11-13-2016, 05:12 PM | #1347 |
Rep 8,364
F020 and F030 share F020 Psdzdata (ie same connection target), but ONSW is only is only found in F020 FAFP (not F030). As such, it would not be a valid Aftermarket fitment HO-Word edition (ie you would get a invalid error if you tried to add to your F30 FA).
But, since they do share ECU's, you may be able to us TM's NCD / CAFD Tool (SVT-CAFD Resource) to load your SVT, choose F020 for main series, add select ONSW from SALAPA list, & select calculate to determine which FDL's to change. Results will look something like the following: PHP Code:
11-13-2016, 05:29 PM | #1348 |
Rep 40
I think I may need the newest esys and pzdata files. I tried to code tonight and I couldn't link to the car. Said I had incorrect dealerID even though I coded a day ago...
11-13-2016, 06:05 PM | #1349 |
Rep 40,648
If you coded it a day ago and it worked, there is nothing new you need.
11-14-2016, 03:46 PM | #1350 | |
Rep 34
Thanks a lot!. It will try this and let you know. |
11-14-2016, 06:11 PM | #1352 |
Rep 40,648
PM sent.
11-16-2016, 06:51 AM | #1355 |
Rep 40,648
PM sent.
11-20-2016, 06:55 AM | #1358 |
Rep 40,648
PM's sent.
11-20-2016, 07:53 PM | #1359 |
Rep 45
ESYS on Surface Pro 4
Hi All, any one experience this on Surface pro 4 ? I try to adjust the screen resolution, but it doesn't work. Kindly refer to my file attachment.
Hope can hear from expert. Kenny Chan |
11-20-2016, 08:17 PM | #1360 |
Rep 8,364
If you have high resolution screen, you must used updated Launcher 2.6 and check Fix. You are using latest E-sys so I assume you would have newest launcher too.
11-26-2016, 05:33 PM | #1361 |
Rep 125
Drives: 2013 328I Sportline
Could I please get the latest Esys and psdzdata? I had to reinstall a fresh copy of windows and lost everything I had previously.
11-26-2016, 05:33 PM | #1362 |
Rep 40,648
PM sent.
11-26-2016, 05:54 PM | #1364 |
Rep 7
Good Early morning (to european guys) and Good afternoon (to american guys).
I am trying to code my bimmer (F30 320D) unfortunately I cannot find a working version of esys+PSDzData+Token that works properly. Could I obtain information on what to do to make them work, as a copy of them working? Thank you so much |
