05-06-2015, 08:39 AM | #1 |
Rep 1,976
Drives: 2020 G20 320i M Sport
HU_NBT2 and 6NS coding
I just picked up my brand new F23 convertible yesterday and I have the new HU_NBT2 head unit and it doesn't seem to let me add 6NS via VO coding to enable mobile office.
I'm going to have to use the token master tool and see what 6NS enables on HU_NBT and see if I can enable those options on the new HU_NBT2. Does anyone know if Office is enabled by a single parameter? getCurrentEventID() started [ParallelTask-6] 15-05-05 14:52:08,413 [INFO] [CodingTask - - ecu:HU_NBT2 - da:0x63] com.bmw.psdz.uc.event.EventManagerImpl: API: getCurrentEventID() finished [ParallelTask-6] 15-05-05 14:52:08,413 [INFO] [CodingTask - vin: - ecu:HU_NBT2 - da:0x63] com.bmw.psdz.uc.event.EventManagerImpl: API: firePSdZEvent(PSdZEvent pEvent) started [ParallelTask-6] 15-05-05 14:52:08,414 [WARN] [CodingTask - vin: - ecu:HU_NBT2 - da:0x63] com.bmw.psdz.uc.event.EventManagerImpl: There was an error during TAL execution, please check the log files. [ParallelTask-6] Errors during NCD generation for CAF cafd_00001ef6-006_009_052: DataGroup HMI, Function CDMM_USB_PORTS: More than one condition parameter is active: [usb1, usb1_sia] Timestamp: Tue May 05 14:52:08 EDT 2015 ErrorCategory: SYSTEM_ERROR ID: 303 Class: com.bmw.psdz.tasks.coding.ncd.internal.evaluation. CafEvaluatorImpl
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
05-06-2015, 03:43 PM | #2 |
Rep 1,976
I had a detailed look at the logs again and this CDMM_USB_PORTS parameter has both USB1 and USB1_sia enabled when these are separate options on the drop down menu.
This was coded using the repaired CAFD on 55.1. I will try the trimmed one and see if that works. From what I understand, this repaired psdzdata is based off of parameters from older files so so I will see what happens when I used the original trimmed one instead.
05-08-2015, 09:06 AM | #3 |
Rep 1,976
Ok nevermind. I checked again and I left 6NH in there along with 6NS. Tried again and it works!!
This confirms that HU_NBT2 can have Mobile Office enabled just like regular NBT I was also able to FDL code everything else I had on my original NBT on this one as well. Hope this helps.
05-08-2015, 11:02 AM | #5 |
Rep 1,976
New professional nav system that's currently only on the F23 2 series cabriolet and the LCI F20/21.
It will be rolled out with just about any MY2016 built after July this year. Interface is almost exactly the same as HU_NBT except that NBT2 is capable of LTE connectivity and Over the Air map updates. Also, NBT2 now uses ATM instead of TCB for Telematics.
11-12-2015, 04:21 PM | #6 | |
Rep 153
I have a F36 from July 2015 and I have NBT2. I have been able to code many things but no the enhaced bluetooth (6NS). I had 6NH. I changed from 6NH to 6NS. "Office" appeared in the menu but no SMS no messaging and only one phone paired at a time (we have two Androids). After reading your post, I tried to put both 6NH and 6NS, but I got the following error: HU_NBT2 [63] cdDeploy ProcessedWithError cafd_00001ef6-006_011_023 Not Executable Any idea? Thanks in advance. Regards, |
11-13-2015, 03:53 AM | #8 | |
Rep 153
I did it (use both) because Aritaurus was successfull or at least that is what I understood from his message. EDIT: I have HU_NBT2 which seems to be a quite different... Last edited by 00punisher; 11-13-2015 at 05:52 AM.. |
11-13-2015, 08:58 AM | #9 |
Rep 1,976
No no, I accidentally had both there which is why it did not work.
11-13-2015, 11:25 AM | #10 | |
Rep 5,316
Drives: G80 M3 6MT
You just change the letter from H to S and VO code.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
11-13-2015, 12:02 PM | #11 | |
Rep 153
03-07-2016, 11:43 AM | #12 |
Rep 29
Punisher did you ever get this working? I have a new F30 with NBT2 and mine is exhibiting the same symptoms you described. Telelphone shows up as "telephone (1)" and no option for 2nd telephone. Office messages not working.
If you fixed it what was the solution? Thanks |
03-09-2016, 04:43 AM | #13 | |
Rep 153
I thought that maybe it was a problem of my phone, but all Android I have tested did not work either... I should test with iPhone, but I haven't do it yet. |
03-09-2016, 05:07 PM | #14 | |
Rep 29
BMW must have changed something recently that now prevents this from working. I'm probably just going to re-code mine to take 6NS out and then re-code the other HU features I want. If someone gets this figured out in the future I can go ahead and do it again. |
03-10-2016, 08:08 AM | #15 | |
Rep 1,976
03-10-2016, 09:36 AM | #16 | |
Rep 29
You can't enable notifications on the iPhone because that option does not show up when paired to the HU_NBT2. Once 6NS was FA written to the car and VO coding of the HU was done, the office menu shows up and the phone shows up as "telephone 1". However you can't pair a telephone 2 or choose notifications/messages as an option. I've tried with 2 iPhones and 1 Android phone and it doesn't work on any of them. Re coded FA and re-VO coded and it still doesn't work. |
03-10-2016, 09:44 AM | #17 | |
Rep 153
Options different from music streaming and contacts sharing are not shown when I paired any phone. Only "Office" menu appears but, as stated, you can't pair a 2nd phone and no notification/message is shown ever. |
03-10-2016, 11:08 AM | #18 | |
Rep 1,976
Telephone -> Bluetooth Device -> Highlight your phone and press options on the iDrive knob -> Scroll down to configure Bluetooth -> Check off Office, Telephone 2 and Show images and select ok. For telephone 2, select the second device and go to "Configure Device" and designate that as Telephone 2
03-10-2016, 02:18 PM | #19 | |
Rep 29
No "office" option appears under Bluetooth settings for the phone either in the iDrive menu or on the phone itself. The main office menu in iDrive shows up but the options for configuring office on the BT device are absent. What is the CAFD file name for your HU_NBT2? I think you might have a different version. Mine is CAFD_00001EF6_006_017.ncd |
03-10-2016, 02:58 PM | #20 | |
Rep 1,976
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 03-10-2016 at 03:23 PM.. |
03-10-2016, 03:37 PM | #21 | |
Rep 1,976
03-11-2016, 02:16 AM | #22 |
Rep 153
