06-13-2016, 08:43 AM | #1 |
Rep 5
Dummy Error CAFD
Good evening Forum,
I tried to connect with esys to my F31, I was able to save the original SVT and the FA I have verified the I-step which is the F020 15-07-502 Problem with CAFD First attempt with esys premium launcher (3.27.1 psdData 58.3) Mistake of all as this under: CAFD_000011B3_001_002_011 Fehler: CPS read from ECU "ECUId: ZBE3_0x67" failed! [C070] negative response error: code: the result contains an error Description: Service RDBI_CPS has error in result: [Severity = 2051] [ErrorCode = 53311] [ErrorCodeDescription = Module offline] [VendorCode = 20039] [VendorCodeDescription = link is no longer active]; ECU: ZBE3_67_ETHERNET Severity: ERROR [2130759743] Have you any suggestions? Last edited by koaz74; 06-14-2016 at 09:33 AM.. |
06-14-2016, 12:50 AM | #2 |
Rep 8,364
It looks like you tried to read the entire SVT tree at once.
In general, there are not codes for each ECU so you will not need them all. For the "not found! [C012]" errors, it means a corresponding CAFD is not in your c:\data\psdzdata\swe\cafd (eg. cafd_00000794.caf.014_040_122). That is in P56.2, but dropped in P56.3. See post#189. For the "ECU_ETHERNET" errors, they are connection issues. You can make sure battery charged, engine is running, Antivirus and firewalls disabled, and just read single ECU. You can also try Reading Coding Data directly through E-sys (without launcher) then afterwards use Launcher to actually map. |
