BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Wheel speed sensor
      09-19-2020, 09:36 PM   #1
liveevil
Drives: 2013 BMW 320i GT
Wheel speed sensor
Hi,
I have the chassis stabilization , abs, cel warning lights, which is typical of my wheel speed sensor.
Bought the following part number 34526884423, and after changing the sensors, - the error didnít go away. In fact, I got the airbag malfunction error as well now
- the steering became heavy (Was normal before I replace)
- Automatic trunk does not work (can still open by force)
- retractable spoiler deployed and couldnít get it down
I bought my own parts and the workshop installed for me. They suspect I got the wrong part.
Has anyone faced similar experience, and managed to get it resolved? What would be the next troubleshoot to do?
Thanks!
      09-19-2020, 10:07 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The error won't go away because you changed the sensor. You have to clear it with an OBD diagnostic and repair tool. You might not have had to replace it. I got the entire set of warnings associated with ABS sensor failure. I used my Foxwell NT510 to diagnose the problem, clear the codes, and then function test the sensors. They were all fine. Two years later the problem never returned.
      09-20-2020, 07:35 PM   #3
liveevil
We cleared the error codes a few times but it came back the moment we drive the car.
      09-20-2020, 08:13 PM   #4
Billfitz
Billfitz's Avatar
In that case you have to test the sensor function. If they test OK then something else is causing the problem.
      09-24-2020, 03:21 PM   #5
liveevil
The new sensors are not the right one. Apparently I have park assistant on the f34, which I never knew for the past 7 years!
