BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
proTUNING Freaks
      03-23-2018, 05:09 PM   #1299
ChrisFulton
Drives: m235i
Originally Posted by valve float View Post
look good as well....target met...same spool up knock....tq limit at top of 4th with throttle closure....
Thanks Valve Float
      03-23-2018, 05:40 PM   #1300
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Originally Posted by ChrisFulton View Post
I'll let someone much more knowledgeable explain this, but looks like a well known problem of hitting "torque limiter."
Yeah i noticed the torque limiter being reached!
Thanks for the info and hoping this torque limiter will be solved soon!!! Ive had this issue from the beginning but it seems like its getting better from my first few logs.
Originally Posted by badbread View Post
Stock FMIC?
Yeah I'm completely stock with Auto trans
      03-23-2018, 05:57 PM   #1301
Munchi435i
Munchi435i's Avatar
Originally Posted by r0nd3L View Post
I'm hopeful as well. I have been testing some custom maps sent to me in effort to diagnose that, but problem still exists at this moment.
If I was the only one experiencing it, I would lean to some hardware problem, but there is a handful of us, so doubtful.
Yeah I know the struggle but I'm confident that MHD will find a solution. I'm really curious why this is even happening at all! And why only a few cars are affected??
      03-23-2018, 06:03 PM   #1302
valve float
Drives: 335i
i was under the impression it was related to early build PWG DMEs, but i now see EWG cars effected as well...? hmmm
      03-23-2018, 06:06 PM   #1303
Munchi435i
Munchi435i's Avatar
Hmmmm would it be possible that the affected cars have old DME's?
      03-23-2018, 06:19 PM   #1304
Niart906
Drives: 2013 335i M-Sport 6spd
Originally Posted by dphjr View Post
I just ditched the BEF JB4 combo for OTS and I'm so glad I did. My JB4 loved to throw drive train codes and felt very rough (albeit the BEF is still being heavily developed, while MHD is almost at release). Power was not linear at all, but hit you all at once, and my shifts were really rough for some reason. Finally, I was running very lean, although that is common with JB4 users. But my car is running much better now, power delivery is stock and strong; I was hitting 17 psi on a quick run I did yesterday.
I'd suggest you scroll back a page or two to see the big discussion on JB4 that just happened on this thread.
Thanks for the reply, you've described my experience with the JB4 BEF combo exactly. I love having the features of the JB4 but right now it's not quite fully fledged, and my first track event is less than a month from today. I'm not comfortable running that tune on track just yet. That said, Terry has been very helpful with BEF revisions and his communication is damn near instant through email. I'll probably continue to fine tune the BEF with him during the off season.
Also, 17psi is impressive, but I'm PWG. Curious to see how the PWG stage 2+ compares to EWG. Might even grab the ethanol map for track events, assuming my intercooler can keep up.
2013 335i Estoril Blau II/Black
6spd | M-Sport | JB4+BEF | BMS Intake | ER D-P | VRSF Chargepipe | Phoenix FMIC | Megan Racing Sway Bars | H&R Sport Springs
      03-23-2018, 07:24 PM   #1305
louielouie
Drives: '15 435i | '16 M4
I have timing corrections as well in my logs running on stage 1 stock, 91 octane. Car is only 23k miles so I don't think it's plugs/coils.
Is this common due to low octane?
      03-23-2018, 07:38 PM   #1306
Munchi435i
Munchi435i's Avatar
I'm using 93 oct stage 1 flash so it's not a octane issue
      03-23-2018, 09:11 PM   #1307
valve float
Drives: 335i
yep...that's why splashing in some e85 is so helpful to those with low octane...
i can run the stg2+ 93 map with 0 zero timing corrections on e20mix...super punchy low/mid range, great spool, very smooth...don't necessary need e30 maps to benefit from e85...
      03-24-2018, 04:41 AM   #1308
cxp213
cxp213's Avatar
297
Drives: M235i
Originally Posted by F30RiK View Post
Coils are brand new and spark plugs are n20 spark plugs gapped to 0.25. I had the same issues on my n20 (timing pull) with the same spark plugs.. I think I will buy the original ones for my n55 (bosch) and gap them to 0.20.
I'm 6mt, thanks for your help!!
Aren't the N20 plug colder plugs than the N55 ones? I thought a lot of tuned guys were being recommended to run these plugs..? And I hope you mean 0.025" but why that gap?
I don't know if advising people to arbitrarily splash in some E85 is a sound idea. Although ethanol does raise the octane level, it is also less energy-dense and more of it is needed, so it's not just a difference in octane level. Unless they know how to calculate the ethanol concentration and are ok with possibly deviating from the map's intended targets, they should probably just stick with the octane rating for the map they chose. What works for you may not for others and they also may not have the same level of knowledge that you might have.
GatorF30369.50
      03-24-2018, 10:28 AM   #1309
valve float
Drives: 335i
thanks for all the self righteous concern but this e85 stuff is kinda old news....
wait, you're right i should retract because many in this forum apparently can't search/google "e85 n55 pwg ewg" and/or perform basic algebra ...
      03-24-2018, 10:41 AM   #1310
enemigo13
Drives: F30 340xi
400 at the wheels? with pwg? sir, are you ok? 400 at the wheels converts to ~460hp at the crank considering 15% of transmission loss. while this car has 306hp stock _at_the_crank_ (~300 in reality), so do you really think that you added 154hp to your car with stock pwg turbo just adding some ethanol and tune )) really? to make something around 450hp _at_the_crank_ from 3 litres you need at least 1.2-1.25 bar at high rpms (17-18psi at 6000-6500rpm) not 0.7-0.8 bar (10-11psi) you have now. make a video of your 100-200km/h (60-130mph) acceleration and I will tell you how much approx hp you have. If you have 400whp (460 crank hp) you should do 100-200km/h in 8seconds easily (stock m4 does it in ~8.7 seconds), let me guess how much it is now? 11-12 seconds, right?
thought a pwg stg2+ on a solid e30 map was good for 400/450@wheels...?!?
this mhd beta e30 map may yet see more timing, boost or other trickery...
SeanWRT2499.50
      03-24-2018, 11:20 AM   #1311
valve float
Drives: 335i
i just said "a solid tune"...not this current mhd beta...pretty sure i've seen TT plots with a custom e30 map peaking at 24 tapering to 16, making 397/457@wheels...the curve is nasty no doubt, but lots of area under the middle of it, how long the turbo would last under that load is anyone's guess...
in fact here is the link...
https://bmw.***********.com/threads/...ent.943/page-2....s poo l s tree t....
remember the e chassis...?...lots of tuning has been done on the pwg n55 hardware...just different DME's and hence different tunes...
      03-24-2018, 11:44 AM   #1312
F30RiK
Drives: 13' 335 xdrive M-sport 6 Speed
The plugs were on my previous car and had hesitations with jb4 and I tried different gap and forgot to re-gap them when I did the installation on my 335.
I will put back my old bosh spark plugs today (gapped at 0.032 from the factory ).
      03-24-2018, 12:05 PM   #1313
badbread
not good, but bad
Drives: 2013 335i
What type of plugs to use seems to come up a lot, from what I've gathered the stock plugs work just fine unless there is some special circumstances, very highly tuned for example.
What octane fuel are you using? If you're using 91 absolutely try supplementing with e85. www.*************/howie85 for my noobies guide on using e85 to supplement octane.
      03-24-2018, 12:31 PM   #1314
cxp213
cxp213's Avatar
297
Drives: M235i
Still responding to posts like a douche I see. Don't take it so hard, it's not a dick.
It wasn't meant to be self-righteous, but more of an advisory to those who may blindly throw in E85 because they read on the forums from a stranger that it'll magically solve their problems, lol. It's a valid concern to have considering the type of posts that are constantly being posted.
      03-24-2018, 12:38 PM   #1315
SeanWRT
SeanWRT's Avatar
2500
Drives: E90 M3 & F87 M2
Some PWG guy is high.
Lemania 2320
      03-24-2018, 12:53 PM   #1316
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
I came from stock turbo PWG and I can tell you software won't fix hardware problem. The turbo is so tiny no matter how much power you have, you will still lose vs a EWG top end, even stock EWG.
Its the worst turbo BMW can put in the f series.
E85 mix won't solve anything, changing the turbo will.
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, GFB DV+, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3, xDelete
      03-24-2018, 12:55 PM   #1317
enemigo13
Drives: F30 340xi
Your link is blocked. what "solid" tune will do? will it increase compressor diameter or turbine flow? I dont care about peak psi, its useful for gearbox breaking and loosing traction only, 24psi at 3000rpm is useless. 16psi at redline (7000rpm) with stock pwg turbo? sorry, I think its PS2 or maybe PS1 territory. If you still cannot believe that stock pwg turbo is crap, add jb4 to your existing flash tune, jb4 will completely close wastegate letting turbo make boost as much as it can (if you believe that current flash tune not enough pushing turbo) and make 100-200km/h run. post your video here. We will watch and laugh how "460hp car" does 100-200 in 11-12 seconds, that's it. For power you need boost. And healthy ignition timing. Period. I'm running 1.05-1.1 bar (15-16psi) @ 6000rpm along with 9-10 ignition timing there and trust me, I'm far away from stock M4 100-200km/h time. M4 does it ~1 second quicker. Yes it's 60kg lighter but in this case it makes more power also. Every stock pwg log I see, stock pwg turbo falls off the cliff after 5000rpm and it's physical hardware limitation, it's very sad that people do not understand that software will not convert their tiny pwg turbo to PS2 ..
      03-24-2018, 02:52 PM   #1318
Niart906
Dude get off your high horse, 400 whp on a PWG car has been done before with just a JB4 and an E40 mix of ethanol. No one here is saying PWG is better than EWG, just that you can still make good gains with the PWG setup.
http://f30.bimmerpost.com/forums/sho....php?t=1312822
akgambino149.00
      03-24-2018, 04:40 PM   #1319
F30RiK
I put back my old 50 000miles Bosch spark.plugs capped at 0.032 from the factory and my timing correction seems better.. I will buy some brand new spark plugs next week
https://datazap.me/u/f30rik/f30-peg-old-bosch-sparks
      03-24-2018, 05:59 PM   #1320
akgambino
Drives: 2013 F30 335xi M-Sport (PWG)
What plugs/gap/mods were you running that were no good and made you go back to the stock plugs/gap?
Wondering as I just flashed bm3 and they recommend the ngk two step colder plugs gapped to 0.02, I bought them but haven't installed yet and am looking for a reason to or not to install them lol
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct)
flash, mhd, tune
