BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 GFB DV+ installed without moving or touching the turbo! +quick tutorial
      05-24-2018, 09:32 AM   #155
XAoPiLLz
Drives: 2016 328i N26
Originally Posted by BunkerJ View Post
Yeah, same. I typically can hear it in the parking lots between buildings or the canyons.
maybe its because im in comfort mode most of the time. i only throw it into sport or sport+ when i wanna have some fun.
16 Mineral Grey F30: Injen CAI | ER CP/TiC/Catless DP | VSRF 7" Intercooler | NGK LI Plugs | BM3 running PTF stage 2 93 AGG Tune | BMS Methanol Kit | GFB DV+ | AWE Quad Exhaust Suite | Dinan Sport Springs | 19" MRR GF9 with 225 front and 255 rear | M4 CF Spoiler | VividScreen 8.8"
      05-24-2018, 05:00 PM   #156
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Maybe. I drive in Sport+ always.
      06-08-2018, 03:04 PM   #157
Noelified
Noelified's Avatar
Drives: 2016 F36
My DV+ is on order. Just wondering if something like this would work. Not sure how much torque you can get with it, but I might try it. Amazon prime for $4.
      06-08-2018, 06:26 PM   #158
D041987
Big Turbo Boys N Girls
D041987's Avatar
Drives: 2012 328I 6speed
It's a very sever angle and the tensioner is in the way. You will need to grind down the 5MM key to the size of the 4mm key on the body to get any force. You will get maybe 2in pounds of force on tightening it. Mine was loose from factory, I could almost turn it by hand. I used an allen wrench to remove it but putting it back in was a bi tch! I had to cut an allen key and bend it a lot to get any force or room to tighten it. I also used blue lock tight as a measure on that back bolt when I had the stock turbo. There is no other way to do it unless you loosen the mani and drop the turbo down a little.
Also as I recall I had flutter on my car with just the intake and DV+ in 3rd or 4th with light throttle application especially on the hwy. Than it got progressively less as the spring relaxed and things settled in. As for the tune and turbo forcing more air this can contribute to the flutter but as you tune the car for more boost, the other parameters and systems that control air like the diverter valve are also adjusted to compensate in the coding for the increase, so should not be much of a difference.
Noelified228.00
BunkerJ1032.00
      06-09-2018, 09:13 AM   #159
LordRuxpin
Drives: F30 N26
No... it wont work, even more so it's just not needed.
      06-10-2018, 09:46 AM   #160
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
Noel, wayyy to thick. You have to get the tool down to this...
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
Noelified228.00
      06-10-2018, 08:43 PM   #161
Noelified
Noelified's Avatar
Drives: 2016 F36
Wow. Thanks. Was hoping to save the effort for $4 I have a bench grinder so I guess i'll be grinding one down like that. Thanks for the pics. Would you say that's the proper length?
      06-11-2018, 09:18 AM   #162
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Exactly. Mine settled in and I stopped getting it when in park. I'll get it 3rd or 4th if I'm low RPM, press the throttle more and liftoff.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      06-11-2018, 01:09 PM   #163
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Length-wise it's perfect. I did use a small extension on the back to get the ratchet on but I think all of those long ball hex sets are about all the same
Noelified228.00
      06-11-2018, 10:45 PM   #164
LordRuxpin
Drives: F30 N26
Welp, I was finally able to finish the install for my GFB DV+, my Injen CAI came in whilst I had to find time to finish this DV+ install. Needless to say I like the way sound in unison. http://www.flickr.com/photos/1419515.../in/datetaken/
BunkerJ1032.00
      06-12-2018, 09:20 AM   #165
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Great to hear.
      06-12-2018, 05:35 PM   #166
ilivas
Drives: 428
The “woosh” sound comes from when the air is released from the DV and recirculated back into the intake. When you add the stiffer spring it keeps the piston closed a bit more and not all that air is released and it bounces back into the turbo and bounces back and forth between the turbo and the throttle body plate.
BunkerJ1032.00
      06-12-2018, 10:20 PM   #167
LordRuxpin
Drives: F30 N26
Yea, BunkerJ covered this in pretty great detail... Under load it doesn't even happen.. that only happens for me when I'm static. I believe that flickr link I posted earlier goes to all of the photos and videos I have. Where you can hear it, when I'm flooring it... I'll try to make a better video soon though.
      06-19-2018, 03:57 AM   #168
Mid_Night_F20
Mid_Night_F20's Avatar
23
Drives: 125iM N20
hey does the boost pipe have to get off?
I have a metal one so there will be hardly any flex in it.....
N20, EWG, Full M package, 19" x 8.5/9.5, JB4, Catless DP, Custom 3" exhaust, Upgrade intercooler with metal piping, drop in K&N, Snow Performance Stage 2 kit
      06-19-2018, 06:48 AM   #169
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
I think it's still doable with the pipe installed in your case... but it not flexing will limit your movement. I'd say give it a shot first before removing it completely
      06-27-2018, 07:26 AM   #170
XAoPiLLz
just remember that if your 16 is anything like mine they wont be allen head screws on the EWG or the 3 screws on the original DV. They were all torx bit. Just an FYI.
Noelified228.00
      06-27-2018, 11:00 AM   #171
lonecitizenfour
Drives: 2014 428i XDrive
Just got mine installed from a shop. Will post a video this weekend!
      06-27-2018, 12:27 PM   #172
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
How much did they charge you?
      06-27-2018, 03:46 PM   #173
lonecitizenfour
More than the part itself but nothing ridiculous. It didn't take them 5-6 hours like people have mentioned before.
      06-28-2018, 07:45 AM   #174
LordRuxpin
Drives: F30 N26
Honestly if you do it yourself, following the initial post... it should only take you an hour... as long as you have the right tools. But having your extended 5mm ground down to the right spec is the toughest part..
      06-29-2018, 11:46 PM   #175
lonecitizenfour
I don’t want to potentially screw it up. I don’t have access to the car throughout the week because I don’t keep it near where I have my primary residence. Rather just have a shop do it and pick it up!
Btw... this may be the way it’s intended but sounds no different.
      07-02-2018, 09:06 AM   #176
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Sound varies due to mod but honestly, the sound is irrelevant. It's all about the performance.
