BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > 2BB300 Particulate Sensor Code
      01-06-2020, 01:38 PM   #1
EricD735i
Drives: ‘16 328d & ‘16 X3 28d
Fired up the wife’s X3d this morning and got a CEL. Code 2BB300 “diesel particulate sensor measuring electrode faulty.” Took a run downtown and back on the highway and it went out by the time I got home. I’m trying to figure out which sensor this is and if it’s covered under a 10 year/120k extension - I have a letter somewhere stating there was an extension on a sensor (not NOX) that I need to dig up. If it’s not covered I’ll look at replacing it in the near future. Can someone verify that #13 on the RealOEM diagram is the sensor causing the issue?
high quality photo upload
img hosting
      01-06-2020, 05:17 PM   #2
AlpineX
Drives: Diesel
Particulate matter sensor is included in carb or federal emissions extension. 13
      01-06-2020, 06:34 PM   #3
EricD735i
Yeah, did some research and it appears covered for 10/120 on the X3 (but not on my 328d for some reason).
      01-15-2020, 04:31 PM   #4
EricD735i
Update - dealer replaced no charge under a 10/120 warranty extension. Again, this is the X3d, not my 328d.
      08-21-2020, 08:26 PM   #5
CTMike
Drives: 2021 X5 40i MSport/2011 E93 M3
So I had this code on my F31 328d and the dealer said it required reprogramming. Picked it up today... no more check engine light, but I’m pretty sure my KermaTDI tune is gone. The pep was gone. I’m debating if I want to apply the tune again or not.
      10-02-2020, 12:16 PM   #6
CTMike
Check engine light came back, same 2BB300 Diesel Particulate Sensor Electrode Faulty code... this time, the actual sensor was replaced under warranty.
      02-07-2023, 03:46 PM   #7
Paul80
Drives: BMW X5 F15 X40d msport
same code 30EC00 and 2BB300
Writing from 2023 if any of you still have these cars.
I have an X5 40d and same codes. Trouble is, none of the local garages will touch it and we're in the UK so no recall yet for the PM sensor.
I was going to attempt replacing myself. Eric, did you get confirmation that is was no 13 from the dealer? The one after the CAT?
I got a bit confused as there are sensors before the DPF, after the DPF and after the CAT...but no mention which one is the Particulate sensor...
      07-21-2023, 05:22 PM   #8
gsek2001
Drives: BMW 328d Xdirve
P24ae-2bb300
Hello
Greatly appreciated if someone help:
2014 328D drive N47 engine
Error Code: P24AE, 2BB300
Let me know
      08-06-2023, 05:57 AM   #9
raducris
Drives: 2015 BMW X5d
2015 X5d  [0.00]
Hey Paul, have you figured which sensor it is? I'm having the same error and ISTA ABL points to this sensor but I can't figure its location on the car
      12-20-2023, 07:52 AM   #10
raducris
2015 X5d  [0.00]
Yes, it is #13, not covered in Canada for my N57 engine
