09-08-2019, 07:23 AM | #1 |
Rep 155
G30 Screen on F30 retrofit
Hi! Has anyone done this retrofit? G30 screen on F30, with NBT (non evo) navigation system? If so, did it require some wiring changes, dash cutting or something else? Do you have some photos of the final result?
09-08-2019, 08:32 PM | #2 | |
Rep 10,473
09-08-2019, 09:01 PM | #3 | ||
Rep 155
09-08-2019, 09:03 PM | #4 | |||
Rep 10,473
09-08-2019, 09:14 PM | #5 | ||||
Rep 155
EDIT: found this on google |
09-08-2019, 09:21 PM | #6 |
Rep 10,473
I'm sure it could be done but MAJOR work would need to be done on CID, Plastic on the rear of the CID, dash surface and under the dash.
AlbertoSONIC97.50 |
09-08-2019, 10:00 PM | #7 | ||
Rep 155
Btw, isn't that a G30 (M5) steering wheel on an F30/F32/F80/F82?? |
09-08-2019, 10:05 PM | #8 | |||
Rep 10,473
09-08-2019, 10:11 PM | #9 | ||||
Rep 155
09-08-2019, 10:12 PM | #10 | |||||
Rep 10,473
09-08-2019, 10:22 PM | #11 | ||||||
Rep 155
09-08-2019, 10:24 PM | #12 | |||||||
Rep 10,473
More like retrofitting a F80/M3 Wheel. |
AlbertoSONIC97.50 |
09-08-2019, 11:09 PM | #13 |
Rep 3,535
IK6SPEED4486.00 |
09-08-2019, 11:25 PM | #14 | |
Rep 10,473
09-08-2019, 11:45 PM | #15 |
Rep 10,473
For clarification, the silver trim can be removed and painted any color to match your trim....blue, black, coral red....whatever.
09-09-2019, 06:12 AM | #16 | |
Rep 155
09-09-2019, 06:14 AM | #17 |
Rep 155
11-18-2020, 11:53 AM | #20 |
Rep 31
I tried retrofiting this screen with no success. Using esys I coded 3005 DISPLAY_PIP_CONFIG>CID_DISPLAY_RES to 1440x540 and 3005 DISPLAY_PIP_CONFIG>CID_DISPLAY_SIZE to 10.25. The screen stays blank and changing the CID_COM_MODE to SPI makes it turn on but with a no signal on the display. My headunit is an nbtevo2.
11-18-2020, 05:25 PM | #21 | |
Rep 48
CID_DISP_AR = ratio_1_07 CID_Touch = aktiv CID_APIX_MODE = apix2 CID_COLOR_DEPTH = 24 CID_COM_MODE = mii CID_DISPLAY_RES = 1440_540 CID_DISPLAY_SIZE = 10_25 CID_HMI_TOUCH = aktiv would guess you´ve forgotten to change color depth |
11-18-2020, 10:03 PM | #22 | |
Rep 31
