03-31-2018, 07:07 AM | #1 |
Rep 1,487
19” 437m wheels
Hi all
I have my eye on a set of 437m alloys off an m4 i think but the tyres on them are 9J x 255/35/19 and 10J x 275/35/19 Will these fit on a f30 with standard m sport suspension? Last edited by Panchoa; 03-31-2018 at 07:38 AM.. |
03-31-2018, 07:14 AM | #2 |
Rep 32,881
There was a thread about this recently:
OEM F8x 437m or 513m - Any UK members running these? https://f30.bimmerpost.com/forums/sh....php?t=1464167 |
03-31-2018, 07:37 AM | #3 |
Rep 1,487
Cheers buddy although no-one there running the original M4 tyres sizes which is what im interested in as i cant be bothered with having to buy new tyres.....
03-31-2018, 08:58 AM | #4 |
Rep 2,598
They will “fit” without rubbing with OEM F80 tyre sizes if your car is RWD. If it’s x-Drive then no as the rolling circumference will be wrong.
HOWEVER the poke would look ridiculous with stock ride height. Even worse if it’s an x-Drive (ignoring the tyre issue already covered) I have 245/35 & 265/35 (OEM M2 spec) on a RWD car lowered on H&R’s with zero rubbing issues. |
03-31-2018, 09:22 AM | #5 | |
Rep 1,487
03-31-2018, 10:10 AM | #9 |
Rep 1,487
Thanks for the input, ive already looked at ghe other thread - nothing clear on their on whether anyone is running the M4 tyre sizes!
03-31-2018, 10:17 AM | #10 | |
Rep 2,598
If you want to fit OEM 437m you have to be prepared to invest in lowering the car (to introduce a sensible level of camber) to bring the wheel under the arch & also you need to fit the correct tyres for your application! If you really lowered the car on coilovers I do think you could do 255/35 & 275/35 if you wanted. What is the rationale for not wanting to use different sized tyres?! |
03-31-2018, 10:33 AM | #11 |
Rep 1,487
Ok mate. Thanks. Just cant be arsed to buy new tyres as the set comes with the standard tyre sizes included. Buying new tyres will bump up the cost way past what i would want to spend
Oh well never mind |
03-31-2018, 11:09 AM | #15 |
Rep 32,881
03-31-2018, 11:58 AM | #17 |
Rep 2,598
04-01-2018, 05:04 AM | #21 |
Rep 2,598
04-01-2018, 05:50 AM | #22 |
Rep 637
Yes. Like a bit of an aggressive look. The 245 / 265 being less wide will reduce some tramline. So better combination.
