08-06-2020, 11:15 AM | #1 |
Not stock
474
Rep 614
Recommendation on cutting compound/polish for Sapphire Black?
Hey all - I ceramic coated my F30 328 and went the full regime of iron remover, clay bar, compound, polish, etc. My wifes X1 is also Black Sapphire - while doing mine I did notice it took considerably longer to get results as the clear coat seems real hard on these cars compared to others I have done. Does anyone have a recommendation for pad/compound combo for getting good, quickish, correction results?
Thanks all
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
08-06-2020, 11:28 AM | #2 |
Rep 35
I got some good results on my F32 Black Sapphire with the Menzerna 400 (cut) and the 4500 for finish, using the medium cut pads (white) and the black finishing pads. Brought out some nice highlights and the flake that I hadn't seen in a while. It does take a bit longer due to the black color.
08-06-2020, 12:13 PM | #3 |
Rep 16,089
I use Menzerna 400, 2000 and 3000, sealing with Jescar Power Lock. Fast cutting requires a rotary buffer with the 400, then switch to random orbit with the rest to minimize swirling.
08-17-2020, 04:40 PM | #5 |
Rep 849
Drives: BMW 435i
Black hole is a great glaze, but it is a glaze which will only temporarily fill in the defects. I've used it, and liked it, but it isn't a permanent solution.
For the polishes I've used Blackfire Compound on a white Lake Country Flat Pad and Thin Pro Pad with my dual action polisher. It gave me quite a bit of correction on my Sapphire Black 435i. You can see the results here: https://thecargeek.net/full-detailing-a-2016-bmw-435i/. It actually polished out really nicely in one step. For very light levels of correction, I've also used SONAX 04-06 polish on a white pad. The Blackfire SRC compound I reference in the blog post isn't made any more, but Blackfire's new polish cuts just as well, but actually is easier to remove and I think it polishes out a little better as well. If it makes you feel better, our Sapphire Black isn't as hard as the black metallic paint I've corrected on a GTI or a Porsche Cayanne. That Porshe was REALLY hard.
08-19-2020, 03:52 AM | #6 |
Rep 14
Sonax CutMax combined with a Rupes yellow medium wool pad has always done a great job cutting swirl marks and light scratches, followed by Sonax perfect finish with a white Rupes pad
08-21-2020, 01:35 PM | #8 |
Rep 283
On my sapphire black 440i i used Sonax cut max with Hex logic green pad, then gyeon q2 primer on a white pad followed by wolfgang deep gloss sealant.
Finish is deep smooth and glass like. |
09-04-2020, 09:06 AM | #10 |
Rep 117
I have a 2016 with black sapphire paint. the hood has many rock ships. I took it to a body shop they said they would need to repaint the whole hood and bumpers for color matching and all. pretty costly for just rock chips. I just want the car to look as new as possible with out spending over 2-3k?
09-04-2020, 09:21 AM | #11 | |
Rep 2,200
09-07-2020, 11:24 AM | #12 | |
Rep 495
If it's really bad, and you think it'll affect resale then go for it. |
09-09-2020, 01:25 AM | #13 | |
Rep 7,484
Repairing chipped paint is easy if you're good with DIY. All you need is the right tools and knowledge/practice. Many guides online such as this: https://www.detailingworld.co.uk/for...ad.php?t=20127 |
09-09-2020, 01:31 AM | #14 |
Rep 7,484
OP. I had black sapphire for many years. I have used the products Bill has. My current set is Scholl Concepts S17+ and if needed Chemical Guys VSS. Orange hex chemical guys pad.
09-09-2020, 08:37 AM | #15 | |
Rep 849
Drives: BMW 435i
I'm actually going to skip doing another coating on my own car to see how it looks and holds up this winter.
09-09-2020, 03:17 PM | #16 | |
Rep 283
