BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > FDL/CAFD Description Missing
      06-05-2016, 07:35 PM   #1
studeezy
Drives: 2015 M4
I coded an F30 today for the first time and all went well. I later decided to code some other options on the same car but now all of a sudden when i try to edit the FDL i have no descriptions and all periods for the folders. I know this is a common issue that people have when they set the launcher to the wrong chassis; however i have mine set to f30 which is the correct chassis. Any ideas?
I am using E-Sys 3.27.1 with E-SYS Launcher 2.5.3.108 and PZDATA 58.1
      06-06-2016, 07:29 PM   #2
studeezy
Drives: 2015 M4
Bump
      06-06-2016, 08:14 PM   #3
kevinjt
kevinjt's Avatar
152
Drives: 335i M-Sport 14'
Ask shawnsheridan directly, he's one of great savy guys around here
      06-06-2016, 09:47 PM   #4
studeezy
Drives: 2015 M4
Will do. Thanks.
      06-08-2016, 09:56 PM   #5
studeezy
Drives: 2015 M4
I ended up rolling back my VM and reinstalling esys. This fixed it but the same problem happened again after reading the file in FDL editor the second time. It seems to have been a problem with windows xp. I have tested it in windows 7 and now it works every time.
      06-09-2016, 07:41 AM   #6
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
FYI, Windows XP is vintage 2001 and has been unsupported by Microsoft for years. Windows 7 has also recently been dropped from support. I use E-Sys with Windows 10 and so far, zero problems.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      06-09-2016, 07:52 AM   #7
studeezy
Drives: 2015 M4
Thanks. Since my post I've actually switched to Windows 10 for that reason. 👍🏾
      06-12-2016, 07:34 AM   #8
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
The reason you do not see any descriptions and only see dots I'd very simple. BMW has truncated all of the recent PSDZDATA files. To overcome this, Token Master has developed E-Sys Launcher. You can find links to down elsewhere on this forum & on Bimmerfest
Hope that helps!
      06-12-2016, 08:19 AM   #9
studeezy
Drives: 2015 M4
Hope that helps!
As stated in my original post. That was not the issue. I've posted my solution. Thanks.
