BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Rear Diff Seal Leak?
      07-08-2018, 06:59 PM   #1
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
I was having my tires rotated and balanced today and noticed oil around drivers side differential. Does this look like a bad seal to you guys?
      07-09-2018, 03:56 AM   #2
cfm56d7b
How many miles does your vehicle have? Did the dealer inspect the differential during the last CBS maintenance?
      07-09-2018, 04:55 AM   #3
XxThe_RemedyXx
967
Currently at 55k. Honestly I'm not sure if they did.
      07-09-2018, 08:20 AM   #4
kingmonkey8
Drives: BMW 428i
Probably leaking from the output shaft seal. Looks like it has been leaking for a while with the amount of dust on it. But not seeing any drip so might not be too bad.
Check the oil level and top up. Is the diff making any noise?
      07-09-2018, 08:33 AM   #5
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
I had the same thing on my 2013, see post below.
Dealer had to replace seal and top off oil.
https://f30.bimmerpost.com/forums/sh....php?t=1108145
      07-09-2018, 08:42 AM   #6
XxThe_RemedyXx
967
A few months ago I noticed a high pitched sound when accelerating. Did some research and concluded that the noise may be coming from the diff. I brought it in and they said all was well and couldn't reproduce the sound. I have a feeling this is where the sound is coming from.
      07-09-2018, 08:43 AM   #7
XxThe_RemedyXx
967
Awesome. Thanks. Just contacted my SA. Should this be covered under CPO?
      07-09-2018, 08:44 AM   #8
KGB_123_99
I don't see why not.
      07-09-2018, 09:57 AM   #9
XxThe_RemedyXx
967
My SA replied:
"Sorry ... – I got your text and again, this doesn’t bother me at all. I forwarded this picture to my shop foreman. I will see if this is leaking enough to the point of coverage. I cannot make those decisions but it looks like the seal may be “sweating” but I will know for sure shortly."
      07-09-2018, 10:32 AM   #10
rak299
Drives: 2021 M3 6MT
"Sweating"? Really? I think when some material that is supposed to be kept inside gets outside, it is called leaking.
      07-09-2018, 10:36 AM   #11
XxThe_RemedyXx
967
lol, yep! I said "Not sure about sweating, there's oil caked all over". We'll see what they come back with. I don't think this can be classified as "sweating".
      07-09-2018, 11:14 AM   #12
vooonoo
¯\_(ツ)_/¯
vooonoo's Avatar
537
Drives: f30 328
2014 f30 328i  [0.00]
Hope it's covered
I had to post this picture
      07-09-2018, 11:18 AM   #13
XxThe_RemedyXx
967
Originally Posted by vooonoo View Post
Hope it's covered
Haha I hope so too...
      07-12-2018, 05:50 PM   #14
cfm56d7b
What is "sweating" as described by the mechanic? Just trying to see some credible insight even if improperly described.
      07-12-2018, 06:39 PM   #15
XxThe_RemedyXx
967
Wish I knew. It doesn't even make sense. It's a damn leak, that's all.
      07-16-2018, 02:41 PM   #16
XxThe_RemedyXx
967
UPDATE - Bad rear axle seal and charge air pressure sensor being replaced under warranty. Copay of $50... I'm happy.
      07-17-2018, 08:55 AM   #17
kingmonkey8
Drives: BMW 428i
What's the charge air pressure sensor? Is this anything to do with the diff?
      07-17-2018, 09:07 AM   #18
XxThe_RemedyXx
967
No, but I got a DT Malfunction that lead back to a bad MAF sensor...
      07-17-2018, 03:02 PM   #19
Sea-Tac
Sea-Tac's Avatar
Drives: 2108 X3 xDrive30i
I would say it sure as heck should be covered. Good luck.
      07-17-2018, 03:14 PM   #20
XxThe_RemedyXx
967
Just picked it up, $50 CPO copay and out the door.
      07-17-2018, 03:30 PM   #21
cfm56d7b
Much better than "sweating" diagnosis. ;-). Glad to hear that all is well.
      07-17-2018, 05:53 PM   #22
Sea-Tac
Sea-Tac's Avatar
Good...rest easy.
