07-02-2018, 06:42 PM | #67 | |
Joint Chiefer
38
Rep 108
07-06-2018, 10:33 AM | #68 |
Rep 80
I have been bit by stone damage to the condenser too.
I consider the grill design to be deficient with clear openings over 0.9 inch that allows a sizable object to hit the condenser. For BMW to now fit a rock guards installed (since 11/17) is not an upgrade but a fix. I installed an expanded metal aluminum screen in front of the truss bars that are behind the grill. |
07-08-2018, 11:07 AM | #69 | |
Rep 4,877
It's not a warranty issue either. It's damage caused by a road hazard. A lot of vehicles have open inlets for the rads, not just BMW. If the dealership does a good will and fixes it for the OP, that's great, but that shouldn't be expected. |
09-04-2018, 05:04 PM | #71 |
Rep 499
Here's what I would do:
1 -- I personally would just pay out of pocket to be assured that your insurance premiums stay low. 2 -- To make sure this does NOT happen again, you will need to install a grille. Otherwise you're just rolling the dice -- because obviously there's nothing to prevent a rock from re-breaking the radiator. 3 -- If you're going to go to through the massive pain-in-the-ass-trouble to put grilles in, you might consider just doing the repair yourself. If it's the auxiliary radiator that broke, you're going to be RIGHT THERE. I wish I had known this before I put the grilles in -- would have replaced the lower radiator myself. Once you have the front bumper off it looks exceptionally easy. The only part I personally would have had to research is how to bleed the cooling system properly. And for what is is worth, I could tell the BMW tech didn't take the front bumper off. They accessed the auxiliary radiator via the passenger wheel well (either by removing the plastic fender liner or pushing it out of the way). So to just remove and replace the auxiliary radiator is not that difficult. Last edited by natesi; 09-04-2018 at 05:15 PM.. |
09-04-2018, 05:18 PM | #72 |
Rep 16,082
09-04-2018, 05:26 PM | #73 |
Rep 499
The new stone shields only protect the middle area of the car though -- won't do anything for the auxiliary radiator (if you have one), which is wide-freaking-open. This is a shit-design -- it's reasonably foreseeable that, if you do enough freeway travel, it's just a matter of time before a big rock punctures the auxiliary radiator. I don't know how they could have been this dumb -- seems low effort, careless, and defies common sense.
09-04-2018, 10:00 PM | #74 | |
Rep 148
1. Point out the addition of the rock guards to the radiator in 12/2017. 2. Request dealer contact regional and ask for "goodwill repair". 3. If they decline goodwill, call and open a case with BMWNA and explain situation and request goodwill repair. You have nothing to lose by taking these steps. As shown by the multiple threads on this, it is a significant issue that they are clearly aware of. If you don't make the request no chance of getting repairs covered. |
12-19-2018, 09:21 AM | #75 |
Rep 134
Reviving this thread as I am going thru this now with my 17’ 440i. I wouldn’t expect there to be a recall as it’s not a safety issue per se, but it seems pretty sad that BMW would look the customer in the face and act like they don’t know that this is a known issue.
I’ve taken the above advice. Hoping for a favorable outcome. Thanks to all for sharing their experience. |
12-19-2018, 12:03 PM | #76 | |
Rep 14,115
Drives: G82 M4C X-Drive
All in all, I had it MUCH worse. Not only was the oil cooler destroyed, but my transmission oil cooler, some radiators, steering rack, front bumper, both headlights, M Performance Exhaust, and my rear differential. My M3 was in the shop for a month and a half. Total cost of repair: $36,000. Here's just a taste of what this rock did: More in my thread: https://f80.bimmerpost.com/forums/sh....php?t=1550991 Good luck everyone! And no, there is no recall, the best you can do is get an oil cooler shield or don't run over any rocks!
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
cfm56d7b5886.00 |
12-19-2018, 12:30 PM | #77 | ||
Rep 3,680
12-19-2018, 12:49 PM | #78 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Maybe a DIY fix. Dirt track cars use Nomex honeycomb sheets to protect radiators etc. You can cut them with a knife, razor, shears etc. The sheets are cheap about $20 from Speedway Motors. They are an ugly brown color but some barbecue high temp spray paint will cover them up.
Trial Fit A bit more trimming Done. About a half hour not including waiting for the paint to dry.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 12-19-2018 at 12:59 PM.. |
04-01-2019, 08:25 PM | #79 |
Rep 1,103
add me to.the list.
didn't have my car 1 day even and had a piece of metal go through bumper and damage radiator. $2600.... Have a case opened with BMW North America to get some help on that hopefully and the guards installed.. My 2018 F36 is a 12/17 production date so I must've just missed having the guards! |
04-01-2019, 08:26 PM | #80 |
Rep 1,103
add me to.the list.
didn't have my car 1 day even and had a piece of metal go through bumper and damage radiator. $2600.... Have a case opened with BMW North America to get some help on that hopefully and the guards installed.. My 2018 F36 is a 12/17 production date so I must've just missed having the guards! Edit: I was mistake. Car is a 9/17 production. Apparently radiator that accommodates guards changed in 8/17 but new mounts and guards weren't added until 12/20/17. Would like to get guards added while car is already torn down. but I need it back asap and unlikely BMW would approve that quickly. |
04-10-2019, 07:30 PM | #81 |
Rep 499
Just an update: The mesh screen I installed continues to pay dividends regularly.
https://f30.bimmerpost.com/forums/sh...8&postcount=64 This example was just one trip down to my friend's house, and back -- couple hours each way. It's the best bang-for-the-buck mod I've ever done -- and only cost about $8. It gives me piece of mind knowing I won't be on the freeway again, and stranded, due to a punctured radiator or auxiliary cooler. |
gfa325.50 |
