05-31-2020, 05:31 AM | #1 |
Rep 26
NBT Evo difficulty after retrofit .
Hello,
I would be so grateful for you guys help on this. My car was upgrade from CIC to NBT EVO with a matching VIN ATM module. The Evo hasn’t been coded. It is connect to NBT emulator. The problems are as follows; Contact details from my phone do not display on Evo despite allowing them to do s from my phone Car Play is InActive NBT and ATM are matchings vins but have not been coded. SOS Malfunction is still present despite coding ST_ECAL_ALIVE and ST_ECAL_TIMEOUT set to nicht_aktiv. Someone told me I need to rewire my Ethernet the (Quadlock to OABR) Quadlock EVO 31 17-ETX_TH+ 32 19-ETX_TH- 37 18-ETX_RH+ 38 20-ETX_RH- I have no idea what this means or how to do it? Is this true an required Final Notes; On Current Version the following is displayed ; Vehicle Vin (ID) : This is blank? TB: -006.32.12 MB: 006.32.12 Thanks again for you help Si |
05-31-2020, 05:33 AM | #2 |
New BMW owner
139
Rep 621
Why didn’t you code it ?
06-01-2020, 05:10 AM | #4 | |
Rep 2,302
But they still don't know your car and the equipment, so all codings are still set from the donor car. That's why it is necessary to code the Evo and ATM. |
08-26-2020, 08:54 AM | #5 |
Rep 3
Sorry to defer the post, but I also recently fitted a NBT EVO (from HU entry) but I get the "NO SIGNAL".
I am using the emulator and everything is connected. Any help is appreciated. |
