12-18-2016, 07:09 PM | #1 |
Rep 1,509
Qi wireless charging adapter
It appears BMW has finally released a snap-in adapter that has Qi wireless charging... but I can't find any USA dealers that actually have one.
Has anybody actually seen this thing, or is it a unicorn? https://www.baum-bmwshop24.de/snap-i...g-84212412369/ |
01-02-2017, 06:55 AM | #2 | |
Rep 252
01-03-2017, 05:48 AM | #5 | |
Rep 600
However I found this as part# fitting the F3x series cars (but like written from 07/14 production and with S6NSA) 84102449887 http://www.realoem.com/bmw/enUS/show...84#84102449887 https://www.baum-bmwshop24.de/bmw-wi...rging-adapter/ Unfortunately, my phone is to big. The install guide is german. But see the pics. https://www.baum-bmwshop24.de/downlo...g_adapter.pdf/
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
01-03-2017, 05:38 PM | #6 |
Rep 26
Ya know I used this wonderful thing called Google Translate....and magically I can read German instructions from BMW. It works great so no need to worry about not understanding steps.
Wireless Charging Mounting (F20, F21, F22, F23, F30, F31, F32, F33, F34, F35, F36, F80, F82, F83, F87) Installing the wireless charging tray A in the center armrest storage compartment (1). Lay the wireless charging rack A as shown and connect it to the vehicle-side pin housing. Connect USB cable (2), pin housing 4-pin BL, free of clipping (no longer required). Shelf Install center armrest according to ISTA 84 10 700. Final work and functional test The retrofit system is not programmable / coding-relevant. - Connect the vehicle battery - Connect the battery charger to the vehicle - Vehicle testing equipmentSystemTo carry out andreplaced fault memory, process if necessary - Perform the functional test - Assemble the vehicle in a sensible manner - Deliver customer information to the customer. Customer information to wireless charging storage principle The wireless charging tray allows the following functions: - accommodation of the mobile phone - Charge the battery of a compatible mobile phone - Connect the mobile phone to the external antenna. This ensures a better network reception and consistent playback quality depending on the country. Functional requirements 1 Front bracket with LED 2 storage area 3 Movable holding clip - The mobile phone must support the required Qi standard compatibles. If the mobile phone does not support the Qi standard, the mobile phone can be loaded via a special Qi compatible charger (BMW recommends the specially developed wireless charging cases for iPhones for BMW). - The mobile phone must not exceed the maximum size of approx. 151 x 74 x 16 mm. - Use protective covers and covers only up to a maximum thickness of 2 mm. Otherwise, the charging function may be impaired. - Ignition or operation ready. Use the mobile phone LED indicators 1. Open the center armrest, see the operating instructions for the vehicle. 2. Insert the mobile phone in the back of the holding clip and push the holding clip with the mobile phone backwards, arrow 1. 3. Insert the mobile phone with the display facing up into the front holder, arrow 2. Color Meaning Blue Device is charging. Red Device is not loaded. If applicable, excessive temperature on the mobile phone or foreign body in charge tray. If the problem persists, contact a service partner of the manufacturer, another qualified service partner or a specialist workshop. Device is not loaded. If applicable, excessive temperature on the mobile phone or foreign body in charge tray. If the problem persists, contact a service partner of the manufacturer, another qualified service partner or a specialist workshop. -Z-
2016 F32 435i Sportline Sapphire Black
-Coded by Alex@Alpine -M4 Style Spoiler by Mod Bargains -AWE Touring exhaust with Midpipe by @AWE -Injen Air Intake by @Injen Last edited by HoosierIN_CA; 01-03-2017 at 05:48 PM.. |
01-03-2017, 09:48 PM | #7 |
Rep 943
Drives: 2012 328i Modern Line
There was a new M3 on the showroom floor today and I noticed it had the wireless charging option on the window so I popped open the center console and checked it out. It looks just like any other snap-in.
:wave:
01-04-2017, 03:01 PM | #8 | |
Rep 4
Also, the way the wireless charging is done in the 7 series seems different than the 3 series. I'm not even sure if the 7 plus with qi case will fit. Really brilliant on BMW's part. |
01-04-2017, 03:40 PM | #9 |
Rep 943
Here is a couple pictures of the wireless charging snap-in on 2017 M3.
[IMG]http://d.pr/i/1hek+[/IMG] [IMG]http://d.pr/i/Aphc+[/IMG]
:wave:
10-18-2017, 11:27 AM | #10 |
Rep 6
I have bought the bmw original wireless adapter tel:84102449887, but my F30 328i xDrive did not have electric cable interface as video showed, meanwhile I miss the plastic adapter of wireless, could someone help me to check? My VIN:MA91198.
Website:https://www.baum-bmwshop24.de/bmw-wi...rging-adapter/ |
03-08-2018, 04:23 PM | #11 | |
Rep 1,509
The German parts site did have a snap-in adapter with Qi listed about a year and a half ago, but I was unable to find it and it's no longer on their site. The part # is 84212412369. I've googled it and found many listings, but it's never in stock. If I'd been able to find it before I ordered my 440i that was delivered in June, 2017, I wouldn't have spent the $500 to get wireless charging in the new car. |
03-09-2018, 03:42 PM | #12 |
Rep 3,010
Drives: 2019 M2 Competition
I installed my own as well:
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
04-24-2019, 10:51 PM | #15 |
Rep 14
04-25-2019, 03:38 AM | #16 |
Rep 14
Could you send me the link? I think it will fit my 320i, I need this kind of wireless charger to install for my 320i, where can I find this? Amazon or eBay?
04-25-2019, 03:47 AM | #17 | |
Rep 14
05-20-2019, 01:15 AM | #18 | |
Rep 23
Maybe we can use this additional entrance to plug an additional USB PORT (maybe using 6111925854 ), as the wireless charge is not using the DATA functionality of USB port of NBT. Anyone tried ? Or know something about it ? My poor German makes me understand it from below image : “USB-Leitung (2), Stiftgehäuse 4-pol BL, klapperfrei befestigen (wird nicht mehr benötigt).” Last edited by jrbuzaid; 05-20-2019 at 01:23 AM.. |
