05-05-2016, 07:10 AM | #1 |
Rep 47
Coding back to default
Could someone point me in the direction of best method to code back to default values:
a)the whole car b)individual modules If I have also VO coded i.e. 6NS , does that have to changed back first? Thanks guys
F36 4 series Gran Coupe - M Sport
05-05-2016, 10:51 AM | #2 |
Rep 86
This is what I read in another thread.
Restore Default/Factory Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on IHKA (the ECU itself not the underlying CAFD) => Select CODE. |
05-05-2016, 11:19 AM | #3 |
Rep 499
Drives: 2016 F80
I am not sure if there is an easier way but I would think you could just change the VO back to what it was and then recode all the modules you changed which should set them back to defaults for your VO.
Wouldn't that just recode the IHKA module? |
05-05-2016, 01:50 PM | #5 |
Rep 603
Setting the VO back to stock content and then VO coding each ECU you've changed is the quickest and safest way. You can also FDL code without modifying the VO given you have a backup of your stock CAFDs. You load the saved CAFD file rather than reading from the car and then FDL code.
- 2022 X3M Comp
- 2021 X5 xDrive 40i - 2018 F80 M3 (sold) |
05-06-2016, 11:14 AM | #7 |
Rep 2,302
And for the whole car you have to Right-click on "Ecus" at the top of the SVT-Table and then code.
Then all ecus will VO-coded and back to default in one single pass. |
06-22-2016, 02:17 AM | #9 | ||
Rep 8,364
You would only need to VO code the modified ECU modules and not the entire SVT tree. FYI: As a side, I would recommend using the word "Factory," while avoiding using the terminology "Default Values" because you NEVER want to hit the "Code Default Values" button. |
default, standard |
