BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Went with ESR wheels because VMR was sold out
      02-27-2019, 09:39 AM   #1
Hudsonvalley435
2015 435i xdrive- 6spd, cp, dp, fmic, bm3 stage 2
Drives: F32 435i X
So VMR was sold out of pretty much every wheel I liked. A dealer suggested ESR RF2's since I like the rotary forged process over the completely cast process and they had the style I wanted. So I gave them a try and I'm happy I did. First of all, I saved about $250 over VMR, the finish is gorgeous and they're rotary forged for strength and weight saving. The only issue is very minor, my previous bmw center caps don't fit so now I've got to find some random size caps or just put stickers on the ESR caps.
Anyone else have these wheels, or the RF1's? Any experience with them, good or bad? Any luck finding bmw caps that fit well?
      02-27-2019, 10:16 AM   #2
GatorF30
Drives: EBII F30
ESRs are nice. I have them on my E39 M5.
      02-27-2019, 11:26 AM   #3
Mr. Tasty
Mr. Tasty's Avatar
428
Drives: AW 335i Mperformance
i have the esr rf2 on my car. i love my setup and it is the perfect fitment in my opinion.
19x8.5, 245/35/19 and 19x9.5, 265/35/19
each wheel is around 24.0 lbs
the images attached are for the fronts, both oem and then the esr.
I lost about 8 lbs per front and 9 lbs per rear. total loss of about 44 lbs unsprung mass, while going 20 mm wider tire in the front, and 10mm wider tire in the rear.
[IMG]undefined[/IMG]
Rathian153.50
Diegs1422.00
      02-27-2019, 11:51 AM   #4
Hudsonvalley435
Drives: F32 435i X
That weight savings is incredible. It's hard to find real world weight numbers on the RF series. But it sounds like they're a solid build.
      02-27-2019, 11:53 AM   #5
Mr. Tasty
Mr. Tasty's Avatar
428
sorry i weighed them individually. both fronts and rears weigh 24.0 lbs
      02-27-2019, 12:11 PM   #6
_bdiddyb_
Drives: 2013 335i
Love me some 2" deep dish. I get more complements in these than my more expensive Concept One.
      02-27-2019, 12:15 PM   #7
Mkswoosh
Mkswoosh's Avatar
93
Drives: 2018 340xi tanzanite blue
each wheel is around 25 lbs
Probably saved more weight just the tires itself? Since run flats usually weigh more
      02-27-2019, 12:53 PM   #8
Mr. Tasty
Mr. Tasty's Avatar
428
the oem 403m wheels are around 29-30 lbs each.
modern runflats arent too much heavier than non run flats
      02-27-2019, 10:00 PM   #9
f32ftw
f32ftw's Avatar
Drives: BMW 435 xdrive
I got the 18 inch ESR RF2's a few months ago. I lost a few tires last winter due to potholes with the stock 19's and runflat Pirellis so I switched to 18's and Michelin Pilot Sport AS3+.
otay826.00
Rathian153.50
      03-13-2019, 08:06 PM   #10
ArcTurnsSaveLives
2014 Estoril Blue F31 M-Sport
Drives: '14 Estoril F31 MSport
Ditto
I’m literally in the same boat because the VMR’s I wanted (19” 810s FF) are gone till mid June. Are you guys running the fronts with et30? Or something else I missed in my research? Ideally I want the 19x8.5 squared with 255/35, but I’m worried about the et30 in the front being too much poke for the fenders and beefy tires. The pics look great but you can only tell so much...
Wai328135.50
      03-14-2019, 02:07 PM   #11
Hudsonvalley435
Drives: F32 435i X
19x8.5 et 30 front
19x9.5 et 35 rear.
I could have gone with the et 45 in rear for a more square look but et 35 gives it just a slight staggered look. Et 30 in front looks perfect.
      03-14-2019, 02:23 PM   #12
Mkswoosh
Mkswoosh's Avatar
93
19x8.5 et 30 front
19x9.5 et 35 rear.
What tires specs you running. Hoping a 40 would fit fine without stretch
      04-12-2019, 07:04 PM   #13
turbosocal
turbosocal's Avatar
42
Drives: M3
Love my RF2s too! I also wonder where to get some center caps that will fit---anyone know?
      04-13-2019, 12:31 PM   #14
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
19x8.5 et 30 front
19x9.5 et 35 rear.
ET 35.. does the rear poke out.... can you post a photo and what tire size you running?
I'm contemplating getting this setup for my GC.
      04-14-2019, 03:03 PM   #15
marseg13
Drives: bmw 435i
lug holes are bigger than the lugs
hello everyone,
i have a dilemma. i bought esr RF2 5x120 size 19x8.5 and 19x9.5 online. they called me back saying that they ran out of stock of the 8.5(even though it did not specify online) and gave me another option of redrilling the 5x114.3. when i got it, i thought everything was fine cuz i gave specific specs of what i need. so i went to a tire shop to mount it cuz i thought everything was fine. when they put the tire on and mounting it to the car, they notice that the lug holes is bigger than the original from the oem rims. they told me that it is dangerous because the lugs can loosen while driving. is there a solution for this??
      04-14-2019, 03:05 PM   #16
marseg13
Drives: bmw 435i
hello everyone,
      04-14-2019, 03:15 PM   #17
SoCal_NSX
SoCal_NSX's Avatar
2400
Drives: 981CS/428/is250/JLU Rubicon
Originally Posted by marseg13 View Post
hello everyone,
Send them back asap....sounds like they fucked up
      04-15-2019, 08:23 AM   #18
Korvo
Respect My Authoritah
Korvo's Avatar
Drives: 2014 335i M-Sport
hello everyone,
Janky award of the year goes to wherever you bought them from.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
      08-04-2020, 07:25 PM   #19
Hardstyle
Drives: Bmw 328i
Are those esr matte black?
      09-20-2020, 12:42 PM   #20
obzen
obzen's Avatar
Drives: 2017 BMW 440i Gran Coupe
Originally Posted by Hudsonvalley435 View Post
19x8.5 et 30 front
19x9.5 et 35 rear.
What profile tire are you running on the ET30 upfront ? I have similar setup and wonder if I can squeeze in a 40sidewall without rub on stock m susp, instead of the 35 currently
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips
//Apex ARC8 255/40/18
//MST intake
//AutoTechnik brace
bmw 435i, esr rf2, esr wheels, motofilms, vmr wheels
