BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F32 Tires for Midwest
      01-14-2019, 01:27 PM   #1
ZedPlays
Drives: 2015 BMW 428 xDrive
I just bought a 2015 428xDrive. It has the sport line on it and I was thinking of getting new tires for the car. I live in the Midwest so I'm looking for tires that handle well in winter. No Runflats and I was also seeing what size should I get? I am purchasing BMW 437 or 763 reps from OEMCONCEPT. My current tires are 18s, what is the difference if I upgraded to 19s? Does the ride get worse? Do I better control in bad weather? Sorry I'm new to this and everyone is giving me different answers.
      01-14-2019, 01:56 PM   #2
cfm56d7b
There are quite a few threads on this subject.
Before providing some initial guidance, it's helpful to learn ...
- Do you prefer to have 2 wheels / tires sets: first - for summer driving, second - for winter driving?
- Or: you prefer to have one set of wheels and have two different tires sets for summer and winter driving?
      01-14-2019, 02:52 PM   #3
Spielzeugauto
Drives: F31 Touring
Conti DWS or Michelin A/S 3+ for decent handling all seasons.
19s don't make a lot of sense if you are going to be driving them in the winter. They will ride slightly worse, cost more and will be more prone to damage.
      01-14-2019, 07:42 PM   #4
VMRWheels
VMRWheels's Avatar
1586
2013 BMW M3  [5.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
+1
I'd add that the 19's will certainly look better on that car. Depending on the wheel specs, you could upsize the tires to a point where the ride quality is more or less the same.
I have some experience with the Conti DWS 06 in the snow, albeit light, but they were great! Treadwear rating is high, so they'll last quite a while.
WINTER SPECIALS AVAILABLE! PM or email for details! email: brandon@velocitymotoring.com (p) 714-442-7916 x108
      01-15-2019, 12:34 AM   #5
ZedPlays
+1
Right now I have 225/45/R18, should I change this? I kinda want to go to 19s.
      01-15-2019, 11:39 AM   #6
VMRWheels
VMRWheels's Avatar
1586
2013 BMW M3  [5.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
If you want to step up to a 19" wheel, you'll need to change your tires. For example, our recommended specs would be 19x8.5 ET35 in the front with a 225/40/19 tire and 19x9.5 ET45 in the rear with a 255/35/19 tire. Many choose to go a size wider in the front and rear.
Here's an example of what the above mentioned specs look like on a slightly lowered car.
      01-15-2019, 12:17 PM   #7
ZedPlays
Quick question, I have xDrive right now. Will running a staggered setup make that worse? I heard I should have a square set up if I have AWD. Thanns
      01-15-2019, 05:42 PM   #8
cfm56d7b
Are your current OWM wheels square or staggered? BMW does offer staggered wheels as an option for certain models. My previous 2013 BMW 335i xDrive sedan came with optional 19" 401 Style staggered wheels.
There is just one wrinkle. If your particular xDrive model was never offered with staggered wheels either as a standard or optional feature, BMW may deny warranty coverage for xDrive components. While this sounds quite unlikely, it's nevertheless real. Another forum member is dealing with this issue.
      01-15-2019, 07:37 PM   #9
VMRWheels
VMRWheels's Avatar
1586
2013 BMW M3  [5.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
It's possible to run a staggered setup on an xDrive vehicle, but you need to be careful with tire sizes. The difference between the front and rear diameter should not exceed +/-1%. The sizes I mentioned above are safely within that 1%.
      01-15-2019, 10:57 PM   #10
ZedPlays
I called a tire shop today and they said I should run 245/35/R19s on all 4. What do you guys think?
      01-16-2019, 02:02 PM   #11
Spielzeugauto
Drives: F31 Touring
If you're going square and 19s, your options are:
225 40 19 factory diameter
235 40 19 slightly taller and wider than stock
245 40 19 significantly taller and wider than stock (possible rubbing)
245 35 19 slightly shorter but wider than stock (increased wheel gap)
255 35 19 factory diameter but maximum width for front (be careful with offset)
      01-16-2019, 04:22 PM   #12
VMRWheels
VMRWheels's Avatar
1586
2013 BMW M3  [5.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
I've have many customers run that on a 19x8.5 ET35 with no issues.
