BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 10mm spacing at all?
      06-16-2021, 05:19 PM   #1
fortythirtyfive
Drives: 435i MS
I currently run 20mm hubcentric spacers on my 20" 405M ET47 rears.. this gives me a nice flush setup as my sidewalls are pretty flat.
Thing is the new wheels I'm looking at only come in 8.5 ET35, that's the equivalent of using a 12mm spacer on the stock 405M's so it won't be flush.
I have read one or two posts about being unable to run 10mm hubcentric spacers in the rear but nobody fully explains what causes the issue.
Is there any modding I can do to the hub to accept the 10mm spacer? It's a deal breaker for me as I'm finally set on a dream wheel design but they can only offer ET35 and I'd rather avoid having wheels sucked too far in
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      06-17-2021, 08:08 AM   #2
fortythirtyfive
Drives: 435i MS
Nvm - I have been told I can file the hubs down slightly to accept a hubcentric 10mm spacer.. I'll be doing this.
2015 435i - 401whp
