05-31-2021, 05:58 PM | #1 |
Rep 15
KW Street Comfort coilovers bottoming out too easily - F31 wagon
I have a 2017 330i Touring and put KW Street Comfort coilovers onto it about a month ago. The car seems to slam pretty hard into the bump stops if I hit a moderate dip or pothole above 30 mph. I'd like to eliminate this but I'm not sure what I can do at this point. I've tried raising the ride height to create more damper travel, but this hasn't helped much. I'm now at the maximum height that KW allows in their installation instructions. The dampers are at 15 out of 21 clicks towards the stiff side right now. I've slowly been increasing it, but there isn't much adjustment left.
I'm not a suspension expert by any means so I'm hoping somebody might have some insight. It just feels like the springs are too soft or there isn't enough travel in this suspension. The shock has about 0.5" of travel before the bump stop engages. Even on an average road where the car doesn't slam down hard, the shock still ends up making contact with the bump stop from time to time. I assume it's just compressing the softer part of the stop and it doesn't quite reach the hard part where there's no travel left. These are the KW bump stops that came with the kit. There aren't any unusual marks on the coil springs, so I don't think the coil is slamming together and losing all travel. Is there much I can really do? Continue tweaking my ride height and damper stiffness? Find a kit with more suspension travel? Does one even exist? I went with the Street Comfort kit because I only wanted a small ride height drop. I have an Integra lowered on some Tein springs and KYB shocks, it hasn't bottomed out once on these same roads where my 330i will bottom out every couple days. I feel like I expected more from the KW kit compared to some cheap springs and shocks on an Integra. |
05-31-2021, 06:03 PM | #2 |
Rep 10,256
Were the coilovers brand new when installed?
Very unusual problem. My previous car had KW Street Comfort coilovers without any problems / symptoms as described. Did you install these coilovers by yourself or was the installation performed by an experienced shop? |
05-31-2021, 07:50 PM | #3 | |
Rep 15
06-01-2021, 12:04 PM | #4 |
Rep 3,540
From the video it seems like your bottoming out issue is only in the front, right? I would check your springs for evidence of coil bind. You should see marks on the tops/bottoms of the coils from them slamming into each other if you have it. This can be done just looking through the gap between the tire and fender with a flashlight, or if you need to, jacking that part of the car up to create a larger gap to see through. You get a bottoming out effect if the spring runs out of travel and goes to solid block height.
Counter-intuitively, raising the ride height makes coil bind worse, because you're moving the bump stop away from engaging. If you're getting coil bind you actually want to lower the front so the bump stop can engage sooner. Alternatively you can put packers/shims on the damper shaft to effectively make the bump stop longer so it engages sooner. You want your bump stop to engage soon enough to prevent coil bind. The other thing you can do is move to a stiffer front spring to get less compression, and have more compression stroke. On the damper adjustment side, going stiffer commonly makes things worse. This is because the dampers are heavily rebound biased, which means the damper wants to keep the spring compressed instead of letting it extend back. So what happens when you hit a dip like in your video is the spring and damper get compressed when the tire hits the bottom of the dip, and then stays compressed hitting the exit/rising edge of the dip which compresses things even more. It also has the same effect hitting a bump. You hit the bump, damper/spring compress, and then stay compressed coming off of the bump with the wheel/tire maybe not even being on the ground, so the front end falls to the ground (think like when you ride your bike off of the sidewalk curb).
06-01-2021, 12:26 PM | #5 |
Rep 472
I had the same exact bottoming out issue with KW SC coilovers on my 328 xdrive and ended up selling them and switched to eibach pro kit springs with Koni special active struts. The whole process was very frustrating and cost me a lot of money. Check out some of my posts on this same topic I believe there's a separate thread on it.
turtlepower5.50 triax37130.00 |
06-01-2021, 03:18 PM | #6 | |
Rep 15
Unfortunately, my car is already much lower than I expected. KW says that the kit lowers the car 0.4" - 1.6" at the front, but in my experience it's been more like 1" - 2.2". If I have to do significant lowering to eliminate the coil bind, then I feel like the ride height will no longer be practical for a daily driver. As a result, I did some research last night (including reading a few of your very helpful posts!) and might go for some Eibach springs and Koni shocks like rcaso26 suggested. In particular, I'm considering the E10-20-031-15-22 or E10-20-031-16-22 spring kits. The 15-22 kit is supposed to lower the car 30mm front / 15mm rear. The 16-22 kit has front springs for the six-cylinder cars that are a little stiffer, and I'm estimating that they would lower the car around 23mm front / 15mm rear. Right now I'm leaning towards the stiffer springs for a little extra height. The shocks would probably be either the red Special Active or the yellow Sport shocks. Last edited by turtlepower; 06-01-2021 at 03:30 PM.. |
rcaso26331.00 |
06-01-2021, 04:30 PM | #7 |
Rep 472
reach out to johnung or check out his numerous posts on this topic. He has done a ton of research on the eibach / koni combination and is very helpful.
06-01-2021, 04:58 PM | #8 | |
Rep 10,256
06-01-2021, 05:04 PM | #9 | ||
Rep 1,934
06-02-2021, 03:37 PM | #10 | |
Rep 15
I lowered the coil perch and softened the damping to eliminate the coil bind. The car still hits just as hard as before over that same bump from the video, so I don't think coil bind was the primary problem. The coil bind issue should now be solved, but still no success in keeping the car from bottoming out.
06-13-2021, 11:45 AM | #11 |
Rep 1,369
Wouldn’t having one strut deeper into the knuckle affect the anti-roll bar? Effectively your anti-roll bar is always loaded even when the car drives straight.
It has been my observation that in order to remove a strut from the knuckle many apply a lubricant. That’s fine but before reassembly that lubricant needs to be removed. BMW makes a big deal about no lubricants in the knuckle-strut mating area. As Logicoeur mentioned, left and right do need to be the same. They are tied together by the anti-roll bar. |
turtlepower5.50 |
