05-05-2024, 01:56 AM | #1 |
Rep 2
BMW 316i 2014 f30 door issue
Hey everyone, the driver side door in my car listed in the title won’t unlock with the key button, it will only open manually, all the other doors work perfectly when I use the key to unlock them. Has anyone got a fix for this?
05-07-2024, 07:04 PM | #2 |
Rep 311
Drives: 2014 335i 6MT MSport
Dead door lock actuator?
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
05-14-2024, 04:44 PM | #4 |
Rep 3
Hi, I did replaced my door lock actuator for my passenger side once. You can able to DIY. It’s straight forward process. Just get the correct part number then I believe you need to take off the door panel from inside then remove the original one then replace with new one.
Highly recommend you to check some other folks video before you take off your door panel since the door panel are attached to couple of wires so be careful and hope you able to get it fixed. |
