BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding for 6NR BMW Apps?
      03-17-2019, 03:55 PM   #111
Elmo111
Drives: BMW 118d Urban
Originally Posted by shawnsheridan View Post
Originally Posted by EmilioB View Post
Hi all,
Can somebody confirm to me if either of these 2 VIN numbers support BMW Apps? They both have ConnectedDrive in the menu.
P709274 production date 06.15
VZ29629 production date 07.14
Thanks!
P709274 production date 06.15 - Not Possible
VZ29629 production date 07.14 - Possible
Hi all,
Thanks!
For the 07.14 unit, I don't have a TCB. Is that going to cause some issues if it's retrofit?
I'm currently in the process of buying the actual vehicle attached to the 06.15 head unit, if I replace with the 07.14 ENTRYNAV, does that just mean I'll lose access to ConnectedDrive functionality minus BMW Apps?
I was wondering if it's possible to migrate the other lot of FSC certs over to the 07.14 unit - but I believe you can't mix and match
      03-17-2019, 06:41 PM   #112
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
You can Have 6NR BMW Apps with ENTRYNAV. You are not going to working Telematics (e.g. 6AK Connected Drive Services) with retrofitted TCB, unless TCB has active Telematic Subscriptions, ENTRYNAV uses same VIN as Donor TCB and an Emualtor for Activation.
      04-19-2019, 04:07 AM   #113
gzmdesign
gzmdesign's Avatar
Drives: BMW F11 - 520D M-Sport
Question
Morning fellows, I have finally made the jump and went from a 2011 F10 (CIC) to a gorgeous 2016 F11 with NBT (Large screen, new controller).
I have dipped my toes in the coding waters, got my self one of them Wi-Fi adaptors and got Bimmercode purchased, I've done a couple of things on it already and it seems simple enough. I 'm now looking to do a bit more.
The CIC I had before used to show me texts from my iPhone (it had the "Office" menu on it) and it was quite the handy feature. My new one doesn't.
Also, while I see the Connected Drive menu on it, I don't see Apps in it. My brother has a 2014 F10 (525D) and that one has Apps, Office, etc... Also, his Connected app on the iPhone itself has a few more features than mine, for instance he gets to see the fuel level, current miles and remaining range of his car, I don't.
I've done some extensive reading up and it seems I don't have EBT (which I did in my old CIC F10) and that's why I don't see texts. Also seems I don't have the Apps pack (??).
Are these things able to be enabled via coding with BimmerCode? Sorry, if I'm asking too much please feel free to tell me go do more reading! I just seem to have hit mi limit here... I stumbled upon this post and it seems you guy have a resident Yoda (shawnsheridan)
I can post both VIN endings here if it helps?
Thanks in advanced for any help guys!! I'm not strange to trying things on my cars / motorcycles, but I rather have some peer review before I break something hahaha
Current: 2016 BMW 520D F11 M-Sport - Alpine White
Previous: 2011 BMW 520D F10 SE
      04-19-2019, 08:06 AM   #114
shawnsheridan
If you have NBT, you can VO Code HU_NBT for 6NS to EBT.
BMW Apps needs a 9C FSC Code and 6NR Coding. PM sent.
      04-19-2019, 10:38 AM   #115
gzmdesign
gzmdesign's Avatar
That was a quick response! Thanks very much!
For the EBT coding, I have an NBT head unit, but I don't have E-Sys or the cable, I only have the Wi-Fi adaptor and BimmerCode, I've done some coding in expert mode, but as far as I know you can't do VO coding through BimmerCode, any idea if 6NS can be done using expert mode in BimmerCode?
Thanks again!!
      04-19-2019, 10:41 AM   #116
shawnsheridan
Thanks again!!
No idea. I only use E-Sys myself.
      05-04-2019, 12:35 PM   #117
ahm.r
Sweden
Drives: bmw F20 116i 2012
Hi Shawn!
I have changed my head unit which is ENTRY CB to one which is the same but after I mounted the other everything worked but not bluetooth.
My question must be the new head unit coded and how should I do?
I have e-net cable and e-sys that you have sent to me and I'm very grateful for your help, best Shawn.
      05-04-2019, 03:52 PM   #118
shawnsheridan
Originally Posted by Ahmed-R View Post
Hi Shawn!
You need to import your original FSC Codes into replacement head unit, such as these:
AppID 129 (81) - Media Player (USB)
AppID 130 (82) - Telephone (Bluetooth)
You also need to VO Code HU_ENTRY to a;lign it to your car.
      05-04-2019, 05:17 PM   #119
ahm.r
Sweden
Stor tack Shawn.
      05-05-2019, 09:14 AM   #120
ahm.r
Sweden
Im a beginner in this programme and I cant find myself around in it. My question is if someone in the forum can remotely access my programme, and install and code my new head unit. I have both the cable and the programe, but I lack the know-how. Im willing to pay for the effort put into this. My head unit doesn't have a navigation, only bluetooth for calls, no media!
I would be very grateful.
Best Regards
      06-17-2019, 02:36 PM   #121
MelbourneF30
Drives: 2013 BMW 328i xDrive
Hi Shawn can you PM me cost for the 6NR FSC code?
Thank you
      06-17-2019, 02:42 PM   #122
shawnsheridan
Thank you
PM sent.
      07-12-2019, 09:14 AM   #123
Bobo_Car
Drives: F31 330d Xdrive
2014 F31 with ProNav
Hi Guys,
Been reading this thread from the first page, I was bought hear after seeing the 399USD charge form Bimmertech to code this!! If I have understood well to get apps for my specific car with a build date 08/14. I need to activate 6NR option and i also need a 9 character FSC code generated from my VIN.
How hard is this to do, I'm fairly tech savvy always done the USB map updates etc myself.
I understand I need an OBD cable and E-sys, I currently have a macbook so I imagine i will need a windows laptop... or is there a coding specialist in the UK that would perform this for a reasonable price?
Any advice would be great.
Cheers
      07-12-2019, 10:05 AM   #124
shawnsheridan
Originally Posted by Bobo_Car View Post
Hi Guys,
Cheers
The bulk of the cost for BMW Apps is the official OEM 9C FSC Code itself, not the Coding of 6NR. The 9C FSC Code is not a 20 Digit Alphanumeric Code that can can be generated simply like an Map FSC Code can, rather it is an actually a digital file signed by BMW AG. PM sent.
      07-12-2019, 05:46 PM   #125
Bobo_Car
Thanks for explaining Shawn
Cheers
      08-19-2019, 07:56 AM   #126
aktm135
Drives: M135
Hi Shawn
I have the same query as Bobo_Car but Iím in Australia. My car is 09/2013 m135 and I would like to enable BMW Apps. Any advice/help you can offer would be appreciated.
Thanks
      08-19-2019, 08:02 AM   #127
shawnsheridan
Originally Posted by aktm135 View Post
Hi Shawn
Thanks
PM sent.
      11-06-2019, 03:26 PM   #128
sidrandy
Drives: 2015 335x M performance
hi Shawn, would you be able to hook me up with your FSC code contact. thanks in advance
      11-17-2019, 09:00 PM   #129
0x40404040
0x40404040's Avatar
Drives: F25 N55
2012 BMW X3  [0.00]
Hi guys. I own an F25 with CIC and Combox from the factory. While doing some random coding, I've noticed that I have 9C FSC accepted but not available.
AppID 156(0x9C)
UpgradeIndex 1(0x01)
SWTType SWTclassic full
FSCStatus not available
FSCCertStatus accepted
Does this mean that I can just write 6NR to my car's VO, VO code HU_CIC and CMB_MEDIA and I'll have the apps?
I wonder would the apps work via Bluetooth tethered internet connection? My vehicle was imported from the US to Europe so BMW Teleservices are useless now.
If Bluetooth tether wouldn't work, would it work via USB connected Android / iPhone device?
VIN: L981521
      11-17-2019, 10:22 PM   #130
shawnsheridan
PM sent.
      11-17-2019, 10:29 PM   #131
shawnsheridan
AppID 156(0x9C)
VIN: L981521
You do not have 9C FSC Code. It shows Status = "Not Available", and VIN L981521 does not have one issued by BMW AG.
Apps with CIC / Combox is only possible via USB Cable, and there is no Android support.
      11-26-2019, 02:01 PM   #132
saxonel
Drives: bmw F15
Thank you
