BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
European Auto Source (EAS)
      12-04-2019, 03:04 AM   #3565
harkes
harkes's Avatar
China
727
Drives: M135i, NSX and AE86
Question What does BMW know that the tuners does not?
Hi
Car: F20, N55, PWG, Pure Stage2
So...after 30 revisions from both a custom tune and the BETA-OTS I still dont have a car that is running right with the Pure Stage2 hvis is frustrating me quite a lot to be honest
So, I was very surprised when I logged Stage0 and saw how well it controls the turbo. How the $#%@ is that possible? What secret sauce does BMW have in their tune that all the brightest MHD tuners has not discovered yet? I am sure the tuners are trying hard, but 30 revisions...
I have asked this question many times before and will try again: Has anyone had a big turbo PWG tuned sucesfully? If so please shoot me a PM, thanks.
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
      12-04-2019, 06:07 AM   #3566
Floriduh235
Drives: M235i MT
Originally Posted by arck001 View Post
Yeah I've checked all connections, replaced tmap sensor, replaced boost solenoid, replaced maf sensor. I still need to do a proper leak test.
Strange.... maybe the diverter valve diaphragm is completely shot (if stock)?
      12-04-2019, 03:51 PM   #3567
DreamerJoe
Drives: 2013 F30 335i
Originally Posted by harkes View Post
Hi
that's your WGDC right? I'm not sure if this would be related or the cause.. but was your wastegate set or checked when you did your PS2 install?
Current: ERCatlessDP/A.A.FMIC/ Chargepipe/AFEintake/MHD 2 91 E30/CF kidney,M-mirror caps, trunk lip
Future: Dinan springs, Koni or Bilstein shocks/wheel spacers/pure stage 2/rear brake mod SS lines/B58 HPFP upgrade looks promising
      12-04-2019, 06:20 PM   #3568
harkes
harkes's Avatar
China
727
Hi
It has been adjusted to be fully closed at 7inHG
(A Dane in China)
      12-04-2019, 09:31 PM   #3569
arck001
Drives: 2013 335i
Originally Posted by thejeremyman9 View Post
Yeah, boost leak test would be the next check. I described how to do it in the boost leak thread.
Also, might be worth trying to reset all adaptations if you haven't already.
I suppose an issue with the WG could also be causing it - in other words the WG issue is the cause of the boost oscillations and not the other way around. I don't think i have seen that reported by anyone else but throwing ideas out there since the fluctuations in WG duty cycle are pretty large and abrupt.
That makes sense, WG should be the problem then.
Car hasn't thrown an codes either.
Could the diverter valve cause this as mentioned?
      12-04-2019, 09:49 PM   #3570
thejeremyman9
Drives: 2015 BMW 335i
I wouldnt say WG "should" be, more like "could" be.
Yes, DV is another good guess. I can see how a bad DV could potentially cause those issues, but i would think that if the diaphram was totally shot it would be a constant leak... Not sure if a boost leak test will test the DV or not.
Overall i'm not really sure how to easily test the WG or the DV with them still on the car... perhaps others have some ideas.
      12-05-2019, 07:39 AM   #3571
AmuroRay
Drives: M235i
Originally Posted by Alpine_F30 View Post
While I agree it's always a good idea to get a custom tune if you're looking to maximize power based on region, available gas, etc that 350-360 figure just isn't true unless you're talking PWG.
The only 2+ MHD ewg dyno I've seen was 375WHP/~400tq, and that was 93 pump gas in dead of summer heat. E30 2+ map in winter/fall should get close to 390-400.
In regards to BM3, it does seem their Stg 1 is a bit more aggressive than MHD, but BM3 Stg2 and MHD Stg 2+ seem VERY comparable.
You seem to be over generalizing a bit, it's awesome you're happy with your custom tune, but most people just want to quickly add some extra power and wouldn't even notice much if any difference between ots and custom. If you're looking to squeeze every oz of power out though for sure custom is the only way to go.
Flat out false. MHD off the shelf tune is NOT hitting 370whp on pump, and the E20 tune isnít even remotely near 400whp.
These cars consistently put down 360whp at most. Please donít make me pull the graphs.
      12-05-2019, 07:49 AM   #3572
AmuroRay
Drives: M235i
MHD PWG with e20
370whp (wheel hp)
MHD EWG Stage 2+
410hp at the ENGINE
440hp at the engine
365whp (at the wheels - blue line)
You want people to believe they can make 400whp with MHD on an off the shelf tune? Come on.
      12-05-2019, 07:57 AM   #3573
AmuroRay
Drives: M235i
375whp(well, 370ish - itís PS and not HP)
harkes726.50
      12-05-2019, 09:06 AM   #3574
DreamerJoe
Originally Posted by AmuroRay View Post
MHD PWG with e20
370whp (wheel hp)
MHD EWG Stage 2+
410hp at the ENGINE
440hp at the engine
time to bring out the hub dynos
      12-05-2019, 11:10 AM   #3575
AmuroRay
Drives: M235i
Most of those dynos would read 355-365whp on US dynjets on 93oct. No way youíre making 400whp with those off the shelf tunes.
      12-05-2019, 01:40 PM   #3576
DreamerJoe
Most of those dynos would read 355-365whp on US dynjets on 93oct. No way you’re making 400whp with those off the shelf tunes.
hub dyno's tend to read a lot higher because their is less load.. they jack up your car, remove your wheels and attach straght to your lugs. not a traditional dyno on rollers.
      12-05-2019, 02:26 PM   #3577
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
Yup, never do hub dynos as it's very inaccurate, the power you make on it will never be what you're actually putting down as you just removed about 160lbs worth of wheels.
MHD has a very conservative OTS tune for N55.
B58 on the other hand is the opposite as their OTS tunes are pretty aggressive.
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, GFB DV+, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3, xDelete
      12-05-2019, 02:30 PM   #3578
AmuroRay
Drives: M235i
I know. Church automotive in Cali has one, all the import guys used to post their numbers. I actually prefer those dynos because they donít factor rotational issue with wheels, and give you a more realistic number (plus they can add load) Iím under the impression they are the best dynos for tuning.
      12-05-2019, 05:44 PM   #3579
Zara
Drives: 2014 335i
Any update on the MHD Wireless OBD-II adaptor?
2014 335i 6MT /// Mineral Gray - Red Coral
| M Perf Spoiler | M Perf Lip & Diffuser | M Perf Grilles | M Perf Side Splitters | M Perf CF & Alcantra Interior Trim |
| Wagner Evo II FMIC | VRSF DP | AA CP | CTS Turbo Intake | MHD Custom Tune | H&R Sports | Bilstein B8s |
      12-05-2019, 06:04 PM   #3580
thejeremyman9
The WiFi adapter was released a while ago... just check a few pages back in this thread.
      12-05-2019, 06:20 PM   #3581
DreamerJoe
I have it, works great.. only 20 seconds to map write, super quick.
Phyrexia473.50
      12-05-2019, 09:44 PM   #3582
Zara
Drives: 2014 335i
Oooh perfect, thank you!
Glad to hear it works great
      12-07-2019, 07:54 PM   #3583
3volved
Drives: 2015 435i xDrive GranCoupe
Can confirm. The long flash only took about 2 1/2 minutes. I'm using a new Tab A 10.1...now to figure out how/where to mount the damned thing.
      12-07-2019, 08:10 PM   #3584
thejeremyman9
I ended up going with a Tab A 8'' because the 10.1 seemed like it would be too big to mount. I basically cut the dimensions of the 8'' and 10.1 out of cardboard and tried moving them around various potential mounting points and that showed me right away the 8 was better.
In any case this is what i used to mount mine, it fits perfectly in portrait orientation between the A piller and the gauge cluster. The bottom of it is at above air vent level and its pushed back as far as possible toward the windshield. You may not be able to fit the 10.1 in the same spot, but this mount should work. Its super solid and the tablet doesnt move at all even when launching, canyon runs, etc.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      12-08-2019, 12:54 PM   #3585
Tpriest7893
Drives: Bmw 335i f30 N55
This might be a dumb question, but based on what I have been reading it seems MHD is not as strong as bm3 for the OTS maps.
On the MHD website, for a PWG car, map 2+ states 400 HP. Is this correct?
I'm on the fence between the two tunes.
What I like about MHD is the wireless OBD port just plugs in connects to phone and that's it.
Also, for the price I can get MHD and the WiFi adapter cheaper then a used bm3 license.
When it comes to the custom tunes do you just request it via the app? And they load it for you?
-Tods
      12-08-2019, 01:18 PM   #3586
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
I have not seen many comparison dynos for BM3 vs MHD BUT if you are looking to squeeze every ounce of WHP then i'd suggest getting a custom map.
As far as OTS maps I'm not sure which yields more HP but both camps will say there respective OTS is better than the other. From the logs i've read it seems like BM3 is tuning more based on target boost and MHD is more base on load requested.
As always, your experience may vary depending on lots of factors such as location, hardware mods and quality of fuel.
When it comes to custom tunes, you would need to reach out to a tuner and they will send you files to upload using either MHD or BM3. I have no idea how you go about requesting though BM3 but as for MHD you will just contact the tuner for the custom map.
flash, mhd, tune
