08-09-2018, 03:48 PM | #1 |
Rep 160
Surely someone else has run into this issue(rear rotor size)
2014 328d XDrive Wagon.
I'm having a hell of a time (so is Powerstop apparently) finding the correct rear rotor for this car. The 1st set of 300x20 rear rotors I was sent match in every way except they won't fit over the parking brake shoes. Looks like I need a 185mm hub diameter, not the 165mm hub diameter I was sent. This is a bone-stock car, but it does have the M-package. I don't know it's the "M" that's causing the issue, or if it's because it's a wagon, but these rear rotors seem to be confusing. The 320mmX20mm rotors on the car are not Msport or Mperformance, just the basic rear rotors. Has anyone been thru this w/ their F31 Xdrive wagon and have some guidance to offer? Thanks Last edited by opinion914; 08-09-2018 at 04:07 PM.. |
08-09-2018, 05:25 PM | #2 |
Rep 15,966
M has a larger rotor than base. Use this to find the exact size:
https://www.realoem.com/bmw/enUS/select |
08-09-2018, 06:27 PM | #3 | |
Rep 3,533
opinion914, Sounds like you were given rotors for a 320/28i RWD model. Those had a smaller rear hub than the 320/28i xDrives. You need an AWD/xDrive rear rotor. |
08-10-2018, 06:04 AM | #4 |
Rep 160
Thanks guys. The overall diameter is definately nothing unusual, simple 300mm base diameter. The drum brake hub is too small. Need 185mm as opposed to the 165mm I received.
I think you may be on to something Farkle. Fingers crossed PowerStop agrees. Kevin |
09-10-2018, 07:37 PM | #5 |
Rep 43
I have this problem 2013 328 m sport. I went on rockauto ordered the supposedly correct rear rotors paid to put then on then find it doesn't fit my parking brake! WTF! I've Been driving around for over a month now without parking brake. So I went on realoem.com found what part numbers I needed and ordered front and rear rotors Zimmerman from eBay. Also got my pads from amazon
330 mm brake rotors front 34116792221 300 mm rear 34216792227 |
09-12-2018, 10:53 AM | #7 |
Rep 10,232
09-27-2018, 12:47 PM | #8 |
Rep 160
Turns out I was shipped the incorrect rotors. If I went the OEM route I'd definitely use the stamped numbers. I went aftermarket though and it took some back and forth to get the correct set.
10-05-2018, 03:35 AM | #9 |
Rep 192
The rotors you were given are for an F20. Everything is the same except the hub diameter because the parking brake is smaller on the 1 and 2 series.
