BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
proTUNING Freaks
      01-04-2018, 02:34 PM   #133
f32_027
Driver
f32_027's Avatar
Drives: 435i
Originally Posted by Twisted Tuning View Post
Originally Posted by f32_027 View Post
You provided a link to your meth controller - that will work completely fine with the bms stealth tank and their pump and lines? Twisted Tuning And, it's not too big to fit in the Engine bay?
yes, itwill work. Is the Jb4 still using that little FSB thing? Simply you would remove the JB4 stuff and the solenoid and pump would get connected directly to the controller.
Same with the AEM, Aquamist, Snow offerings. If you wanted a simple replacement, the AEM v2 and Snow Performance stage 2 controllers work well also.
Twisted Tuning the jb4 and tank aren't connected yet so I don't know about the fsb thing - I'm just planning ahead. I'm part of the beta program so the plan is to sort out the flash tuning first, and then afterward hook up all the meth related stuff and do a custom tune so everything works smoothly. I looked up the AEM controller but I'm not a fan of having the controller inside of my car. Any other suggestions?
      01-04-2018, 06:35 PM   #134
Kennedy28
Drives: 2014 335i
Twisted Tuning Yes they still use the fSB module to integrate it into the jb4. Im thinking of just trying to piece a kit together possibly. With your controller it seems it comes with built in fail safes as well ? which is my main priority. Spray and pray is not really my thing
      01-04-2018, 08:03 PM   #135
f32_027
Driver
f32_027's Avatar
Drives: 435i
@Mike@N54Tuning.com can you speak to some of the last few posts regarding jb4 as a controller for meth and it's limitations vs other controllers?
      01-04-2018, 08:35 PM   #136
135iDCT
135iDCT's Avatar
106
Drives: 135I
Any plans to release a web version of MHD flasher? so no need to buy android device
or IOS App?
      01-04-2018, 09:29 PM   #137
Lotus99
Lotus99's Avatar
Drives: 19 M2C & 18 X3 M40i
In a competitor's thread?
      01-04-2018, 09:42 PM   #138
f32_027
Driver
f32_027's Avatar
Drives: 435i
@Lotus99 didn't think of it that way
      01-04-2018, 09:50 PM   #139
Twisted Tuning
Twisted Tuning's Avatar
944
Drives: 335xi
i thought so. never can be too sure. they change stuff with the JB4 every other week it seems. it does have failsafes. Let me know if you need something. I have many meth injection parts i deal in.
Where would you want the controller? in the Engine bay? Most controllers aren't waterproof, so just need to be careful and keep them away from water.
      01-04-2018, 10:15 PM   #140
f32_027
Driver
f32_027's Avatar
Drives: 435i
In the engine compartment, on the right side of the car, under the cowling on-top of the fuse box Twisted Tuning
      01-05-2018, 08:55 PM   #141
the1isntugly
Drives: 14' 435i Sport Line
Will you be able to drive with the MAF disconnected for those that are getting codes with aftermarket intakes?
      01-05-2018, 09:23 PM   #142
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
Well, one of the points of the tune would be to scale the MAF depending on the type of intake you have, so hopefully the MHD tune would actually correct the issue instead of having you disconnect the MAF
The reason for the CEL is most likely due to the difference in the size of the maf housing that is throwing the measured air outside of the MAF curves acceptable tolerance.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current
MHD Tuning1621.00
      01-05-2018, 10:01 PM   #143
2000Z3M
Drives: 2016 435i ZHP
what will this do to cars with mppk?
      01-05-2018, 10:29 PM   #144
paimon.soror
mppk would become your baseline tune.
MHD Tuning1621.00
      01-06-2018, 12:07 AM   #145
Seba77W
Seba77W's Avatar
292
Drives: BMW 435i Xdrive Coupe
What intakes get CEL lights?
I've had my CTS Turbo intake on for nearly 10k miles with no problems and no CEL! And the sound!
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
      01-06-2018, 12:17 AM   #146
paimon.soror
I think CTS is really the only intake system that closely mimicks the OEM MAF housing.
Seba77W291.50
TR-8R68.00
      01-06-2018, 08:36 AM   #147
Mountain_Commando
Mountain_Commando's Avatar
Australia
288
Drives: 435i Gran Coupe M-Sport
Maps are out!!!
Oh wait, I don't have my KDCAN cable yet.
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
      01-06-2018, 09:16 AM   #148
GatorF30
Drives: EBII F30
Flashing Right Now!!!
      01-06-2018, 11:21 AM   #149
ABPReader
Deserter
ABPReader's Avatar
Drives: BM&W
Can't wait to read some feedbacks and to pull the trigger later this year ! If you some people have tablets to recommend that would great
MHD Tuning Do you have something planned for the S63tu ?
      01-06-2018, 11:27 AM   #150
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
I Flashed stage 1 about 30 mins ago and just came back from a short drive. Even in comfort mode I could feel a difference in throttle response and a overall power! After letting the oil temp get to about 200 degrees I switched to sport+ and WOW!!!! amazed at the difference with just a flash and being completely stock!! I have not had a chance to log anything but I think we are suppose to do a few WOT passes to calibrate the tune and then I'll start my logging. All in all, everything is still working as it should and no codes, fingers crossed!
ABPReader207.00
ali820222.50
MHD Tuning1621.00
      01-06-2018, 01:19 PM   #151
valve float
Drives: 335i
just flashed stg 1 91oct...jeezus, i concur...what a difference from the piggyback...now i understand what flash tune vs piggyback is all about...
this is just beta v1...can't imagine what future revisions bring...
good days people, good days
ABPReader207.00
ali820222.50
MHD Tuning1621.00
      01-06-2018, 01:54 PM   #152
ceedawg
ceedawg's Avatar
436
Drives: 2k15 335i xdrive MSport 6spd
Munchi my car is stock and Im looking into MHD and Bootmod3 and all you have is this MHD flash and that's it? Wow!!! Nice!! The back and forth decision is driving me crazy
      01-06-2018, 02:03 PM   #153
GatorF30
Drives: EBII F30
Just made my first log and sent it over to MHD. Car pulls crazy hard!
      01-06-2018, 03:32 PM   #154
paimon.soror
the anticipation ... the anticipation...
flash, mhd, tune
