06-13-2021, 01:51 PM | #1 |
Rep 611
Closed air intake duct
I recently realized my car is one of those that hasn't the typical air intake with grille behind the left kidney, but it's closed (see the pic). The realoem also shows the parts 14 & 15 are not in my car, and the duct intake is straight from the front (see the other pic).
Even after quite extensive research, I haven't found any definitive answers to a few of my very basic questions; hope somebody can help, please: 1. While having straight and not exposed intake can make perfect sense, from where it actually sucks the fresh air? 2. Is it worth changing it for the more usual duct from behind the kidney grille? 3. What happens, when a significant amount of water (from rain, snow, or wash) gets into the intake? |
06-14-2021, 06:54 AM | #2 |
Cheapskate
4447
Rep 4,993
It pulls air from behind the headlight.
It won't provide a noticeable hp gain but it's nice to have. The intake box has a flap on the inside, so if the grille gets blocked by snow then it can still suck in air from the engine bay. If you're in a situation where water is going into the intake then you have other issues and that cap won't change anything. |
J555568.50 |
06-14-2021, 11:11 AM | #5 |
Rep 1,641
I have the typical North American version with the vent. I have not had any issues while driving in the torrential rains that often occur in Louisiana and Texas. There are drain holes I believe that do drain water should it enter the front part of the vent.
I can tell you what happens if you get a lot of water in the intake. You hydrolock your engine and need a new engine. That is why I have and F30 and not an e46. My wife got caught in our old bmw in an unexpected high water situation because of a clogged storm drain and did not realize how high the water was since this was near our house and had not happened before. She was hoping to go slow but saw the truck in front speed up and so she did as well. A wall of water hit the front end and a lot of that water got sucked into the intake; through the filter and into the engine. Net result, dead engine and a new car needed. |
alohasurftoad3076.50 J555568.50 |
06-16-2021, 05:50 PM | #6 | |
Rep 611
Thanks a lot for all your comments and suggestions, guys!
As we have some heavy rains or snowing during the year, it sounds wise to keep it as it is. Especially if no significant gains can be expected. Quote:
06-16-2021, 06:11 PM | #7 | ||
Rep 1,641
J555568.50 |
06-17-2021, 06:16 AM | #8 | |
Rep 437
CajunBMW is talking about driving into deep water and sucking it in, not heavy rain. |
J555568.50 |
06-17-2021, 06:25 AM | #9 | |
Rep 611
06-17-2021, 08:21 AM | #10 |
Rep 3,869
I've seen people revert back to the bumper intake. Mine is also "open", in the engine bay.
There must be some advantages of sucking outside air instead of hot engine bay air, I'd think..... At least for the 40i engine - have you noticed the temperature under the bonnet... after just a normal ride? I can barely touch my right fender.........
J555568.50 |
06-17-2021, 11:20 AM | #11 | |
Rep 1,641
Wires1645.50 |
06-17-2021, 11:22 AM | #12 | ||
Rep 1,641
Th3Walrus340.50 |
