06-17-2021, 12:11 AM | #23 | |
Rep 319
I had a 17 plate Corsa with 75k miles on it for a day and the interior wasn't making half of the little rattling noise that bmw does. |
06-18-2021, 10:19 AM | #24 |
Rep 319
Something just popped in my head.
My old 2013 F20 had a minor steering rack knocking issue (although not as severe and only when going over the speed bumps) which I solved by tightening up the washer looking bolt with three holes in it. Since my garage say that the knocking on my f30 is caused by the inner tie rods I started thinking if it could just be as simple fix as it was on my f30. I had a look at the steering rack and it looks like this one doesn't have the three holed bolt, it has a normal bolt which looks like it could be tightened up using just a normal socket wrench. Now my question is... do LCI models still suffer from that steering rack problem? I know it was very common on pre-lci models and there's even a repair kit for it but nothing for the LCI models. Can't do anything at the moment because the engine is super hot so I need to wait for it to cool down but is there any point even bothering? Thanks. |
07-04-2021, 06:10 PM | #25 | |
Rep 7
07-05-2021, 02:58 PM | #26 | |
Rep 319
Yes. It turned out to be the inner tie rods that were knocking when they got some heat from the engine. I had both inner rods replaced together with the track rod ends 2 weeks ago and had no knocking since then. Another guy on a different forum had exactly same issue on his F20 and when I told him about my fix he did the same on his car and had no knocking since then too. |
05-22-2022, 12:12 PM | #27 | |
Rep 125
Drives: 2020 m340i RWD
05-24-2022, 12:36 PM | #28 | |
Rep 319
Had the car warmed up, made sure it was knocking. Took it to an indy and they found what it was. Replaced inner tie rods and outer rod ends. Been quiet since then. |
05-24-2022, 06:17 PM | #29 | ||
Rep 125
06-16-2023, 03:42 PM | #30 | |
Rep 3
Noise is driving me ****** nuts |
06-16-2023, 04:13 PM | #31 | |
Rep 319
But here's the thing. I've done less than 10k miles since I had them replace and the O/S one is knocking again. Taking it to the garage next week. Frustrating to say the least. I was told if it's just one side that needs doing were looking at £250+. Getting enough of this car to be fair. |
06-16-2023, 04:27 PM | #32 | |
Rep 981
The repair kit wasn't released until 2019 if I remember correctly, so that's well into LCI territory, and is the same parts for all Fxx cars with the ThyssenKrupp rack. The main component of the repair kit is a different grade of composite tensioning block material with what I assume to be PTFE pad inserts, as opposed to the original one piece solid block of unknown material. The original block's contact surfaces had holes in them to retain grease, and these wear down over time, whereas the newer block doesn't, so there's an element of natural lubricity at play....kind of like oil impregnated bronze bushings on steel. The newer block also has 2 O rings. The original didn't. No idea what they're for. Perhaps to keep the grease on the rack's sliding surfaces instead of sliding up past the block, not sure. FWIW, I drove a 2022 420d recently, with only 7000 miles on it, and it was exactly the same as my F30. Same knocking over certain bump/speed ramps etc. One would assume such a new car would be as tight and optimal as it could be. From my own experience, I have yet to drive any 2003 onwards BMW that doesn't have some kind of unwanted feedback through the steering, and my previous VWs with a ZF steering rack were exactly the same. I think the play/backlash, what we hear and feel through the column, is intentional to avoid harsh kickback through the steering column. Obviously the knocking could be something else....worn bushings, shot top mount bearings, tie rods, drop links etc etc, but the rack bears the brunt of the blame. Kudos to BMW though for offering a repair kit at a reasonable price. At one point they were replacing the entire rack to cure the 'acoustic anomaly' |
06-18-2023, 04:05 AM | #33 |
Rep 452
Check and tighten bolts on these brackets...they loose over time and rubber mountings are highly temperature sensitive
https://www.realoem.com/bmw/enUS/sho...diagId=31_0951 |
06-18-2023, 09:38 AM | #34 |
Rep 319
The cause of mine knocking again is the os inner tie rod. This was lighlighted on last mot. I also believe they're are other issues... Probably top mounts, maybe some other bushings. I don't know. Either way this has been for the past 2 years as bad as my Renault Laguna 2 That i owned 13 years ago. Endless visits at the garage with new problem every few months.
I'm actually considering giving up on bmw and going japanese. |
07-07-2023, 03:52 PM | #35 |
Rep 981
Yeah the rack often gets the blame first, but isn't always that.
Tie rods, top mounts and bushings are relatively cheap and easy fixes, which fail on all cars. Totally understand the desire to move on once the frustration kicks in. Unfortunately BMWs require the ultimate maintenance to match the 'Ultimate Driving Machine' marketing spiel. Quite honestly, every time I drive my 2009 Golf 2.0 TDI, I wonder why BMW have the reputation for quality and (cough) reliability that they do, but in spite of everything, Bimmers have a certain something about them other cars don't have. Good luck with your next steed. Hope it's a BMW engined Supra.....joking |
07-07-2023, 04:15 PM | #36 | |
Rep 319
My "trusted" mechanic wanted £280 for the job. Another garage I contacted insisted it was the rack even without inspecting the car even tho I told them several times that it's not the rack. As you can imagine I gave up with that garage and moved on. Then decided to fix it myself and this was the best thing I could do. Not only saved quite a lot of money but also had some fun doing it. |
V330d25.50 |
07-07-2023, 05:58 PM | #37 | |
Rep 981
Yeah I find the F30 incredibly easy to work on compared to a lot of other brands I've worked on in the past. The cost savings DIY are immense. And doing it yourself you know it's done right as a lot of garages cut corners. |
kierownik90.50 |
