmw F30 328xi
I have been with bootmod3 since October.
After finding out a new update for N20 EWG L-P was out I went to flash and found my OBD agent needed to be updated:
I updated my agent and now on bootmod3.net it says I don't have any registered vehicles.
I tried to plug in but the website won't lock in.
My phone still shows all of my information and maps.
I just want to flash the new update 😢
Any advice or anyone in Maryland with the WiFi agent?
15? 328xi Stage2
VRSF
      02-12-2020, 06:48 PM   #2806
aps
aps's Avatar
176
Drives: '13 F30 335i
Posted in the facebook group, but figured I'd post here as well:
First time data logging - can anyone take a look at these logs for me and let me know 1. did I even log right? 2. how do they look?
These were all done starting in 3rd gear between 2-2.5k RPM.
I have been having an issue where it feels like the car is hesitating or boost is breaking up for a split second, but only on partial throttle. Like 3rd-6th gear between 3k-5k there are multiple points where for a split second it feels like power drops for just a half second. I can’t really feel it at WOT, but not sure if it’s just because I’m powering thru to redline and it’s happening to quickly for me to notice.
Been tuned for 500 miles or so. Changed spark plugs to NGK 97506 gapped at .022 and that didn’t resolve anything.
Appreciate everyone’s help and insight!
Data Logs:
http://www.bootmod3.net/log?id=5e4492f2d10b4331b2058ae7
http://www.bootmod3.net/log?id=5e44921ad10b432feef14129
http://www.bootmod3.net/log?id=5e44907fae729b4664954da4
http://www.bootmod3.net/log?id=5e448f81d10b4331b2058ad9
http://www.bootmod3.net/log?id=5e448f64d10b4331b2058ad8
2013 335i (8AT, PWG) /// BM3 Stage 2, FBO: CTS Turbo FMIC, CTS Catless DP, ER CP /// Bilstein B14, OEM 437Ms
      02-13-2020, 07:48 AM   #2807
hybris
hybris's Avatar
Norway
170
Drives: BMW 330e F30 M-sport
I have been having an issue where it feels like the car is hesitating or boost is breaking up for a split second, but only on partial throttle. Like 3rd-6th gear between 3k-5k there are multiple points where for a split second it feels like power drops for just a half second. I canít really feel it at WOT, but not sure if itís just because Iím powering thru to redline and itís happening to quickly for me to notice.
Been tuned for 500 miles or so. Changed spark plugs to NGK 97506 gapped at .022 and that didnít resolve anything.
Appreciate everyoneís help and insight!
Data Logs:
So you need to floor it when you log, start in 2nd and floor it through as many gears as you have room for without killing yourself or anyone else.
Log 1 and 3 you're not doing that.
Log 2 and 4 and 5 have at least one gear where you're flooring it, and I'm no expert, but your timing does not look very good. Not sure if that's how it looks if you're on an ACN map and you have crap fuel.. Perhaps go down to a stage 1 map and log again.
Thorbjorn
16 BMW F30 330e M-sport
Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs
aps176.00
      02-13-2020, 07:54 AM   #2808
JaredG_F30
JaredG_F30's Avatar
985
Drives: 2014 335i, M-Sport, Manual
So I just looked at your second log and these are my observations
You have a knock at 4220 RPM
Ignition timing is all over the place but this is probably due to shitty CA gas
You are over boosting until about 4900 RPM then boost drops below target to redline
Your HPFP takes a dive starting at about 3500 RPM and doesn't recover until after 5,000 RPM (this is the hesitation you are feeling from 3-5k)
You are PWG right? Did PTF release a map revision recently for PWG?
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
aps176.00
      02-13-2020, 07:56 AM   #2809
JaredG_F30
JaredG_F30's Avatar
985
Is this on stage 2 93 octane map?
      02-13-2020, 08:50 AM   #2810
codestar
St2 91 test 1. I was given test 2 since then but haven't had an opportunity to take a log for it yet
      02-13-2020, 09:15 AM   #2811
aps
aps's Avatar
176
Thank you both!
Yeah I am in LA and it's all crap gas, but I do only fill at Shell or Chevron what actions do I take to go about correcting the timing?
And yep - PWG, I haven't seen a revision to the ACN map for a while. When I flashed for the first time in January, the map date says its from like October of 2018. V7.1.
Its interesting that the log shows the HPFP basically dipping all the way from 3500 to 5000 rather than the little blips that I feel on partial throttle in that range. Could the blips of hesitation (at partial throttle) be a result of throttle closure as the car reacts to the HPFP basically not keeping up? Or am I totally misunderstanding what's happening there?
      02-13-2020, 11:44 AM   #2812
thejeremyman9
Drives: 2015 BMW 335i
Thank you both!
I recommend costco gas in CA. I have the best timing on that with MHD 2+ tune. I pretty much exclusively go to Costco unless i absolutely need to get gas somewhere else.
I would also consider looking into mixing ethanol. Check out the Pearson fuels app. There are numerous stations in the area - I am around Irvine and there is one right around the corner from where i live.
aps176.00
      02-19-2020, 07:44 PM   #2813
BuefordTjustice
Drives: '16 435 Gran Coupe xdrive
can someone tell me how this log looks? IMO it looks good and steady but I just started looking at these today. I started low in 3rd gear and punched it til redline and shifted into 4th
http://www.bootmod3.net/log?id=5e4ddd75d10b4335623d9160
      02-20-2020, 11:07 AM   #2814
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
I recommend sending to PTF direct
      02-22-2020, 07:47 AM   #2815
Halim@HCP
Halim@HCP's Avatar
Denmark
541
Drives: BMW F80 M3 / M6 F13
New update is out!
https://f30.bimmerpost.com/forums/sh...&postcount=132
      02-22-2020, 07:52 AM   #2816
romemedrano
Drives: BMW F30
Originally Posted by Halim@HCP View Post
Thanks for giving us an update! I probably won't have time to test this out gotta prep for track weekend next week! If Phantom10R and JaredG_F30 says it's good I'll flash it on track and do a few sessions on it!
