08-13-2017, 04:24 AM | #133 |
Rep 12
Hello
Ive put new LED headlights to my 2016 F80 VIN:5E68234 They fit plug and play but when I turn ignition off and turn back on they don't light back on which seams I need some coding. Is there anyone who can help with the coding?? What option needs change or adding?? Thanks |
11-24-2017, 03:17 PM | #134 | |
Rep 3
I need wiring for bmw f30 2013 xenon to led headlights, do i need light control unit and what else i need please let me know |
11-28-2017, 10:30 AM | #136 |
Rep 765
12-08-2017, 06:33 PM | #137 |
Rep 765
Can someone That has the lci full led headlights help me out. I'm trying to get all the parts necessary since my headlights only came with turn signal modules. I kno I need the 3 led modules for each light plus the main control module for each but I don't know about the "led display for fan" 63117419612. Is that inside the headlight or am I missing something? When I twist the cap off the light I can see something that I think is it but I'm not sure and jus trying to figure this out. Sorry for such a dumb question. Thank you.
12-23-2017, 08:35 PM | #139 | |
Rep 765
04-13-2018, 05:44 PM | #141 | |
Rep 765
U sure about that? For the lci led I thought 1 is activation flash indicator light, 2 is ground, 3 is constant power n then the rest like u said. |
04-14-2018, 03:11 AM | #142 | |
Rep 28
I asked my dealership and they said no Lol How much did the harness set you back? |
04-14-2018, 11:57 AM | #143 |
Rep 53
Think I found the retrofit harness, it’s this one: 61122410223. Looking at the instructions it also seems like leveling sensors are need as well, I guess you will get errors if they are not installed?
Update: It looks like the non-adaptive LEDs don't need leveling sensors, at least none are listed for S5A2A (LED headlight) so we should be good to go without. What about coding, anyone know any specifics? Last edited by rflagg; 04-14-2018 at 03:07 PM.. |
04-15-2018, 02:21 AM | #144 | |
Rep 765
04-21-2018, 02:54 PM | #145 |
Rep 765
Before coding the fem they would level separate n at a nice slow speed. After coding fem they would level at same time but real fast. I want them to level slow like they did before. Anyone have any suggestions. Maybe I can fdl code something for the leveling speed? I kno it’s soenthing dumb but I like it when it would level slow lol
Jacob SD1.50 |
05-17-2018, 01:20 PM | #147 |
Rep 49
Just so u guys know, there is a page called “eurowagens” that sells OEM looking headlights for a lot of the F-gen BMW’s, LCI And pre-facelift, also the reflector versions. Pretty much all the headlight versions, they seem to specialize themselves for F20 and F30. They’re also certified SAE, DOT and ECE so they’re road legal worldwide.
The LCI taillights r also easy to install on a non-LCI. Just switch up some wiring in the rear, just search for “LCI taillights Retrofit” and it should come up a utube video of a blue F30 with the LCI taillights, the dude that made it explained all pretty good aswell. Last edited by MagnusAG99; 05-28-2018 at 01:12 PM.. |
07-26-2018, 02:55 AM | #148 | |
Rep 4
08-20-2018, 02:30 PM | #149 |
Rep 2
Right front headlight not working after replacement
Hello all,
I know I might not post in the right place but I couldn't find a better thread. I replaced my right front headlight of my F31 the other day with a TYC 20-12973-05-2. After putting everything together I just realised that none of the lights work on that side. Is there some coding required in order to make it work? I have no experience with cars, but I thought that it will be as simple as taking out the broken (original) headlight and mounting the new one. Thank you in advance! Cheers |
08-20-2018, 02:36 PM | #150 | |
Rep 765
08-22-2018, 04:50 AM | #151 |
Rep 58
Hello Marius, I am retrofitting LCI Adaptive LEd in my F33 bimmer. I am having problems with coding. After vo coding on FEM the FLE units has dissapeared. Before this I detected CAF and they worked fine. Could you help me? Thanks.
08-29-2018, 10:05 AM | #152 |
Rep 58
10-24-2018, 05:48 PM | #153 |
Rep 7
Can somebody help me, I have an f31 12/2012, and I am aware about k-Can 2 signal for the led headlights. Where they are connected in the fem on the model before 07/13? As teh models before 07/13 are using the K-Can instead of the K-Can 2. Thanx
10-24-2018, 08:51 PM | #154 | |
Rep 2,302
Markom0510.00 |
