BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Stock F30 335i Axle Back Exhaust Muffler Modification and Dissection
      02-11-2019, 06:09 PM   #199
N26Ghost
N26Ghost's Avatar
Drives: 2014 BMW 328i M Sport
Originally Posted by TurboM View Post
I just cut it open today and applied about 5oz of JB weld across all of the holes. Pretty sure I got them all but it was a bit hard to see all of the ones on the bottom half. Not really sure what to do about the packing material though. I guess the 3 options are:
- put it back in chambers 1 and 3, or
- put it in the center chamber
- throw it in the trash
Any thoughts?
I'm having a local welder close it up tomorrow afternoon as the JB weld needs about 24hrs to fully cure. Based on the pictures I sent him he's pretty convinced the canister is stainless steel.
Did you close up all of the holes in all of the chambers? Or just chamber 2?
Also, what material did the welder use to close up the opening?
'14 F30 328i M Sport // FBO // bm3 Stage 1 DME 91 OCT // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
      04-09-2019, 11:51 PM   #200
TwistedX
Really Twisted
Drives: 2015 M235i F23 8AT
Have we confirmed: outside/case is stainless steel and interior tubing is regular steel?
2015 BMW M235i F23 - VRSF FBO, AEM Intake, AR Designs Catted, Air Lift 3p Suspension, MHD stage 2+, XHP stage 4
      04-10-2019, 11:51 AM   #201
MineralF30
Drives: '15 F30 335i 6MT M-Sport
I did this on my car a few weeks ago. To answer your question, outside casing is stainless steel, inside is regular steel.
Big Boost 6159, MHD + Motiv E85 Custom Tune, 6MT, FBO, PR Coils, MMP Port Injection, AFE Intake.
      07-27-2019, 02:08 PM   #202
thejeremyman9
Drives: 2015 BMW 335i
Bumping a older thread here; wondering if anyone has used exhaust wrap instead of spot welding all of the holes closed? I saw one post mention using wrap but no confirmation.
https://www.amazon.com/Design-Engine...03913138&psc=1
What i am thinking is using something like the above to wrap around the portions of tubing in chambers 1 and 3 that have holes in them, then using saftey wire/metal zip ties to secure the wrap snugly in place before sealing the muffler back up. I see two main advantages to this approach: (1) Its reversible incase the sound is undesireable and (2) you can cover the holes on the bottom of the muffler without cutting open both sides. I imagine there is not that much back pressure so the exhaust wrap should be able to "seal" over the holes reliably?
Any input is apprecaited.
(Side note just wanted to confirm the muffers are the same as the OP on a 2015 335i EWG car?)
      07-27-2019, 02:13 PM   #203
Jadar
Jadar's Avatar
Serbia
1620
Drives: 2013 F30 335i MSport
https://www.amazon.com/Design-Engine...3138&psc=1
Yeah I don't see why the wrap wouldn't work and it sure makes things easier. Some people mentioned they were going to try JB WELD but no one has reported back yet.
Yes the mufflers are the same. Only difference on the 35i mufflers was if it's a 235i or a 335/435 they had different mounting points is all. The 235i has a slightly different curved 3" exhaust path, I'm assuming due to shorter wheel base.
I've been out of my F30 for quite some time now it's always nice to see sown of these old threads come back from the dead .
FBO-PS1 and stuff
      07-27-2019, 09:02 PM   #204
e46m3to335i
e46m3to335i's Avatar
Drives: 2014 335i xDrive
I did the PE mod a couple months ago. Used wrap on one of the sections and covered the Y section in JB Weld. Also sealed the muffler back up with JB Weld. It's been solid and I'm confident it will hold fine for quite a while. Can post pics when I get some time.
Jadar1619.50
