08-15-2017, 08:55 PM | #23 |
projecttechnik.com
108
Rep 215
I tried this and it didn't seem to work for me, I could not activate the rear and top view cameras at speed, here is what I have.
From the sounds of it D_SCHWELLE_1 and 2 need to be set to wert_02 or is it wert_03? REM > 3203 > PdcParkMasterVar > V_OFF_PF_R > UNKNOWN / Werte = FF REM > 3203 > PdcParkMasterVar > V_SCHWELLE_1 > UNKNOWN / Werte = FF REM > 3203 > PdcParkMasterVar > V_SCHWELLE_2 > UNKNOWN / Werte = FF REM > 3203 > PdcParkMasterVar > D_SCHWELLE_1 > wert_03 / Werte = 00 REM > 3203 > PdcParkMasterVar > D_SCHWELLE_2 > UNKNOWN / Werte = FF REM > 3201 > ? > CUT_OFF_SPEED > Werte = FF TRSVC > 3000 > SV_Activate_Speed_Limit > UNKNOWN / Werte = 00 TRSVC > 3000 > SV_Deactivate_Speed > UNKNOWN / Werte = 00
08-16-2017, 09:41 AM | #24 | |
Rep 114
You it must set to wert_03 for that you must choose it in the drop-down list not typing it |
08-16-2017, 02:42 PM | #25 | |
projecttechnik.com
108
Rep 215
Any ideas?
08-16-2017, 02:57 PM | #26 | |
Rep 8,364
08-16-2017, 03:05 PM | #27 |
projecttechnik.com
108
Rep 215
I should have clarified, the values don't stay when I "code FDL". I apply the changes then back out of the CAFD and "code FDL". When I go back into the CAFD the changes did not stick and it will be either wert_03 / werte=00 or wert_00 / werte=FF.
08-16-2017, 03:11 PM | #28 | |
Rep 8,364
The only ways coding does not stick are the following:
08-16-2017, 03:40 PM | #29 | |
projecttechnik.com
108
Rep 215
Here is my order of operations; -select wert_03 from dropdown - click save icon at top -edit werte from 00 to FF - click apply then click save icon at top -back out of CAFD by clicking on the green arrow up top -code FDL -read coding data on REM then go back into the CAFD to confirm changes I've even did the "save and code FDL" process after selecting werte_03 then went to update the wert to FF then did the "apply, save, and code FDL" process after and it still didn't save. Perhaps I will have to try wert_02 and see what happens.
08-16-2017, 04:55 PM | #30 | |
Rep 8,364
08-17-2017, 12:07 AM | #31 |
projecttechnik.com
108
Rep 215
I was able to get this to work on my car tonight (finally). Basically whatever I updated in REM I also updated in PMA since I have Park Assistant, I used werte=FF. Interestingly, immediately after I coded it, it did not start working. After the car sat for a little bit, it started to work on the next start up. Only downside is that I have to manually turn off the rear cam/top view after reversing so now biggie.
Below is what I have now; REM > PdcParkMasterVar > V_OFF_PF_R > Werte = FF REM > PdcParkMasterVar > V_SCHWELLE_1 > Werte = FF REM > PdcParkMasterVar > V_SCHWELLE_2 > Werte = FF REM > PdcParkMasterVar > D_SCHWELLE_1 > Werte = FF REM > PdcParkMasterVar > D_SCHWELLE_2 > Werte = FF REM > CUT_OFF_SPEED > Werte = FF PMA > PdcParkMasterVar > V_OFF_PF_R > Werte = FF PMA > PdcParkMasterVar > V_SCHWELLE_1 > Werte = FF PMA > PdcParkMasterVar > V_SCHWELLE_2 > Werte = FF PMA > PdcParkMasterVar > D_SCHWELLE_1 > Werte = FF PMA > PdcParkMasterVar > D_SCHWELLE_2 > Werte = FF PMA > CUT_OFF_SPEED > Werte = FF TRSVC > SV_Activate_Speed_Limit > Werte = 00 TRSVC > SV_Deactivate_Speed > Werte = 00 Thanks all for the help, greatly appreciated.
08-17-2017, 12:48 AM | #32 | |
Rep 8,364
08-17-2017, 01:13 AM | #33 | ||
projecttechnik.com
108
Rep 215
Almaretto2374.00 |
08-17-2017, 10:01 AM | #34 |
Rep 8,364
You could also raise distance/speed cutoff without maximizing it so that you can still use for a longer period and it will still auto-turnoff.
08-21-2017, 08:34 PM | #35 |
Rep 109
08-21-2017, 08:51 PM | #36 |
Rep 8,364
08-21-2017, 09:34 PM | #37 |
Rep 16,079
08-21-2017, 11:53 PM | #38 |
Rep 8,364
08-22-2017, 05:13 PM | #39 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I use it to monitor the hitch and load on my trailer on my X3.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
Almaretto2374.00 |
09-05-2017, 01:07 AM | #40 |
Rep 1
Should go to a camera store just to check what i can improvise. Cheap cameras will do I think.
09-05-2017, 09:12 AM | #41 | |
Rep 8,364
09-05-2017, 06:32 PM | #42 |
Rep 193
07-16-2018, 11:11 PM | #43 | |
Rep 455
I'm having a helluva time trying to find... CUT_OFF_SPEED > What app are you using? I'm using bimmercode, found everything else but above. |
07-17-2018, 12:29 AM | #44 |
Rep 8,364
