BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Suspension / Brakes / Chassis / Spacers > FOR SALE: 4 pot 370mm / 2 pot 345mm Blue Brembo M Sport Calipers (used, with pads)
proTUNING Freaks
      02-01-2019, 04:22 PM   #67
R99
Drives: 2016 330d F31 Touring
Originally Posted by pjb330ci View Post
Still around?
Yes, one 340 / 345 set here.
Happy to split and sell front / rear separately.
      02-04-2019, 01:03 PM   #68
R99
Just to update, I have two sets of 370 / 345 on the way.
So, currently available is:
1 x 340/345 set (happy to split to sell fronts & rears seperatley)
2 x 370/345 sets
1 x 370 pair of fronts
Also...
1 x single 370 front
1 x single 345 rear
      02-04-2019, 05:15 PM   #69
TYE
TYE's Avatar
52
Drives: 997 GT3, '18 440i GC
Is the 370/345 coming with oem pads or is it calipers only? Thanks.
      02-04-2019, 05:47 PM   #70
R99
Used pads included (incl pins / clips)
      02-04-2019, 06:24 PM   #71
alexng72
Drives: 2015 F32 435i Black Msport
Hi how much is it for a rear 345 set shipped to 45011?
Thanks
      02-04-2019, 06:30 PM   #72
R99
Thanks
380 GBP
      02-06-2019, 12:29 PM   #73
R99
One pair of rears now sold.
      02-06-2019, 03:50 PM   #74
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
I will buy the whole set if available
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, APEX EC-7
Instagram: @brandonsclean3
      02-06-2019, 04:30 PM   #75
R99
340/345 or 370/345?
Regards
      02-07-2019, 12:15 AM   #76
sickF30
Drives: F30 335i
You need 370mm discs as the grey Brembo’s are the 340mm version.
Regards
this is incorrect. the blue calipers are exactly the same as the grey calipers, just blue. they will work with both the 340mm and 370mm discs.
the only requirement to run the 370mm discs is you have to replace the dust shield or trim your stock dust shield to make room for the larger discs.
      02-07-2019, 03:17 AM   #77
R99
Ok, you try fitting a 370mm rotor with a grey 340mm caliper (or a blue 340 caliper for that matter) and let us know how you get on.
You are incorrect, do you want me to post a picture of a 340 & 370 side by side showing the physical differences. The 370 calipers have a bigger mounting radius.
      02-07-2019, 01:25 PM   #78
Logicoeur
Logicoeur's Avatar
387
Drives: F30 335i xDrive
Correct. Blue 4pot Brembo calipers come in 340mm or 370mm. Same caliper just a longer integrated carrier. The 340mm blue is just a painted gray 4pot Brembo. Red, yellow, orange are all 370mm.
370mm 2pot brembos in any color are the same as stock m3/4 and I believe the M2. They fit 380mm rotors by moving the mount holes on the upright 10mm farther outward from the axle.
F30 335iX | Remus Axleback | 18X9 ET32 19lb TR-1 255/40/18 | MPerf LSD
      02-07-2019, 03:02 PM   #79
R99
Yes, exactly. The only point to note from your reply is that the fronts
are 4 pot and rears 2 pot.
Unfortunately, the guy posting above calling my info out as “incorrect” obviously doesn’t know the basics.
      02-08-2019, 01:07 PM   #80
sickF30
Drives: F30 335i
my apologies then.
      02-09-2019, 10:27 AM   #81
R99
Calipers are here:
      02-10-2019, 11:28 PM   #82
TheShadow
Drives: 335i M sport
how much for a set of 370 front 345 rear shipped to usa?
Are these calipers the same size etc as m performance calipers? Just different colors?
      02-11-2019, 03:08 AM   #83
R99
Hi, yes identical to M Performance when in 370/345 combination.
I do not have a full set ready to go out just yet, will do shortly though.
      02-11-2019, 04:57 PM   #84
alexng72
+1 for a very fast and smooth transaction for a rear set 🙏
kern4172382.00
      02-11-2019, 05:02 PM   #85
Ahmed Abdullatif
Drives: 340i
Hello any other good set available?
Thanks
      02-11-2019, 05:05 PM   #86
Ahmed Abdullatif
Drives: 340i
Another set in great shape - rear pads are not suitable for re-use in my opinion, however the paint condition on this set is fantastic!
Far better than most sets on eBay that have loads of paint damage!
Pistons and bleed nipples are all free moving....
Postage to the USA is £90 GBP and all my stuff is properly packed and insured!
A set like these!!
      02-12-2019, 04:27 PM   #87
newyork326
Drives: 2015 335 M Sport X Drive
A set like these!!
[img]
View post on imgur.com
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
A set like these!!
Price?
      02-12-2019, 06:35 PM   #88
R99
To recap, that set is sold.
All I have left from pic posted above is as follows:
1 set of rears with one bleed nipple that will not undo. £299 delivered as they are or £380 delivered once fixed.
1 set of 370/380mm fronts with two bleed nipples that won’t undo. £399 delivered as they are or £499 delivered once fixed.
1 set of 340mm fronts in great shape, with no issues. £380 delivered.
