11-16-2018, 10:30 AM | #1 |
Rep 118
2018 340I Xdrive Manual Gearbox max torque load
Does anyone know what the max torque load is for a manual gear box on a 2018 340i xDrive?
Thanks for your time. |
11-16-2018, 12:43 PM | #2 |
Rep 5,992
355 lb ft if going by mppsk for manual transmission. The unit in the M3/4 would be able to handle more. It can probably handle more with a jb4 without self destructing but that would be outside warranty.
11-16-2018, 01:03 PM | #3 | |
Rep 118
11-16-2018, 02:00 PM | #4 |
Aficionado of All Things Vroom
171
Rep 1,213
this is incorrect. Just because MPPSK raises tq to 355 doesn't mean that is the hardware limit. There is always a buffer zone built in from the factory, and there are PLENTY of stock clutch cars making more than 355 without issue.
Current: 2020 F97 X3M Competition
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi |
11-16-2018, 02:43 PM | #5 | |
Rep 5,992
eluded3032.00 |
11-16-2018, 02:52 PM | #6 | ||
171
Rep 1,213
Based on your theory, the S55 6MT would be hardware limited at ZCP power levels since that's where BMW pegged it. However, we know the trans is sufficient for much higher power levels than that. It's much more likely that BMW wanted to "push" 6MT buyers looking for bigger power from the factory into M2s or F8Xs. Keep in mind how conscious BMW is of "softening" models to keep them far enough away from M cars. The factory HP ratings are not necessarily indicative of hardware limitations.
e_b_d_i18.00 |
11-16-2018, 03:01 PM | #7 |
Rep 1,452
Not a whole lot of info on the internet about torque numbers for our ZF 6-speed manual.
http://www.realoem.com/bmw/enUS/show...diagId=23_1123
2022 CT4-V Blackwing 6-speed
11-16-2018, 03:04 PM | #8 | |||
Rep 5,992
11-16-2018, 03:07 PM | #9 | ||||
171
Rep 1,213
11-16-2018, 03:12 PM | #10 | |||||
Rep 5,992
11-16-2018, 03:16 PM | #11 | ||||||
171
Rep 1,213
You said if you tune your car above the MPPSK level that they would deny warranty coverage on anything trans related. That statement is categorically and unequivocally false. It depends on the dealer (some are more mod friendly) as well as the specific part that failed. I personally know multiple people running various tunes across different platforms (N54, N55, B58, S55) who have received trans related warranty work on a tuned vehicle, including new clutches.
11-16-2018, 03:23 PM | #12 | |||||||
Rep 5,992
11-16-2018, 03:46 PM | #13 | ||||||||
Rep 118
I personally wouldn't risk my warranty for a tune. |
bimmer4562959.50 |
11-17-2018, 01:44 AM | #14 |
2JZ-GTE
3032
Rep 3,992
This arguing on the Internet is funny. BMW has said the MPPKSK is tuned for less torque in the manual transmission because of the limits of the transmission. So I think that statement would be correct.
Say you blow a motor, If BMW finds out you modified anything at all on the car your powertrain warranty will be denied. |
bimmer4562959.50 |
11-18-2018, 07:55 PM | #16 |
Rep 259
Drives: 16' AW 340i xDrive
Okay, the short answer is nobody knows, unless;
a) someone got the info from inside BMW b) someone strapped up a few boxes and wound them up until they blew up c) imperical data from tuners that blew boxes d) someone ran a hunch of boxes for hours and thousands of kms at different hp/tq levels until they blew So something that wouldn't be easily known. What the forum will tell you is, what hp/tq levels hasn't resulted in a catastrophic failure.....yet.
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
rockymtnpilot73.50 |
10-20-2019, 11:11 AM | #17 |
Rep 203
Hey, I am also interested in this old topic.
I contacted ZF and here is their answer: "Die Bezeichung des Getriebes wird bei der Konstruktion des Getriebes vergeben. Das angegebene Getriebe GS6-45BZ ist nominal für 450 NM ausgelegt, kann aber z.B. durch Aenderungen in der Stückliste auch für eine mehr Drehmoment hergestellt werden. Die genauen Angaben kann Ihnen jedoch nur der Fahrzeughersteller liefern, denn er bestimmt, welche Motor/Getriebe Kombination im entsprechenden Fahrzeug verbaut ist" In summary, the base model of that gearbox is build to stand 450 NM of torque, but the car manufacturer can specifically ask to support more torque. So in the end, only BMW can answer if the gearbox in the manual 340i can endure more torque or not. Is there a BMW mechanic here that could check it ? |
02-20-2020, 08:13 AM | #18 |
Rep 203
bump!
Any info concerning the max. torque that the gearbox and clutch can bare ? Anyone having troubles with the 6MT after tuning the engine ?
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
02-20-2020, 08:27 AM | #19 |
Rep 775
My clutch started slipping after a BM3 stage 2 tune with downpipe. Getting the 550i clutch installed which is rated to hold more power and torque
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive |
02-20-2020, 08:33 AM | #20 | |
Rep 203
I get the clutch slip thing, but I am more concerned with the gearbox itself, that would be very expensive to change if it breaks.. Any issue in your case ? How many miles do you have since the tune ? thank you!
Corvette C6 Z06 Z07 Last edited by vcx; 02-20-2020 at 09:03 AM.. |
02-20-2020, 10:47 AM | #21 | |
Rep 775
My car has 19,000 miles when I bought it, I put the tune (BM3 stage 2) on with about 21,000 miles and it started slipping almost right away and progressively got worse Which is odd because my old 340i xdrive that I leased new, I had JB4 stage 2 on for roughly 20,000 miles and never had one issue
2020 M340i xDrive |
