BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > powder coating brake calipers
      08-04-2018, 08:32 AM   #1
f32ftw
f32ftw's Avatar
Drives: BMW 435 xdrive
I have the blue m sport brake calipers on my 2014 435 and I'm getting them powdercoated soon. I was quoted $500, this includes removing, disassembling and reassembling. Is this a good price?
      08-04-2018, 04:41 PM   #2
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
As a comparo, I pay $200 to pc calipers at my local shop, but I have to remove them, disassemble and assemble myself for that price
      08-05-2018, 09:12 PM   #3
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Man if you already have the factory blue brakes why ruin them with a 3rd party refinishing?
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
      08-06-2018, 06:29 PM   #4
f32ftw
f32ftw's Avatar
I just want to be different as I see a lot of 435's have the same blue M sport brakes. I'm powder coating the OEM wheels black and the calipers yellow. Do you guys think I would be better off getting them painted instead?
      08-07-2018, 11:46 PM   #5
EvenKeel
Drives: Sedan
Frankly, you'd be best off leaving well enough alone. There are tons of folks on here that would kill for the Blue MSport Calipers.
      08-08-2018, 07:47 PM   #6
strobe89
strobe89's Avatar
Drives: 2013 M3 + 2015 335i xDrive
Gun is loaded.
      08-08-2018, 08:24 PM   #7
Mike.
Mike: Everyone's Pal
Mike.'s Avatar
Drives: F80 M3
2013 BMW 335xi  [10.00]
i got raped on the price, but i love mine
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix
      08-09-2018, 09:45 AM   #8
f32ftw
f32ftw's Avatar
Do you have pics? What did you end up paying? Did you powder coat them or paint them?
      08-10-2018, 12:01 AM   #9
tonirai
Portugal
Drives: F20 LCI 120Da M
I will be powder coating mine too - I bought a set of M Sports on ebay, for a good price with some paint damage (which didn't matter because I already had the intention of changing the color).
I will stick to BMW OEM colors...
But the blues are too common and "invisible", and I don't like the reds.
So yellow or orange it is - pending to orange.
But my big problem will be finding powder which will match close enough... not so easy in my country, and impossible to do the matching "remotely" (with a USA powder supplier, for example)...
      08-14-2018, 08:55 AM   #10
Mike.
Mike.'s Avatar
Drives: F80 M3
look in my build thread, or my powder coating thread.
$800.00 I got them PC'd
      08-14-2018, 10:50 AM   #11
Savageenterprise
Drives: 2008 M3 (E93)
Not to jack your thread but how do you think color matching my calipers would be? car is BSM and was thinking I could get a powder coat very similar to match. thoughts?
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
      08-14-2018, 01:18 PM   #12
sickF30
Drives: F30 335i
Don't let people's personal opinions deter you from doing what you want to do on your car. Some people are scared to turn their own wrenches.
Brembo's are easily rebuildable, so painting/powder coating them is not an issue at all. It's very common.
I had mine painted Porsche Acid Green.
      08-14-2018, 01:21 PM   #13
sickF30
Drives: F30 335i
Get them painted instead so that it matches perfectly.
      08-14-2018, 09:42 PM   #14
f32ftw
f32ftw's Avatar
That looks great! My car is also Estoril Blue. What do you think of this color? Do you think it would look good with my wheels?
      08-15-2018, 05:00 AM   #15
tonirai
Portugal
My car is also BSM. To match perfectly with the body, there's nothing like painting.
Original caliper color (blue, yellow, orange, red) is another matter, because those aren't bmw colors, those are brembo color for bmw, which nobody knows the exact composition or code (only conclusion I've seen is Estoril blue is a good match to the blues, and Phoenix yellow for the yellows is pretty close, too).
Bottom of line is, if you want body color, use body paint.
      08-15-2018, 03:23 PM   #16
sickF30
Drives: F30 335i
Do it!!!
      08-17-2018, 10:54 AM   #17
f32ftw
f32ftw's Avatar
So $500 to remove the calipers, sandblast off the OEM paint, disassemble, powder coat and reassemble. I guess if the price sounds reasonable then I'll go ahead with it.
      08-17-2018, 04:59 PM   #18
draggy
sucka for a longroof
29
Drives: F31
Would you mind sharing where and what's the shop this quote is from? Thanks
      08-17-2018, 09:09 PM   #19
f32ftw
f32ftw's Avatar
Need Powder Coating located at 27 Libella Ct, Newark, NJ 07105. Are you looking to get your calipers done too? What do you guys think of Brembo decals instead of the M decals? These brakes are Brembos after all. My wheels and valve stem covers already have the M decal on them.
      08-20-2018, 02:52 PM   #20
draggy
29
Drives: F31
I'm torn between powdercoating and painting. If you want something different go with the brembo decals. It's yours to customize.
      08-20-2018, 11:09 PM   #21
sickF30
Drives: F30 335i
I went with Brembo stickers.
      06-16-2021, 09:53 AM   #22
delorean175
Drives: F30 335i Msport, 1982 E28 528e
Hey guys, I'm in a similar boat, paint or powdercoat. I'm upgrading my rear brakes to the Blue 345's. My fronts are the non painted Brembo's. I really hate to strip off that nice blue paint for the rears but I don't know how well I can color match. I'll be doing the painting or powdercoating myself. I have the ability to do either, I have a little hands on experience with painting and powdercoating. I'm not very picky about color, so long as all 4 match.
