11-12-2019, 03:43 PM | #1 |
Rep 65
Replacing rear tyres only on xdrive
I have a 435d running on PS4S tyres, the fronts are still in good shape with around 5mm tread left but the rears are down to about 3mm. Am I going to be ok to change the rears only without the xdrive getting out of shape, I’m sure I read on another thread that 2mm difference between tyres should be fine
Thanks |
11-12-2019, 04:40 PM | #3 |
Rep 5,681
If you're going to mix new tyres with roughly 8mm of tread with used tyres that are already down to 5mm that's a 3mm difference (and potentially I think that's starting to get marginal with X-Drive).
As an aside, I'm surprised you've experienced such a difference in wear between the axles - the tyres on my 335d have always worn at an almost identical rate and hence come replacement time it's been a case of changing all four and not just a pair.... |
11-13-2019, 07:22 AM | #4 |
Rep 609
Drives: F31 330D xDrive MPPK ACS
In 100k miles I have regularly replaced PS4 tyres when either front or rear has been down to the indicators and the other end has still had 3mm. That is what I am running just now - fronts brand new, rears on 3mm. Never had any issues.
BMW sold me an AUC xDrive with new tyres on the front and 3mm left on the rear.
F31 Mineral Grey 330d Xdrive, ACS, Adaptive, MPPK.
Gone but not forgotten: 1967 Triumph GT6 Mk1 (6 pot 2 litre widowmaker) 1966 Triumph TR4A (4 pot 2.2 litre, huge torque, lovely car) 2004 Audi TT 3.2 DSG Quattro (weak springs & nose heavy) 2006 VW Golf GTI (brilliant on good tyres) Last edited by 1966-TR4; 11-13-2019 at 07:29 AM.. |
MalcolmT9.00 |
11-13-2019, 08:34 AM | #5 |
Rep 782
Drives: 2018 F80 M3 CP YMB
I didn't ever have issues on the 335d xDrive I had for 70k miles - although I kept to runflats, I didn't stick with * marked and I always needed to replace fronts sooner than rears. I was on staggered wheels where, on non * marked tyres there will already be a difference in rolling circumference (fronts will be slightly larger), so changing fronts first had a greater risk of exceeding xfer box tolerances but it was fine. Therefore I would think it very unlikely you will have issues changing rears first whether on staggered or not. A square setup will generally be even less susceptible as the RC will at least start off the same (assuming same tyres). As has been said if there is an issue first check pressures & look to increase front/reduce rear...
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
MalcolmT9.00 |
11-13-2019, 02:00 PM | #6 | |
Rep 5,681
MalcolmT9.00 |
11-13-2019, 02:23 PM | #7 |
Barge driver
8618
Rep 12,401
I've just put a set of rears on my xdrive the fronts are at 4mm rears now at 8mm? (not sure of the new tread depth) no issues and it was done at my BMW dealer, across the same axle is an issue though.
730d/Z4C
MalcolmT9.00 |
11-13-2019, 02:27 PM | #8 | |
Rep 15,858
MalcolmT9.00 |
11-13-2019, 03:16 PM | #10 | ||
Rep 5,681
MalcolmT9.00 |
11-13-2019, 03:36 PM | #11 |
Rep 940
I'm struggling to see how reducing the tyre pressure leads to the circumference of the tyre reducing.
Sure, the radius to the point of contact with the road may reduce as it squashes to the tarmac but, as the car rolls forward, surely the distance travelled by the tyre to rotate it 360 degrees is the same as when it was inflated to the higher pressure. Or is it that the carcass of the tyre actually expands slightly at operating pressures (compared to being uninflated), so reducing the pressure (slightly) causes the tyre to reduce its circumference. Thoughts please. |
MalcolmT9.00 |
11-13-2019, 03:41 PM | #12 | |
Rep 291
I fail to accept that the tolerances are so tight in the transfer box that they can't cope with slight variations... Every flippin bend means the wheels are all rotating at different speeds all the time anyway! So for everyones sake, please don't adjust tyre pressures, especially for this nonsensical reason. Pretty please! |
MalcolmT9.00 |
11-13-2019, 04:29 PM | #13 | |
Rep 15,858
You could measure the change... roll the wheel onto a flat plate, measure to the wheel centre (or rim lip). Lower the pressure in increments and measure again. That would give dimensions of the static radius at defined pressures, something to do the maths on. |
MalcolmT9.00 |
11-13-2019, 04:35 PM | #14 | |
Rep 15,858
Remember there is a lot of 'scuffing' that goes on, as tyres rotate through the contact patch, low pressures making wear rates (and heat) worse. |
MalcolmT9.00 |
11-13-2019, 04:54 PM | #15 | |
Rep 3,967
MalcolmT9.00 |
11-13-2019, 05:25 PM | #16 |
Rep 792
I think summer tires usually start with around 8mm.
As said by Highlandpete, playing with pressure is just a tweak, just in case. It fixes a problem with my Mrs 1series. Tyre pressures aren't an exact science, especially changing away from manufacturer load rating and to a non RFT. Most people here are probably still running their MPS4S on RFT pressures when they should be dropped 3 to 4 pounds! Id hardly put it in safety affecting territory! |
MalcolmT9.00 |
11-13-2019, 05:56 PM | #17 | |
Rep 7,028
Drives: 335xd Msport +
Presume the stiffer side walls would/should negate the extra low pressure bulge
MalcolmT9.00 |
11-13-2019, 06:04 PM | #18 |
Rep 3,967
Unfortunately a lot of tyres are now only around 7mm new. This review on the tyre reviews website measured new PS4 tyres at 7.2mm http://www.tyrereviews.co.uk/Tyre/Mi...ot-Sport-4.htm
MalcolmT9.00 |
11-14-2019, 03:06 AM | #19 |
Rep 15,858
Run-flat tyres still deform with lower pressure, much less of course. Indirect TPWS works with run-flats, (my car uses it) measuring the change in RC as pressure drops.
11-14-2019, 08:48 AM | #20 |
Rep 1,703
Remember that if you run a staggered set up, 255 rear and 225 front they don't have the same rolling circumference from the start (in theory) The 225''s have a 5mm bigger rolling circumference and are 3mm bigger in diameter, so in theory the more the rears wear the bigger that gap gets between front and rear....so there must be a tolerance in the transfer box to allow for that. They don't keep failing just because you have worn off some rear tread.
Fronts and rears will only truly be running at the same speed when new tyres are fitted to the rear at say 7.0 mm of tread and the fronts have worn down to 5.5 mm giving the same diameter tyres and allowing for the 3mm diameter difference. I think the box can handle new rear tyres....and in the OP's situation will have a nearer rolling circumference than when the tyres were all new....in theory. In practice tyre sizes can vary massively due to allowable tolerances. Last edited by sensible; 11-14-2019 at 10:33 AM.. |
MalcolmT9.00 |
11-14-2019, 09:31 AM | #21 |
Rep 298
Where did these numbers come from? In any case the tyre markings are not accurate to the millimeters, you can have significant differences between different models and brands no matter what a calculator says. That is why the safest bet for staggered setup is to use BMW star marked tyres as the assumption then is that they will be matched.
MalcolmT9.00 |
11-14-2019, 10:02 AM | #22 | |
Rep 1,703
I did a Tyre Technical course a few years back at Michelin and you would be surprised at the tolerance of tyres, they have quite large margins +\- . Tyre's of the same size can vary massively from one manufacturer to the next. (One reason not to mix brands). I will dig out my book and post the variance of say a 225 tyre for example. My point is that it is not an exact science, and it is really splitting hairs to worry about replacing the rear tyres and modifying tyre pressures to compensate. (Even the 255 rear tyre is on an 8.5j wheel which isn't the ideal size for that wheel.) |
MalcolmT9.00 |
