03-11-2019, 10:31 AM | #1 |
Rep 80
Memphis Motor Werks
This will be my second time using these fellows, the first time I used them was about a week after I took delivery of my vehicle. Oil change and brake fluid flush wound up being somewhere around 300 bucks. Not too too bad plus I needed the work done. I must say that I'm fairly confident in them. I have an OSI warranty but I don't think they do warranty work. Nevertheless I refused to pay bmw of Memphis 500 for what need done. Please don't judge me guys.... I'm about 600 miles overdue for a vehicle check, I'm sitting right at 82k miles. I'm one who believes in preventative maintenance so I'm getting spark plugs changed as well. Total out to somewhere around 300 bucks again I'm not sure how I feel about that but it is what it is. What other preventative measures can I take on down the line in a couple months or so. May get them to change the belt I'm.m not sure, give me some advice guys. Thanks! CHEERS
03-11-2019, 12:07 PM | #5 | |
Rep 80
03-11-2019, 02:02 PM | #6 |
Rep 16,082
I'd do the coils at the same time as the plugs. You can't change the plugs without pulling the coils, so you're paying the same labor either way. Cleaning the intake manifold and valves is a good idea, lest they get so bad that you have to spend big $$ to get them walnut blasted. For that you use this:
https://www.amazon.com/CRC-05319-Int...FQMX9EBAH73PV9 Clean the air mass flow sensor, clean the A/C coils. For the last you use this: https://www.amazon.com/Lubegard-9603...%2C170&sr=1-10 That's best done along with an oil change, taking advantage of the car being up on a lift anyway. |
f34guy10.00 |
03-12-2019, 10:43 AM | #8 |
Rep 10,256
Does your vehicle have M Adaptive suspension? Inspecting shocks for any leaks is recommended considering number of miles.
03-12-2019, 03:59 PM | #9 |
Rep 80
