08-17-2020, 02:13 PM | #15511 |
Rep 40,939
If this is factory fitted hardware, just return FA to original state, and VO Code Head Unit.
08-17-2020, 03:14 PM | #15512 |
Rep 6
Unfortunately its not. The HU_EntryNav has been replaced with HU_NBT2 and the screen with an 8.8in touch screen, so I think I will probably have to redo from scratch then. Damn LOL
08-17-2020, 03:16 PM | #15513 | |
Rep 40,939
CID_APIX_MODE CID_COLOR_DEPTH CID_COM_MODE CID_RESOLUTION
08-20-2020, 09:00 PM | #15515 |
Rep 40,939
PM sent.
08-23-2020, 09:06 AM | #15516 | ||
Rep 7
08-23-2020, 09:33 AM | #15517 | |
Rep 40,939
E-Sys - Getting Started Coding v.2.pdf: https://mega.nz/#!VswHmAJZ!MA1Fh4I2_...DDpLbtcV19BEy0
08-23-2020, 06:21 PM | #15519 |
Rep 40,939
No, I don't have Coding List. Coding is ECU specific, not Chasis specific, and Cheat Codes are builtin to E-Sys Launcher or E-SysX.
08-24-2020, 10:00 AM | #15520 |
Rep 10
08-24-2020, 02:41 PM | #15521 |
Rep 127
Shawn,
I've done some coding work on GM LS1 ECMs, but I'm new to BMW ECUs. I'm looking at this cable (https://www.amazon.com/dp/B07BH3PTGK), which comes with the software and data files, along with links to both. Does anyone know if this is a good cable? Is there a better cable I should be looking for? Has anyone tested this on a 4-series (2017 F33)? I'm guessing it will work, as the 4-series is quite close to the 3-series, and probably uses many (all?) of the same ECUs. Please PM links for current software & data files. If I change cables, most don't come with the software. I've got an old/retired laptop with an ethernet port (Intel NIC) that I'll be using, unless a USB network adapter can be used. My understanding is that Win-7 is a better choice than Win-10. What's the current philosophy WRT 32-bit vs. 64-bit OS? I'm thinking that the software is compiled into 32-bit, but that should work just fine on a 64-bit OS. Of course, the hardware can run either. I need to get some familiarity with the interface, then code for my new brakes (https://f30.bimmerpost.com/forums/sh...4&postcount=12). Thank you for your time. |
08-24-2020, 02:46 PM | #15522 | |
Rep 40,939
USB x LAN Adapter works fine with Cable. Win7/10, 32/64-Bit makes no difference.
SD Convert65.00 |
08-26-2020, 10:51 AM | #15524 |
Rep 40,939
PM sent.
08-29-2020, 01:28 PM | #15526 |
ex deus machina
124
Rep 968
Hi Shawn,
Could you please PM link to the latest PSdZdata? your previous PM (a year ago) for v.4.16.10_PSdZData_Lite no longer works do you still have it? i have an older e-sys luancher 2.8.2, dont know if the new PSDZData will work thank you
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
08-29-2020, 01:54 PM | #15527 | |
Rep 40,939
08-30-2020, 01:31 PM | #15529 |
Rep 40,939
PM sent.
08-31-2020, 02:03 PM | #15530 |
Rep 135
Hi Shawn, Thanks for continuing to support this community with our coding efforts Be grateful if you could send me the latest links please.
Past Previous: E92 335i, CIC retrofit, JB+, Perf Exhaust Last Car: MB ML350CDI, X800D-ML Retrofit, AMG Steering wheel, Brabus tuning box Current car: F31 335d - NBT EVO ID6 retrofit, 3AG retrofit, Coded EBT, Deleted RFTs!! |
08-31-2020, 02:06 PM | #15531 |
Rep 40,939
PM sent.
09-01-2020, 01:54 AM | #15532 |
Rep 3
Hello.
I am trying to code a 6WA cluster on my F31, and I have tried with different versions of E-Sys and I always have the same problem, the KIS/SVT section is disabled and I-step is not available. I have full psdzdata but apparently not compatible with E-sys. Where can I find E-sys 3.22.5 and compatible full psdzdata? |
