08-25-2016, 01:55 PM | #2 | |
Rep 953
2014 328i - FBO/KW v2/VMR v710's IG@F30_Joe
08-25-2016, 06:57 PM | #3 |
Big Turbo Boys N Girls
327
Rep 579
Good Luck incorporating the Canbus to control the electronics. But it will all be custom made. Car is too new and way too expensive to start with to have anyone do any swaps. GL OP!
07-29-2017, 12:52 PM | #4 |
Nemo banks
65
Rep 253
even with a n55 ?
FBO N20, G-Plus Oil Cooler , Injen Cold Air Intake, MST turbo inlet, AFE Charge Pipe, BMS Oil Catch Can, Forged Motorsport Blow of Vavle, Wanger FMIC, Circuit Werkes Catless Downpipe, Full Straight 3inch exhuast. Stage 2 Active Auto Werke.
07-29-2017, 02:00 PM | #5 |
Rep 657
07-29-2017, 05:38 PM | #6 |
327
Rep 579
N55 or B58 should not be too bad as canbus is already there in the ECU. BUt you will def need to do some wiring/ pin changing and coding/ adaption will need to be done.
07-30-2017, 10:58 AM | #9 |
Rep 657
07-31-2017, 02:26 PM | #10 |
Rep 8
It will be better, easier and cheaper to buy 335i or 340i.
07-31-2017, 03:11 PM | #11 |
Rep 657
07-31-2017, 05:35 PM | #12 |
Rep 1,343
Are you sentimental about your 328i that you rather transplant another engine instead of just upgrade to a higher spec 3er as others suggested?
07-29-2018, 10:48 PM | #13 |
Nemo banks
65
Rep 253
07-30-2018, 01:31 AM | #14 |
Rep 63
Well it’s my commuter. I have 117k on it and climbing 60 miles every day. I figure if I found a bmw parting out because it’s totalled and find a motor for about $4k how hard it would be to do it. From what I’ve read the n20 seems pretty reliable however it’s a bmw .
07-30-2018, 02:52 AM | #15 | |
Rep 3,752
Then OP mean, replace the old n20 with a fresh or remanufactured n20? |
07-30-2018, 09:37 AM | #17 |
Rep 2,382
Hey OP, did you know you could buy a Porsche 918 and be quicker than engine swapping your car?
Focusing on your actual question, 2nd reply to the thread hit it on the head. N55 with the associated DME would be your easiest option (leaving the N20 out of it). I'd assume with a similar year, so long as you can get your CAS to accept the DME and sync with it, you'd be fine. I'd be a little more wary of a B58 swap as all components in the chain with CAS would be different and may not accept each other. That'd call for you to pull either the same parts associated with it or at least the same parts that are virginized and then initiate a sync. It definitely won't be fun but if you have the time/money and are really wanting that over a new car or new N20 engine, then go for it.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
11-19-2020, 02:18 PM | #20 | |
alpinweiß
Rep 64
11-19-2020, 05:10 PM | #21 |
Rep 3,752
Buy a classic or 30 yr old car and play with it.
floridaorange10144.00 |
11-23-2020, 07:59 AM | #22 | |
Rep 360
Disconnect: Remove trim to reveal rear engine Under trays and reinforcement plate Fuel to engine at HPFP Wiring harness Bolts of gearbox Bolts to torque converter (support underneath) Coolant drain and remove pipes in and out Drain oil (less weight) Insert towing eye into hole next to oil cooler housing (you need an old one from E series) Air pipe to manifold Intake Manifold Starter motor Vacuum pump to brake line Generally you want everything out of the way then support the engine on a hoist while you undo the nuts on the engine mounts and slowly lift away checking you've not forgotten anything or snagging anything |
