10-23-2020, 07:46 PM | #1 |
Rep 576
Hello, Im a college student and recently purchased a 2012 328i with the n20. I came from an e90 n52, so Ive never done anything to increase performance in a car. So, my question is, what is the best, easiest, most budget friendly way to get my f30 pushing around 300hp? Im assuming thats an easy goal... Not sure if i want to get the BMS Stage 1 or the JB4, or if I want to go FBO or not. Ive also been considering BM3. I use 93 octane gas. Im open to all suggestions, but all said and done (including coils and plugs if needed) I'd like to have spent around $1000 but even less would be great! As always, all help is appreciated. Thanks!
10-23-2020, 07:56 PM | #2 |
Rep 116
Downpipe and JB4. Cheapest and easiest way to make big power gains. With some E mixed in you'd probably be right above 300whp.
erickonphoenix1728.00 |
10-23-2020, 08:13 PM | #3 |
Rep 576
Bootmod3 would only cost me a little more, would it benefit me more than jb4? Ive heard bm3 is alot smoother but Ive also heard the people who have jb4 love it. I plan on getting a VRSF chargepipe which is $220 I believe, so that leaves me with around $800 for a tune and any other bolt ons I may need. But which tune is best and most beneficial?
10-23-2020, 08:20 PM | #4 |
Rep 129
Don’t let people tell you stage 2 will net you 300whp .. because it won’t even a e30 mix might not get you there Fbo. You’ll make around 274-280 whp.. full e85 will get you to that 300 whp. I’m Fbo bigger turbo full e85 around 24 psi snd in around 320ishar goes on dyno Thursday to confirm and see where the cars at
10-23-2020, 08:31 PM | #5 |
Rep 576
Interesting info. So looks like a tune with down pipes will be my best bet and Ill add a charge pipe and diverter valve for peace of mind. So at this point, what are good budget friendly downpipes? Also, JB4 or BM3? Will I need one step cold spark plugs?
10-23-2020, 08:36 PM | #6 | ||
Rep 116
10-23-2020, 08:46 PM | #7 |
Rep 576
Seems I'm wrong, but I thought the n20 f30 made 240hp stock? Either way, seems like 300hp might be hard to reach on my budget. So, what do you guys think of BM3 (stage 1 or stage 2) with the VSRF Sport downpipes, VRSF charge pipe, injen cold air intake and a muffler delete? Also, would I need upgraded spark plugs and coil packs? What about an upgraded diverter valve and boost pipe? If its not necessary I prefer not to do it.
10-24-2020, 08:26 AM | #8 | |
Rep 293
Also, do as much work as you can. Intercooler/Intake and Charge pipe are relatively easy. I have issues getting my downpipe off so I'm having a shop do it. Also check your state emissions, catless will not pas in a lot of states so it can be a pain to replace it every inspection. High flow Cats should pass emissions but you're sacrificing a few HP. |
10-24-2020, 09:09 AM | #9 |
Rep 185
I went with an eBay test pipe ($159.99), a 340i full exhaust (from the cat back) $240, G-plus intercooler $221 and burger motor sports Jb+ $85 used ($199 new). I put down 290whp and 326wtq (dynojet correction) for a total of $706. It would be $820 with a new jb+.
pdxdbo331.00 |
10-24-2020, 10:38 AM | #10 |
Rep 576
Oh wow, thanks for the info! Will definitely look into those. Are you using factory stage spark plugs or one step cold?
10-24-2020, 10:40 AM | #11 | ||
Rep 576
10-24-2020, 10:43 AM | #12 | |||
Rep 293
10-24-2020, 10:51 AM | #13 |
Rep 185
I’m using the factory stock spark plugs. I just added the ftp turbo inlet pipe, the Dv+ diverter valve upgrade, and I just made my own custom air intake, and my car feels a lot faster + a ridiculous more mpg. I’m going to see if I can do a new dyno this week
10-24-2020, 10:54 AM | #14 | ||||
Rep 576
10-24-2020, 10:55 AM | #15 | |
Rep 576
10-24-2020, 12:52 PM | #16 |
Rep 576
So I think what Ive decided to do FOR NOW due to my budget and timing (I go back to school in January) is go with the BMS stage 1 ($379), VSRF charge pipe ($220), maybe a GFB diverter valve ($150) and a muffler delete ($100). This will run me about $700 without the DV and $850 with it, and I already have an intake. Does this sound like something that could possibly get me to the 270s until I can get a flash tune or JB4 with an intercooler and down pipe? Also, any other recommendations or things I should change? Thanks guys
10-24-2020, 01:18 PM | #17 |
Rep 1,065
This is FBO from the youtuber who went from F30 -> e93 M3 -> M2 N55. He also lives in NC.
I think the only thing this guy is missing was the turbo to intercooler boost pipe, but this is with a catted downpipe. Might get a handful more with a catless downpipe, as well as a bigger turbo inlet (FTP instead of MST) and intake (afe power instead of MST). I'll be dynoing my 6MT shortly but I'm waiting for a couple of parts to show up (charge pipe and turbo to IC pipe, arp rods), install, allow for the fuel tables to adjust (usually a gas tank), and will dyno to show FBO catless DP N20 6MT. 271whp/306wtq 8AT Stage 2 93 - starts at 11:20 Last edited by sqwinny; 10-24-2020 at 01:24 PM.. |
10-24-2020, 02:23 PM | #18 | |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
10-24-2020, 02:52 PM | #19 |
Rep 576
Interesting. Well, I do not want to spend over a grand right now so I think what I'm going to do is go the simple route with a tune and a charge pipe along with a muffler delete and I already have an intake. Should I go for the BMS Stage 1 ($379), JB4 ($515) or a flash tune like BM3 ($600)? I plan to eventually go with sport cat or maybe even catless downpipes and maybe a FMIC later down the road but like I said, Im a college student so I dont need to be spending all of my cash on car parts right now.
If any of you guys have a nice setup that cost you less than $1k I'm all ears to new recommendations or options! I guess a more reachable goal would be ~270hp? |
10-24-2020, 03:18 PM | #20 |
Rep 185
Just go with the jb+, the test pipe, 340i exhaust and the intercooler. Everything will set you back only $820 and your at 290whp/326wtq.If you get the ftp turbo inlet pipe $180 from ecs tuning that will put you at exactly $1,000. The charge pipe does nothing for horsepower.
10-24-2020, 03:25 PM | #21 | |
Rep 576
10-24-2020, 03:28 PM | #22 | |
Rep 636
least when I was doing this research it wasn't even a close comparison for a b48. |
