07-31-2020, 07:32 PM | #1 |
Rep 1,172
Car won't start after failed Bootmod3 flash
Hey guys.
So I've been using stage 1 91 octane then I found some 93 gas so I decided to flash 93 map. But it sort of went through but bootmod3 was unable to clear the codes. As a result I can't turn my car on. The car goes to ignition on mode but I can't turn the actual engine on. I read through some posts but nothing has worked so far. 1. Disconnect negative terminal for 10 minutes then try to reflash 2. Reflash using the force reflash and unlock option (suggested by BM3 support) 3. DME reset under diagnostic then reflash 4. Use laptop and iOS to see if it was the devices. So I'm at my wit's end here. I've been waiting for my insurance company to find me towing for the past half hour with no luck so I'm kind of stuck at a parking lot with no public transit either. In hindsight, I should've done this at home but since my first flash went so well I didn't think it would go all SNAFU on me. I'll probably end up calling a friend to ask if he can give me a ride home and then maybe back to the parking lot but I still need to fix it and PTF is closed for the weekend. Any help would be great.
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
08-01-2020, 04:14 PM | #2 |
Rep 3,748
What happened during the flash? Did it finish with 100% complete turn off car wait 5 sec then start the car or it got stuck somewhere and it got interrupt?
Asking because it happened to me 2 night ago. |
08-01-2020, 04:17 PM | #3 | |
Rep 1,172
Then it proceeded to go all the way to successfully finished but in like 3 seconds so I knew something wasn't right even though it said successfully finished. Now it just fails before start according to the dialog box. Currently have battery on charger at home. I had to take it out of the car as I live in an apartment and that was a pain due to the lower battery bracket thing...
2020 X3 M40i
08-01-2020, 04:37 PM | #4 |
Rep 3,748
This is what I did to mine per PTF said to update the agent but I have the newest again installed so I went to doing the following
Turn of your antivirus/internet security software. Uninstall the current agent Install a freshly downloaded new agent. Then try again to reflash the car. Maybe this will work for you too. Be sure the internet security is off and also disable the windows defender while your at it. |
08-01-2020, 11:51 PM | #5 | |
Rep 3,748
08-02-2020, 08:03 PM | #6 |
Rep 1,172
Well, it wasn't the battery.
Bootmod support suggested it was a faulty ENET cable so I ordered one but ZGW Search tool was able to the car just fine. So upon doing some searching it seems on bootmod3 enthusiast facebook group, Zed coding seems to have helped many people recover from something similar to what I experienced, and so I reached out. And now within 4 hours of contacting him, my Yanny is back to life! Albeit with a stock tune, but I think I'm going to keep Yanny in the current form for now. Here is link to the fb. It took Zed an hour plus but it finally worked! https://www.facebook.com/zedcoding/
2020 X3 M40i
08-02-2020, 08:38 PM | #8 |
Rep 1,172
I think something went wrong during flashing where it put it in like a weird mode. The coder didn't tell me exactly how the stock tune was flashed, but it was an hour+ session and told me the software was rejected when he went through regular ways.
Which makes sense because when I went into E-Sys before going to the coder to see if it really is the ENET cable, it could connect to the car just fine but when it came to ECU part, it just gave an error saying value null or something like that.
2020 X3 M40i
08-02-2020, 10:18 PM | #9 | |
Rep 764
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
03-21-2021, 08:46 PM | #10 | ||
Rep 29
Same or similar problem, tried to reflash my stage 2 93 OTS map to improve burbles and get GTS roar (in retrospect idk if that is even available for N55, but it was an option) the flash didn't go through, failed 2 times at 1%, reflash to stock failed at 14%. Car won't start. There are various malfunction messages on the dashboard. Charged my battery with a 30amp charger, kept the charger hooked up and tried to reflash again Stage 2 - failed, no % progress displayed. PTF advised to go to stock next - failed at "clearing codes" stage. Luckily PTF have been super responsive and looking for a workaround to get my car to start. If anyone has some suggestions, please let me know! No recent BMW updates, car was running stage 2 flawlessly for several months! I flash through my iPhone. |
03-21-2021, 10:36 PM | #11 |
Rep 732
floridaorange10150.00 |
03-21-2021, 10:43 PM | #12 |
Rep 29
03-22-2021, 08:48 AM | #13 | |
Rep 732
Laptop will sort you out. |
03-22-2021, 06:45 PM | #14 |
Rep 33
What does that even mean? I do it all the time through my iPhone and the MHD wireless dongle, never had an issue in 10 plus flashes.
2013 335xi F30 - Mineral White Metallic
03-22-2021, 06:56 PM | #15 |
Rep 1,239
Apple are always updating their security, most likely something has been changed in the phones soft wear and could now be giving you issues. Laptop is always the better way to do it!
03-22-2021, 09:13 PM | #16 |
Rep 174
Drives: BMW 430i GC
My car went through this same problem. If the dealership has recently updated your system. The DME(ecu) will fail cause the vehicle to not start. The new update flags cars with flash tunes. Only way to get it fixed is at the dealership, they will reset the DME(ecu)
03-22-2021, 10:42 PM | #17 | |
Rep 29
I have a remote session scheduled with PTF tomorrow who will look into the issue remotely. Will keep you all posted! |
03-23-2021, 04:14 PM | #18 | |
Rep 1
just registered to note that i am having the same problem as everyone here. have a new m4 (2019) tried to flash on bootmod3 after unlocking the ecu and it fails at 1% and now i cannot start the car as the ecu is corrupted. will be looking through it with bm3 support tomorrow, but not holding my breath as we all seem to have the same problem. likely going to have to end up taking it back to bmw |
03-23-2021, 04:44 PM | #19 | ||
Rep 174
Drives: BMW 430i GC
03-23-2021, 05:01 PM | #20 | |||
Rep 7,606
03-23-2021, 05:40 PM | #21 | ||||
Rep 174
Drives: BMW 430i GC
03-23-2021, 05:55 PM | #22 |
Rep 1,508
