BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > "Camera System" error
      12-10-2018, 02:38 AM   #1
Dr Forinor
Dr Forinor's Avatar
Drives: 2015 F31 335d
This is what I get when I put it into reverse;
Further checking and I get this (sure enough no view from side cameras);
Any ideas what might be wrong, please?
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
      12-10-2018, 05:40 AM   #2
Dr Forinor
Dr Forinor's Avatar
This is what the actual cameras look like from outside;
Right side
Left side, this side appears to have something wrong with it compared to every other camera?
Anyone experienced this?
      12-10-2018, 05:51 AM   #3
teaston
Drives: X3 M40d
Looks like water has got into the camera.
      12-10-2018, 05:55 AM   #4
Dr Forinor
Dr Forinor's Avatar
Oh, is that the camera kaput then you think? Or will that dry out and be fine? But if water's got in, then it means a seal is not doing it's job, which means new camera?
      12-10-2018, 06:00 AM   #5
teaston
Drives: X3 M40d
Camera kaput, it will have corroded the internals.
      12-10-2018, 06:21 AM   #6
Dr Forinor
Dr Forinor's Avatar
Will be as simple as remove this camera module, fit a new one, plug and play?
      12-10-2018, 08:12 AM   #7
teaston
Drives: X3 M40d
I'm not sure. Are you out of warranty?
      12-10-2018, 08:31 AM   #8
Dr Forinor
Dr Forinor's Avatar
Yeh, no warranty now.
      12-10-2018, 08:48 AM   #9
teaston
Drives: X3 M40d
Might be plug and play, but looks like may be upside down and need correcting with ISTA, and the cable could be corroded too like this guy:
http://forum.bmw5.co.uk/topic/125551...amera-failure/
      12-10-2018, 08:56 AM   #10
Dr Forinor
Dr Forinor's Avatar
I'll have a more in depth look, thanks.
