10-21-2018, 02:30 AM | #1 |
Rep 98
Drives: 2007 bmw 335i
Need a break upgrade advice
Hey guys need your help to find out if anyone can tell me if I can fit the OEM M3 front calibers on an F30 2013 335i..... I currently have the OEM 4 piston brembo for the front I was thinking on putting does in the back and maybe upgrading to a 6 piston OEM M3 break caliper for the front the reason I needed it's because I fully.modified my 335i and I need more breaking power.
10-26-2018, 08:54 AM | #2 |
Rep 10,256
"More breaking power" involves much more than just swapping calipers.
Great thread on this topic: https://f30.bimmerpost.com/forums/sh....php?t=1529016 My suggestion would be to explore aftermarket brakes specifically designed for your car: either Brembo or AP Racing (my personal suggestion). Brakes with more stopping power are not inexpensive at about $3.5K per axle. |
10-27-2018, 10:54 AM | #3 |
Rep 1,934
OEM M3 front calipers would suffice. No need to spend all of that on AP or aftermarket Brembo kits, unless you are doing some serious tracking.
The f80 M3 front calipers are the same as the mperformance calipers for the f30. Run them with the F30 370mm rotors and you will be fine. Unfortunately the f80 M3 rears won't fit on the f30. Msport front calipers (blue or gray) are actually the same caliper as well but with a shorter carrier to fit the 340mm rotors. You can't lengthen the carrier however as hey are built in.
10-28-2018, 02:24 AM | #4 | |
Rep 98
10-28-2018, 05:34 AM | #5 |
Rep 775
Keep in mind you need to ensure the brake bias is balanced. There's quite a bit to brake calculations, and here's an example of what an ex-Brembo engineer (now with Girodisc) did with my heavily-tracked Ferrari. We uprated the front calipers/discs while also using more aggressive brake pads on the rears.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
11-02-2018, 05:36 AM | #6 | |
Rep 98
