BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
proTUNING Freaks
      08-20-2018, 08:22 AM   #2267
Fantastic4
Drives: 2014 435i f33
Hey everyone, I've been following this thread for a while now and I appreciate everyone's input on the different issues. I'm getting ready to jump on the mhd train soon, just been waiting to have all my bolt ons installed. I'm missing one piece of the puzzle so I'm looking for advice from the thread. I'm looking at the vrsf fmic's and noticed they have two for the 435i. For stage 2 setup, will the street be sufficient? I'm not looking to track the car, just some street fun. The street version is what's within my budget $379 but if I need to hold off and save for the race vrsf then I can do that. So what are your thoughts? Am I going to be fine with just street fmic? It doesn't have to be vrsf brand, that's just what I've been looking at.
Also which spark plugs do you guys recommend for a stage 2 tune?
Other mods:
CTS turbo intake
Vrsf catless downpipe
Vrsf charge pipe
Active Autowerks exhaust with resonator delete
Thanks everyone
Alex
      08-20-2018, 12:15 PM   #2268
enemigo13
Drives: F30 340xi
MHD this was limiter you were fighting with? (coolant temp vs rpm). attaching screenshot, on some EWG versions its not 9000rpm all table flat, but ends with 5500rpm xdf is from n54tech.com.
      08-20-2018, 12:50 PM   #2269
cxp213
cxp213's Avatar
297
Drives: M235i
When are we going to get updates on the N55 maps? Seems like it's always on the back burner and update schedules are missed.
      08-20-2018, 01:24 PM   #2270
GatorF30
Drives: EBII F30
The maps run pretty well as it is. They just rolled out with Precision Raceworks coil integration for the N55. More adjustments are coming soon, including an OTS map for Pure Stage 2 upgrade.
      08-21-2018, 06:59 AM   #2271
Momir@MHD
MHD Tuning
Momir@MHD's Avatar
Drives: BMW 1M Coupé
Originally Posted by ChrisFulton View Post
Bought the Bimmer Geeks cable when I bought the flash tune.
I was skeptical that the cable would make that much of a difference; but maybe it does.
The BimmerGeeks Cable flashes twice as fast as standard cables, so yes the flash times will be half.
Yes, but solved this problem months ago.
Other mods:
CTS turbo intake
Vrsf charge pipe
Thanks everyone
Alex
Get yourself the VRSF Race Intercooler and use the OEM spark plugs (we even run them at 23PSI without issues)
EWG Maps (you run a M235I) are pretty good and nearly maxed out, we want to keep a bit of room because the stock fuel system is nearly at its limit. OTS maps must run on cars all around the world in all conditions without having any issues. We will release a updated version soon, but don't expect a big bump in power since power is limited by the stock fuel system and the fuel you are using.
Originally Posted by Bimmertodd88 View Post
Getting tired of this 3rd and 6th gear torque limiter. Does MHD have a answer for this. Right now I'm bootmod3.
We have a solution that we will integrate in the app as a flash option, send me a PM so we can help you quickly.
Originally Posted by FastF30 View Post
make sure your on 10amp quick charge and not trickle charge.... and one thing I did that is not mentioned anywhere on MHD installs but is on BM3 is I buckled the seat belt... just to make sure... I was so paranoid of bricking my car... LoL...
Did you get that new FMIC yet? gonna need it especially in this heat we have over here....
You can't brick your dme if a flash fails. Just re-flash and you are good.
Well lucky you .... timer said 44 minutes and yes it was 44 minutes for my car...used a samsung S7... I do have to remove it cause I'm taking it in for something else and hope it is quicker next time I re-flash...
How long did it take to flash back to stock completely?
A full flash back to stock takes around the same time like the initial MHD installation. Get yourself the Bimmergeeks cable and enjoy half flash times.
Seba77W291.50
      08-21-2018, 12:07 PM   #2272
starterkit
Drives: 335
Previously used MHD on my n54 335. I now have a 2011 F25 N55 PWG. Would I be facing the torque limiter issue as well? Thank you.
cehrl7147.50
      08-21-2018, 07:31 PM   #2273
Mountain_Commando
Mountain_Commando's Avatar
Australia
288
Drives: 435i Gran Coupe M-Sport
Hi MHD Tuning, any ETA on the updated power dials for N55? I realise it must be pretty low on your priority list, but just thought I'd ask
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
      08-22-2018, 09:30 AM   #2274
Momir@MHD
MHD Tuning
Momir@MHD's Avatar
Only a few cars are affected - datalog and send us the log for review.
We will work on that after getting the TQ limiter fix integrated and the map update done. The power gauges are already "fixed" on M2 and M3/4.
      08-22-2018, 09:36 AM   #2275
GatorF30
Drives: EBII F30
What are the benefits of running the Precision Raceworks coils? Would the car make more power?
      08-22-2018, 10:49 AM   #2276
harkes
harkes's Avatar
China
728
Drives: M135i, NSX and AE86
Very interesting to see MHD opinion on spark plugs as PTF is all about colder and gapped. Bootmod3 user here but I support the MHD opinion - NEVER an issue with factory plugs!
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
badbread297.00
      08-22-2018, 01:24 PM   #2277
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
I dont think the upgraded coil add any performance to be honest. The flash options just allows you to use the coils and thats kinda it.
      08-22-2018, 02:24 PM   #2278
XxThe_RemedyXx
Greece
598
Drives: 2014 335i XDrive
Same here. Running OEM plugs on FBO Stage 2 and never had any issues.
'14 335 xDrive EWG FBO - VRSF Chargepipe - VRSF Catless Downpipe - AA Intercooler - MPE - BM3 Custom Tune by Cary Jordan - R1 Concepts Front/Rear Geomet Cross Drilled and Slotted Rotors - xHP Stage 3 8AT
      08-22-2018, 08:33 PM   #2279
bradsm87
Australia
513
Drives: 2014 F11 LCI 535i Touring
Stock heat range is fine but some do need to decrease the gaps if experiencing misfires.
      08-22-2018, 09:09 PM   #2280
minigp
Drives: 2014 335xi MSport
2014 435 automatic x drive
Stage 2+
Downpipe intercooler intake exhaust
Stock tires DSC fully off no launch control.
93,100 octane blend to make 95.
Not bad
PLF69298.00
      08-22-2018, 09:13 PM   #2281
NWest
NWest's Avatar
Drives: 2015 335xi
Stage 2+
Not bad
Not bad at all, translates to a 12.2-12.3 1/4mi ET
6MT | MPE | Bootmod3 | ER CP | CTS FMIC | Bilstein B14
      08-23-2018, 10:32 AM   #2282
Munchi435i
Munchi435i's Avatar
Stage 2+
Not bad
Not bad at all!! Im curious though, why does it not have a 1/4 mile time? Also, were you running the 95oct flash??
Im hoping my 435i will be a hair closer to super low 12s since the added weight from x-drive im sure plays a role!
      08-23-2018, 10:34 AM   #2283
minigp
Stage 2+
Not bad
Stage 2+
Not bad
Our track here is only 1/8 mile. That's why no 1/4 time. Yes that 95 tune
      08-23-2018, 10:56 AM   #2284
Munchi435i
Munchi435i's Avatar
That makes sense
      08-23-2018, 11:13 PM   #2285
Jimi1121
Drives: 2014 F30 M-Sport
[url]https://imgur.com/gallery/uchAG0U
Mhd stage 2+ . Intake, downpipe, intercooler
12.5 @112
Log from pass. Shows the torque limit in 3rd
https://datazap.me/u/jdarnell1121/lo...16-19-40-41-42
      08-24-2018, 11:25 AM   #2286
Munchi435i
Munchi435i's Avatar
12.5 @112
Wow torque limiter kicks in quick right around 1200RPMs in 1st gear!!
MHD Tuning
Momir@MHD
      08-24-2018, 11:27 AM   #2287
RG24
Drives: 2014 335xi M-Sport
[IMG][/IMG][url]https://imgur.com/gallery/uchAG0U
12.5 @112
The torque limiter is killing my runs as well. That is why I stopped trying until we have the fix. I have been waiting since April. I can feel my car vibrate when it shifts to 3rd. Once it shifts to 4th gear it takes off.
https://datazap.me/u/logkeeper/log-1...16-17-41-42-43
• 2014 335xi M-Sport • MHD Stage 2+ • MPE • Wagner Catted DP • ebay FMIC • ER CP • aFe Momentum • Dinan Springs • Bilstein B8 • 3.80s 0-60 • 11.94@116mph 1/4 •
      08-24-2018, 04:49 PM   #2288
TwistedX
Really Twisted
Drives: 2015 M235i F23 8AT
Trust me I've completely removed the flash and re-flashed at least 5 times due to taking the car into the dealership for warranty claims (non-tune related).
Was there an additional step past flashing back to stock in order to remove mhd all together and rocked the dme?
2015 BMW M235i F23 - VRSF FBO, AEM Intake, AR Designs Catted, Air Lift 3p Suspension, MHD stage 2+, XHP stage 4
flash, mhd, tune
