07-21-2018, 11:21 AM | #2289 | |
Rep 40,635
That said, there is no installation of anything that requires PSdZData Full.
07-21-2018, 11:41 AM | #2290 |
Rep 11
I am trying to install Esys to code/flash my FZD module on the instructions it says that I need the full PSdZData to be able to access the Modules.
the problem I am having is that nether my keys, sunroof or dome interior lights are working so I purchase a new Dome and I know I will need to program my VIN to it so that is the reason I need to install Esys |
07-21-2018, 11:43 AM | #2291 | |
Rep 40,635
Send me PM when you can.
07-21-2018, 09:53 PM | #2292 |
Rep 196
Could I please get the latest PSdZData and Applications, if needed. Our '17 F30 received a software update and I need to re-code everything.
I'm presently running Launcher 2.8.2.155 and E-Sys 3.27.1, not sure if I should have something newer for either of those.
F30 (2017 340xi): 6MT Mineral Grey - CWP, DAP+, Lighting, M Sport, Tech, Track, M Rockers, MPPSK CF
E93 (2009 M3): 6MT Jerez Black - Ext Leather, CWP, Prem, Tech, Rear PDC, Premium Sound M3 Retrofits [Alarm (w/ door sensors), FLA Mirror (Auto High Beams), Dyn RVC, Front PDC] Past (6MT) 2007 E92 SG - 2007 E92 MB - 2014 F30 335xi EB II |
07-21-2018, 09:53 PM | #2293 |
Rep 40,635
PM sent.
Zap33.00 |
07-23-2018, 02:54 AM | #2294 |
Rep 4
Hello everyone, I recently bought my first BMW 320d F31 I would like to learn to make the codings on my BMW (I'm jealous and the hands above I would just put them ;-)) .. if any of you can give me some guidance, link software and all that I need I already read many posts but e-sys I had downloaded does not work, do you have a working software? thank you so much
07-23-2018, 06:47 AM | #2295 | |
Rep 40,635
07-23-2018, 06:48 PM | #2297 |
Rep 11
I am having difficulties connecting to my FZD ECU.
For some reason nether my key nor sunroof or reading lights work in the overhead dome so I assumed that I messed up the FZD module since I was taking it out to get the headliner out and I saw a sparkle go off. After that none of the above worked. So I bough a used FZD module and I have been trying to flash it but esys does read the ECU. This is the error I get: ransaktions-Report: Aktion: Codierdaten lesen CAFD_00000552_001_034_010 Fehler: CPS read from ECU "ECUId:FZD_0x56" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: FZD_56_ETHERNET severity: ERROR [2130765072] CAFD_00000553_001_045_001 Fehler: CPS read from ECU "ECUId:FZD_0x56" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: FZD_56_ETHERNET severity: ERROR [2130765072] I am on an F10 and my I-Step is F010-17-03-505 I am coding with my car turned on. I have coded other features successfully so the cable is not bad and I connect successfully all the time. I am using V.4.12.12 PSDZdata. I've been searching desperately everywhere and cannot for the life of me find any help at all. Can someone please help!!!!!!!! |
07-23-2018, 07:52 PM | #2298 | |
Rep 40,635
07-24-2018, 02:36 AM | #2300 |
Rep 10
Drives: X5 E70, 330D F31 M
Hi,
i have an F31 330D 2018. How i code the Video in motion yet? greetings Thomas |
07-24-2018, 06:42 AM | #2301 |
Rep 40,635
For NBT2 ID5/6 Video-In-Motion (VIM), it is not Codeable. You need a VIN Specific Unlock File. PM sent.
07-24-2018, 06:43 AM | #2302 |
Rep 40,635
Does not show up where? In SVT as one of your ECU's or in TAL List as flashable?
07-24-2018, 02:11 PM | #2303 |
Rep 29
Hi Shawn,
I installed E-Sys 3.2.71 with PSdZData 4.12.12 lite version. I managed to code for a F22 the KOMBI and REM ECU's but when it comes to code HU_NBT seems the cafd file is trimmed (see below pic) The car, due to a recall, has just received couple of weeks ago a Ilevel update. Could it be this PSdZData version to do note cope with latest iLevel, and still have to wait a newer version? Thx |
07-24-2018, 02:14 PM | #2304 | |
Rep 40,635
07-24-2018, 02:14 PM | #2305 |
Rep 115
shawnsheridan could I get latest PSdZData links please ('17 f82 and need to reinitialize cameras)
ty for the continued contribution
2016 X3 Alpine White
*sold* 2017 M4 6MT Sakhir Orange : ZCP//CCB//BM3//LCI *sold* 2014 435i 6MT xdrive : JB4//LCI |
07-24-2018, 02:18 PM | #2306 |
Rep 40,635
PM sent.
reighnman25.00 |
07-24-2018, 03:20 PM | #2307 |
Rep 14
@shawnsheridan,
Hi, can you sent me the link to the whole and most updated package? I coded my f31 late 2016 and the dealer did a software update and wiped it all... I thought I still had it up and running on my virtual Windows 10 on my Mac... fired it up but esys launcher premium won’t start up esys... only have to do some coding, so light psdz data would be good Any instructions how to delete everything before reinstalling? Big thanks!! |
07-24-2018, 03:27 PM | #2308 | |
Rep 40,635
Uninstall E-Sys Launcher (and E-Sys if replacing) via Control Panel => Programs, and then delete psdzdata subfolder in C:\data folder.
07-24-2018, 11:08 PM | #2309 | |
Rep 11
FZD - 56 There was an error during TAL Execution Negative Responce error: Code: TIMEOUT P2/T2 occurred Description: P2 timeout on Service RDBI_SVK has error in results: [Severity=2051] [ErrorCode=585640] [ErrorCodeDescription=resource not available] [vendorCode=2142] [VendorCodeDescription= P2 timeout occurred]; LinkName: FZD_56_ETHERNET severity: ERROR |
07-25-2018, 06:57 AM | #2310 | |
Rep 40,635
