05-23-2020, 03:46 PM | #1 |
Rep 62
List of performance mods for b58 ?
I am planning to get a 340 in about a month and just want to have a full list of all the mods available performance wise. Please add to the list if I am missing any. I was planning to get a 335 so I am new to the b58 field and know some mods are inapplicable or not sure if they exist for the b58
**This is not a list of specific mods but more so what can be modded on the car** - Intake - Turbo - downpipe - spark plugs - charge pipe - turbo inlet - -heat exchanger?? - diverter valve/blowoff valve?? |
05-23-2020, 03:51 PM | #2 |
Rep 833
Drives: BMW F36, E36, E93
certainly heat exchanger if you go for a turbo uprade
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
05-23-2020, 04:36 PM | #3 |
Rep 85
Downpipe and a tune are your best bang for the buck. Plugs gapped down a bit will help too. The high pressure fuel pump becomes the limit when you start upgrading turbos.
05-24-2020, 03:20 AM | #6 |
2JZ-GTE
3032
Rep 3,992
I didn't see nitrous on the list
05-24-2020, 09:32 AM | #9 |
Rep 242
05-24-2020, 11:35 AM | #10 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
I think this is a far from a universally agreed upon mod. I'd go with "maybe" instead of "certainly".
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
05-24-2020, 11:43 AM | #11 |
Rep 684
Rashad95
A lot of mod decisions for this platform stem from your fueling strategy. What fuels are easily available where you live? If it's pump gas only, or maybe even only 91 octane then you're going to be power limited unless you choose to add a meth system. If you have ethanol easily available in your area, congrats - you have access to a lot more power, but may need to consider an upgraded HPFP. The real question is - what is your power goal?
2020 X3M
05-24-2020, 01:40 PM | #12 | |
Rep 179
05-25-2020, 06:49 AM | #13 |
Rep 833
Don't you agree that it would be more then just a maybe to provide the turbo with colder air, especially if you increase the flow? Would be a waste of a good turbo not to give it enough Oxygen
Such Fun
05-25-2020, 01:03 PM | #15 | |
Rep 684
By saying "certainly" your post implies that it's a well-established mod that many or most people are using on the B58 and that's far from the truth. OP is new to B58 so he doesn't have the info yet to critically examine feedback and determine what's accurate so let's help him out.
2020 X3M
kern4174446.50 |
05-25-2020, 02:08 PM | #16 | |
Rep 179
05-25-2020, 05:49 PM | #17 | |
Rep 234
The NGK 94201 spark plugs in the car (stock plugs) are the best ones you can get, no need to switch unless the car has 25k or more miles on it. Charge Pipes for the B58 platform are unnecessary and have been proven above 500whp+ on these cars. Only reason to upgrade is if you are going to run Meth. Turbo wise you have a few upgrades, Pure800 seems to be the most supported and used upgrade kit here. I’d recommend going with Bootmod3, MHD or MGFlasher stage 1 and seeing where that puts you in performance for what you are wanting. Second get a downpipe and go Stage 2. There’s lots of options here, most people recommend VRSF for catless based on price. I’d recommend a CG Precision DS-1 just because you’ll retain most of the performance of a catless pipe with a great sound and little to no catless smell. Depending on where you want to go from here you’ll need a fuel pump upgrade during or prior to upgrading the turbo. |
Supr3me551.00 |
05-26-2020, 01:55 PM | #18 |
Cheapskate
4447
Rep 4,993
This is kind of hard to follow. I think you're asking what mods are available so you can choose a route to go. If so, it goes in this order
1. Tune 2. Downpipe 3. HPFP 4. Turbo - Intake only if you feel that your turbo is laggy - Heat Exchanger only if your logs indicate heat soak is an issue - Spark plugs only if you're already due for replacement - Inlet comes with the turbo kit - No chargepipe/DV needed |
05-26-2020, 03:36 PM | #19 | |
Rep 684
But OP still hasn't answered two important questions - what's his power goal and what fuel is available near him.
2020 X3M
05-27-2020, 11:26 AM | #20 | |
Rep 234
I have 91 Octane here, but for some reason the octane rating here is worse than the 91 BM3 is tuned for, so I'm forced to run ACN91 or I get a couple of knocks when pulling logs. I also have one E85 station in my county, thankfully it's on my way to and from work, but its also 15 miles from home which makes things a little difficult. |
05-27-2020, 12:01 PM | #21 | |
Rep 179
